Old Mar 09, 2012, 01:35 PM
Jam1e is offline
Find More Posts by Jam1e
Worcestershire, England
Joined Nov 2007
Wooden props or nylon/plastic props.
Hi folks.
I'm after a few opinions on an issue i currently have regarding propellers.
All of my planes are either electric or glow. Until now that is.
I've now got a DLE 20 fitted in a Flair Swallow.
Most people are telling me to use a wooden prop as apposed to the usual nylon/plastic types. I've bowed to the knowledge of my fellow club members and have a few wooden props for my DLE 20.
Yet i'm puzzled with the explanation i get for using wooden props on a petrol/gas engine. I'm told that using a wooden prop saves the crank being damaged in the event that the prop strikes the ground. I understand this, but surely if crank damage was such a risk then surely "we" would use wooden props on our glow motors to. Which in my club is very rare??
Whats the difference?
Opinions appreciated
Jam1e is offline Find More Posts by Jam1e
Old Mar 09, 2012, 01:49 PM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
The only thing I can see is if for some reason gas engine manufacturers use lower grade steel for the crankshaft. (does anyone know?) I've seen a lot of nylon/glass and carbon fiber props on gas engines though... I don't think there's much more of a threat if any to the crankshaft compared to glow engines.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Mar 09, 2012, 02:19 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Chillphatcat hit the nail on the head. In my opinion, thats why I use wood on gas engines. I've worked on enough to see that the cranks are not as robust as those on a glow engine. I'll run MA and APC on my glows. I've bent more than a few gas cranks over the years, only one glow crank.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Mar 09, 2012, 02:23 PM
GeetarJoe is offline
Find More Posts by GeetarJoe
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
2 reasons:
1) wood props are lighter. especially when you get to the bigger sizes, 18" and up, composite props are downright HEAVY.
2) larger engines (15cc+) spin bigger props with more energy behind them. long and heavy composite blades spinning really fast can exert more than enough leverage on the crankshaft to bend it. on bigger airplanes a wood prop can act as a sacrificial fail point. in the event of a prop strike from a bad landing, or in my case this weekend a lost landing gear wheel, a wood prop will break when it hits the ground; usually this saves the airframe and/or engine crankshaft from damage.
GeetarJoe is offline Find More Posts by GeetarJoe
Old Mar 09, 2012, 02:39 PM
Jam1e is offline
Joined Nov 2007
Originally Posted by GeetarJoe View Post
2 reasons:
Thanks Joe.
So in basic terms, a petrol engine will run larger props so have more leverage to bend a crank?
Old Mar 09, 2012, 02:44 PM
Who Dat!
GeetarJoe's Avatar
Joined Sep 2011
Originally Posted by Jam1e View Post
Thanks Joe.
yes. think of the blade on the prop acting as a lever when it hits the ground. the longer the lever is, the more leverage is applied. when you add speed and mass the force on the fulcrum point, in this case the crankshaft, multiplies. with longer props you can easily apply enough leverage to bend a crankshaft.
Old Mar 09, 2012, 02:57 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
had a ton of engines in the 20-30cc range over the years. i've broken exactly 0 crankshafts in my 18 years of flying in that range, and i only have ONE plane i run wood props on in 20-30cc (a xoar). they cost too much & break easy, but expensive props > new more expensive engine. otherwise it's all APC's (narrow or wide profiles) or MAS classics. and MAS-C's are easily the toughest props worth anything.
if people are breaking crankshafts, they should quit buying chinese engines with who know's what crappy cheap alloy they decide to make the cranks out of.
or learn to land & quit breaking them in the first place. (yes, that means YOU Mr. always high-alpha landing. why not try landing for real & stop breaking them? durrr) ya, you can break a crank if you... shear off most of the prop... for the typical "ooops" landing where you just knick off an 1/8" it'd have to be chinese to break. (which is where the composite props are better. you knick a wood prop theyll split & it's a throw away. you knick a composite prop and you may riffle up a MAS-C, or knock off 1/8-1/4" from an apc-s)
it's that simple. the problem isn't the props. it's the morons busting things trying to pass off props as the problem instead of the inferior *everything* in their popular, cheap chinese engines.
Toysrme is offline Find More Posts by Toysrme
Old Mar 09, 2012, 03:24 PM
edwin1 is offline
Joined Sep 2003
I dont think its as much breaking a crank as bending one. It will happen from time to time in a crash. The only glow crank I bent was a verticle impact into pavement. I've bent two gasser cranks (being stupid too low) on hard dry ground. I'm just a sport flyer, but like the occasional screamin low pass.
Edwin
Old Mar 09, 2012, 04:00 PM
Who Dat!
GeetarJoe's Avatar
Joined Sep 2011
Geez Toys.. why don't you tell us all how you really feel. lol
Old Mar 09, 2012, 04:24 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think the most likely reason to use a wood prop is that the wood prop might possibly break before it cuts off your arm, leg or head. The plastic prop being less fragile is likely to do some serious damage to you if you both come into contact with each other.
But if you are careful then it is a non-issue, I suppose. The problem is a big gasser has a pretty stout prop on it, and it isn't going to break easily anyway. So it will probably cut off a appendage anyway.
earlwb is offline Find More Posts by earlwb
Old Mar 09, 2012, 07:02 PM
Toysrme is offline
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
that's fine on small engines, but im with you. i think it's silly for people to imagine 20cc+ engines actually running won't chew up anything they come into contact with. let's face it. for the vast majority of all hand+prop incidents are nothing. you were reaching for the glow or needle valve & brushed a knuckle into the trailing edge of a prop. i've done it. everybody's done it.
RC Plane Accident - Why you shouldn't stay near the propeller ! (1 min 43 sec)
Old Mar 09, 2012, 08:32 PM
AMA 537620
Joined Oct 2008
I've never touched a spinning prop in 20 years.
Well... not entirely. I've hit myself with my small helis on several occasions.
Old Mar 10, 2012, 02:24 AM
Jam1e is offline
Joined Nov 2007
Why do you write such an aggressive post??
Very unnecessary.
Old Mar 10, 2012, 02:47 AM
Jam1e is offline
Joined Nov 2007
http://www.youtube.com/watch?v=tzXyYX7hZvw
Ouch!!!!
That is some severe injury!!
Two years ago I stupidly pulled my hand through a prop when retrieving my glow stick.
Split my thumb in two and cut right through my index finger, bone and all!!
I had surgery and 4 days in hospital to sort it out.
And i thought that was bad enough, but that video had me clutching my hands together!!
Old Mar 10, 2012, 07:46 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yeah when you see things like that, you tend to get pretty paranoid about it. It does give one pause to think and plan their safety issues more.
Help! I need help to find black nylon/plastic threaded 3mm spacers. T.Rex.450 Multirotor Talk 6 Nov 17, 2011 03:35 PM
Discussion Wooden blades...plastic blades....carbon blades...huh? makenzie71 Electric Heli Talk 10 Sep 23, 2011 06:40 AM
Wanted 8 -32 plastic or nylon bolts with hex head or allen heads BrianSmith Aircraft - General - Miscellaneous (FS/W) 3 Mar 28, 2009 06:28 AM
Question Plastic or Nylon Staple ideas... Lavawing Slope 8 Aug 26, 2006 07:33 PM
