Old Mar 09, 2012, 12:08 PM
bth is offline
bth
Find More Posts by bth
bth
Bjørn Terje Hansebråten
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
Build Log
Peter Rake's 48 " DH 6 scale 1/9 (No shortkit) (3. prototype build)
I got the PDF files from Peter Rake before Christmas, and this week I want to start building it. I printed out the parts I need on A4 paper, and glued together. I want to build by cutting my own parts, so how long time it will take, I do not know.
(If there would be something wrong or unclear in the text, please let me know, since English is not my native language)
(Google Translator helps some)
bth is offline Find More Posts by bth
Old Mar 09, 2012, 12:26 PM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Bjørn,
You appear to be off to a good start. If there is anything that puzzles you about the plan, just post a question and I'll try to answer it.
It will be nice to get another design that's been hanging about a while completed. Thanks for taking on this one.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Mar 10, 2012, 08:37 AM
bth is offline
bth
bth
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
Former F1
I'm a bit concerned about the space between the upper and lower part of F1
(marked red),
when someone want to make a bigger battery hole(marked green).
It won't break on a noseover?
One solution is to add a area on MM2 and MM3 (in blue) to get a larger grip area.
Old Mar 10, 2012, 01:05 PM
Norfolk, England
Joined Sep 2001
If you nose over hard enough tot break an 1/8 birch ply bulkhead, I think that will be the least of your worries. If you're worried about it, how about moving the servos down and extending the hole in that direction. How big a pack were you thinking of fitting?
Pete
Old Mar 10, 2012, 01:30 PM
bth is offline
bth
bth
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
Pete
The packs are 25-27 mm high , and 35 mm width (3 cell 2200 mAh ), so I have to take out 4-5 mm.
Old Mar 12, 2012, 01:21 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
When I need to use a translator, I find using more than one is useful for checking accuracy. Another translator is the Systran site: http://www.systranet.com/translate
As well as using multiple translators, I will take the translated results and translate it back to the original language. Sometimes the results will suggest a better word to use as a source.
James
Deuce is offline Find More Posts by Deuce
Old Mar 13, 2012, 12:30 PM
bth is offline
bth
bth
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
Wing rib cutting.
Todays work outside in the sun.
Old Mar 16, 2012, 02:40 PM
bth is offline
bth
bth
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
How do I delete this message ?
Old Mar 16, 2012, 02:47 PM
bth is offline
bth
bth
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
More done on the fuselage.
Old Mar 20, 2012, 02:57 PM
bth is offline
bth
bth
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
Motor
Technical Details for AXi 2814/20:
No. of cells (LiPo) 3-4
RPM/V 840 Kv
Max. Efficiency 83%
No load current 0.7A
Maximum Load 25.0A
Internal Resistance 0.145Ω
Diameter 35.00mm (1.38")
Length 37.00mm (1.46")
Shaft Diameter 4.00mm (0.16")
Max. Efficiency Current 8 - 17A (>75%)
Glow Equivalent .20
Weight 106.0g (3.7oz.)
£55.79 exc. VAT
The motor I have ordered:
Turnigy D3536/8 1000KV Brushless Outrunner Motor
Spec.
Battery: 2~4 Cell /7.4~14.8V
RPM: 1000kv
Max current: 30A
No load current: 1.7A
Max power: 430W
Internal resistance: 0.052 ohm
Weight: 102g (including connectors)
Diameter of shaft: 5mm
Dimensions: 35x36m
Prop size: 7.4V/11x5 14.8V/10x6
Max thrust: 1160g
$15.99
Old Mar 20, 2012, 06:03 PM
Norfolk, England
Joined Sep 2001
Sounds fair enough. I know the AXIs are expensive, but they're the ones I feel I get most reliable specifications for - and I could get good drawings of them.
Old Mar 23, 2012, 01:19 PM
bth is offline
bth
bth
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
More on the DH 6
I think you should keep using AXI, it is easy to find motor matcing.
Old Mar 30, 2012, 11:24 AM
bth is offline
bth
bth
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
Motor cowling.
Motor cowling. I replaced the bottom with balsa. It is drawn with 1/8 (3 mm) ply. Have to add the scoop.
Build Log Peter Rake's 1/5 scale Chiribiri - Prototype build crawlspace Scale Kit/Scratch Built 128 Dec 12, 2014 07:35 PM
Build Log Peter Rake's 36" WACO 9- prototype build Zephyr41 Scale Kit/Scratch Built 97 Jul 26, 2013 01:19 PM
Build Log Peter Rake 48" DH-6 prototype build Dan Parson Scale Kit/Scratch Built 222 Mar 11, 2012 03:18 PM
Build Log Peter Rake's Udet Flamingo Prototype Build uranus456 Scale Kit/Scratch Built 55 Dec 01, 2009 09:20 AM
Build Log Peter Rake 48" D.H.6 prototype build Skycruiser Scale Kit/Scratch Built 41 Jul 14, 2009 04:14 AM
