Old Mar 09, 2012, 11:21 AM
jasper7821 is offline
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
What do you guys have the NAZA voltage monitor settings to on a 4s battery
Just curious what I should set my voltage monitor to.
I made another thread and in the battery section and someone suggested to make the no load voltage at 14.8 and the loaded voltage to 12.8 which would equal a .5v loss.
I don't remember what my settings are but they are too high.
I hovered for just over 6 minutes until the light flashed red and landed.
I only used 2316mah so I need to lower the warning voltage.
I have a 4.6 pound loaded Flame Wheel F550 with a Turnigy Nano-Tech 4500 battery.
Just curious what your guy's settings are.
jasper7821 is offline Find More Posts by jasper7821
Old Apr 29, 2012, 08:18 PM
modifyit15 is offline
Find More Posts by modifyit15
Joined Nov 2006
Im having the same problem with my WKM
modifyit15 is offline Find More Posts by modifyit15
Old Apr 29, 2012, 08:19 PM
Joined Nov 2006
my battery was only discharged by 40%
Old Apr 29, 2012, 08:31 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
The best way to gage your discharge is to time the flight and then check how much you put back into the lipo. I start at 5 min. and adjust from there. I run 3.3v/cell and put back about 80% on charging. Your lipos and experience may vary. I fly 8:30 on 4S 4000mAh lipos in my F550 hexa. You have to test and set a timer on top of the battery monitor in the Naza software.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Apr 29, 2012, 08:50 PM
Joined Mar 2008
I have mine set to 14.8 no load and 14.2 loaded on the first protection.
Second is 12.0 no load and 13.4 loaded.
I have my DX8 set to vibe at 14.1
It used to be ok and the battery would take 80% but now all the batteries are only taking about 58% then they're fully charged and showing 4.18 to 4.2 per cell.
When the used batteries cool down all the cells are 3.71 to 3.72.
I'm getting about only 6 minutes on my F550 with the 4500 4s.
Weight is 6 pounds.
Is there a reason why these settings used to use 80%, but now they're not ?
Can I lower the voltages and fly longer.
What is the minimum loaded voltage a cell should be run down to ?
Old Apr 29, 2012, 10:04 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
My guess is that it is your lipos.
Site Sponsor
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Help! NAZA question about switching from 3s to 4s, do I have to change in software first. jasper7821 Multirotor Talk 9 Mar 09, 2012 11:07 AM
Discussion what do you guys think of this clone dynam 3D Flying 0 Feb 28, 2012 11:04 PM
Discussion Using Virtualdub to record FPV - What settings do you use? NorCalMatCat FPV Talk 12 Feb 25, 2012 08:33 PM
What do you guys do when you have a new plane and bad weather? soholingo Electric Plane Talk 19 Dec 15, 2002 09:34 AM
