Old Mar 09, 2012, 12:09 PM
chriscap is offline
Find More Posts by chriscap
USA, CA, Los Angeles
Joined Jun 2010
Question
Shorting jumper leads on Power Supply
I have two Dell Poweredge 2850 power supplies that I'm converting for use with a charger. I was curious if anyone had any recommendations for permanently affixing the required pin shorts. There's not a whole lot of room for error if I solder direct. I was hoping there was some kind of one pin jumper that I could solder to in order to make it easier. Any suggestions or is everyone just really good solderers. I am not that great unfortunately. I've thought about possible cutting up a servo lead to help possibly.
chriscap is offline Find More Posts by chriscap
Old Mar 09, 2012, 01:12 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Most use standard pin spacing that is the same as use on hard Drives, DVV Burners,etc. for Drive Select thus computer drive select shorting / selection clips work fine.. Also same spacing as servo connectios.
Charles
Old Mar 09, 2012, 01:30 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I always take mine apart and do it internally. Wire wrapping works great, just strip off the insulation and solder to the points needed. Also can use stranded wires, not from our sillicone wire, but like a trailer plug uses. I then make a sticker for the case showing there is a mod inside on pins xx, xx, xx.
For testing I use a servo wire that has had the pins pulled out of the connector. Once you get the ones you need to short out solder these directly to the pins and slip heat shrink over the soldered connections. The tails can all be soldered together. IMO, it works but is fuggily.
Rick
rampman is offline Find More Posts by rampman
Old Mar 09, 2012, 03:53 PM
chriscap is offline
Joined Jun 2010
rampman, you're talking about pulling the pin assembly off, finding the source wire, and soldering directly to that? Hmm...hadn't thought about that.
Old Mar 09, 2012, 04:33 PM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Naa, too hard to pull all of those off. Inside they all go like this:
L L L L L
L L L L L
L L L L L
L L L L L
so from the inside where they solder to the PCB I go:
\ L L L L
L \ L L L
L L \ L L
L L L L L
...where the wack ( \ ) is a wire connecting all to each other, a jumper wire. I do it on the PCB. Sometimes I do this at the ribbon cable header, sometimes on the hot swap header; which ever is easiest.
I always take these apart anyhow to blow out all the dust inside and change out some of the screws to adapt to my termination block of choice. It only takes another couple minutes to short these inside.
Rick
Old Mar 09, 2012, 04:51 PM
chriscap is offline
Joined Jun 2010
I kind of understand. I have to go look at it tonight. If you have any pictures that would help. Thanks for your post
Sold Feather Power 42 amp power supply - $35 shipped 6L6Amp Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 06, 2012 09:18 AM
Link Servo and Battery Leads on clearance! ServoCity ServoCity.com 0 Feb 29, 2012 08:43 AM
Question Power leads' length on motor Billinaz Power Systems 3 Nov 09, 2011 10:29 PM
Discussion Will power supply be damaged if voltage applied to output leads? insalacosm Batteries and Chargers 2 Feb 10, 2011 02:28 PM
For Sale Pyramind PS-12KX 10-amp Power Supply + Leads Rooster287 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 04, 2009 12:57 PM
