Old Mar 09, 2012, 12:18 PM
Heli2Crash is offline
Find More Posts by Heli2Crash
Joined Jan 2011
Question
3DHS Edge 48 and 58"
Question..... I saw on forums before but now i cannot find it, but i saw that the Edge's had to have weight added to the noise to get proper CG...
How much was was it? I am flying a 2x4S (Parallel) 2200Mah on the 58 and i have to shove the batterys all the way up into the noise of the plane... I added 212 grams to the noise of the plane, which let me scoot the battery's back a hair.. I would like to move them back about a half a battery more... Is it ok to keep adding weight to acheive moving the battery's back?
The 48" is not so bad, and i have not added much if any weight to it. The setups are as follows:
Edge 58":
Hacker A40-10S
ICE 75
x2 4s 2200 Mah battery’s (about 261 grams each)
Edge 48"
Hacker A30-14S V2
Hacker XB Pro 55amp
Hyperion 3S 2500Mah Battery
Thanks again for letting me pick your guys brains.
Dave
Heli2Crash is offline Find More Posts by Heli2Crash
Old Mar 09, 2012, 12:33 PM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
Adding weight would definately not be the way I would go about it but that would work. I have the same setup on my 58 and I am able to get a slighty nose heavy CG with it. I made a small shelf to slide the battery under up front and then I simply strap down the back of them. Very simple and it keeps you from having to add weight.
joesmith285 is offline Find More Posts by joesmith285
Old Mar 11, 2012, 08:34 AM
Maxster is offline
Find More Posts by Maxster
Joined Oct 2006
I am struggling to get my 58" to balance.
I am running 5245 all round and 5S 3700. I have had to add weight. ESC and RX as far forward as possible.
I flew it and need to add more weight as still a little pitchy.
Joe, whats your set-up to balance with no added weight?
Maxster is offline Find More Posts by Maxster
Discussion 3DHS Edge 58 ESC/Motor question Heli2Crash 3D Flying 1 Mar 05, 2012 02:26 AM
Question 3DHS Edge 48" and 58" question Heli2Crash Electric Plane Talk 3 Feb 12, 2012 09:09 AM
Question 3DHS Edge 48-58 wing question Heli2Crash 3D Flying 2 Feb 12, 2012 08:33 AM
Question 3DHS Edge 48" and 58" Wing question Heli2Crash Electric Plane Talk 0 Feb 10, 2012 08:02 PM
Help! 3DHS Edge 540 48" and 58" Heli2Crash Power Systems 2 Feb 10, 2012 11:37 AM
