Old Dec 23, 2012, 12:03 PM
ShoeDLG is online now
Find More Posts by ShoeDLG
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
The role of the foam was to show that if something held up the helicopter, and in so doing experienced no net vertical force, that thing would experience no vertical acceleration. This is patently obvious when that thing happens to be a solid (e.g. a foam block), and apparently quite elusive when that thing happens to be a fluid (e.g. the air). You are correctect that the size of the foam is of no consequence.
And by "fluid" I mean a substance where stresses are proportional to strain rates, not necessarily a "liquid".
ShoeDLG is online now Find More Posts by ShoeDLG
Old Dec 23, 2012, 12:38 PM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
I do understand fluid also fluidics - having done control systems using same laws of physics as you may refer to .
In this case there are no moving parts and the control is either digital or analogue-depending on desired results..
Anyway
Merry Christmas and Happy New Year to all .
and Season's Greetings to the politically correct crowd.
richard hanson is online now Find More Posts by richard hanson
Old Dec 27, 2012, 03:58 PM
Crossplot is offline
Find More Posts by Crossplot
Joined Dec 2011
ShoeDLG --
Would you be interested in pursueing r/2 off thread?
butcharts2@aol.com
Crossplot is offline Find More Posts by Crossplot
Old Dec 30, 2012, 07:41 AM
The PIPE is offline
Find More Posts by The PIPE
The PIPE's Avatar
USA, MA, Weymouth
Joined Mar 2004
I always refer people to the "Stick & Rudder" book on issues like this...
Dear Fellow RC-Groupers:
The PIPE Here...whenever I see the "issue" of "what causes a plane to have lift while in flight" come up, I just refer people to get a good look at pages 7 through, say about page 11 of the famous Wolfgang Langewiesche-authored book "Stick and Rudder: An Explanation of the Art of Flying", in more-or-less continuous print for nearly SEVENTY years as of 2012.
Page 7 of the book, in the chapter "How a Wing is Flown", has the very aptly named section entitled "Forget Bernoulli's Theorem", a VERY appropriate title for those of us, who like yours truly, has had numerous migraines manifest themselves whenever someone mentions that filthy eight letter word "calculus" at any time.
As that OH-so-true maxim "a picture is worth a thousand words"...or PERHAPS a few dozen integral calculus (there's that FILTHY word again!) symbols...tells us, the pair of illustrations on page eight of the book really "tells us like it is". That pair of illustrations possesses the following captions, depicting a light Cessna 195 style aircraft from a nose-on view about to fly through something like a fog bank near the ground, and then flying through it. The first caption reads:
"The airplane keeps itself up by beating the air down. If one could lay a smoke cloud into an airplane's path..."
then with the second image showing the Cessna 195-like aircraft having flown THROUGH the cloud...
"..the airplane, having flown through it, would squash it down."
My late RC flight instructor (left us sixteen years ago this month) Sammy Frey told me a generation ago that Langewiesche's book was the best he had ever read for ANY RCer to start to understand "why a model aircraft behaves the way it does" when we fly our birds...and all this time later, whenever I pick up my own personal copy to read and re-read whenever I have a moment to do it, I cannot help but agree with Sammy's assertion from so long ago.
That's just my take on it...I simply wish that calculus (again with the filthy word!) was NOT so scary for my brain, and that I had managed to get some help learning how to understand it when I tried to go for an engineering degree in the early 1980s !!
Yours Sincerely and Happy 2013,
The PIPE....!!
The PIPE is offline Find More Posts by The PIPE
Old Dec 30, 2012, 10:25 AM
Tim Green is offline
Find More Posts by Tim Green
Joined May 1999
The PIPE....!!
YES - same as NASA is saying - action, and reaction - Lift is a reaction to accelerating a lot of air downward (the action).
Tim Green is offline Find More Posts by Tim Green
Old Dec 30, 2012, 10:36 AM
Joined May 1999
Originally Posted by TangoKilo View Post
Is it not the fact that force equals the rate of change of momentum?
F=d(m.v)/dt
The rate of change of momentum of the air being caused to move by the rotor blades must be equal to the helicopters weight.
Yes indeed. And you can hover a model copter, weighing 1lb, over a scale large enough so that all the copters air hits it, that scale will read roughly 1lb, just from the air hitting it.
Old Dec 30, 2012, 11:13 AM
ShoeDLG's Avatar
Joined Mar 2012
And if you understand Newton's Second and Third Laws, you will conclude from this that there is no net vertical force acting on the air, meaning that its rate of change of vertical momentum is zero.
Old Dec 30, 2012, 11:17 AM
ShoeDLG's Avatar
Joined Mar 2012
You would be doing yourself a disservice to make up your mind on this subject before trying understand the analysis done by late Peter Lissaman (you can read about some of his work here).
http://en.wikipedia.org/wiki/Gossamer_Condor
In his presentation titled "The Meaning of Lift" he thoughtfully examines the relationship between lift and momentum. His conclusion boils down to:
"In wind tunnels, for example, all the cross stream forces are represented by pressure perturbations on the boundaries - there can't be any downwash, that's what the walls are there to prevent! Interestingly, all aircraft operating on any planet (that covers most cases of interest!) operate in ground effect in the sense that their wake is long compared to their height from the ground plane, and so produce no net downwash momentum in an infinitely large volume. It's a good thing we ave already shown that downwash is not required for lift!"
Although his approach is lighthearted it does include Calculus. If the calculus in his analysis is not accessible to you, it may still be worth recognizing that the relationship between lift and momentum exchange may be more subtle that it might appear.
Old Dec 30, 2012, 12:03 PM
Joined May 1999
What on earth, are you on about? Please clairify.
Old Dec 30, 2012, 12:17 PM
Joined May 1999
There's no net downwash? Really?
If you place a scale above a hovering chopper - scale reads zero, or close to it.
If you place a scale below a hovering chopper - scale registers the weight of the chopper.
If your man was right, fans would blow air both directions - and they don't, not in my world.
Old Dec 30, 2012, 12:23 PM
ShoeDLG's Avatar
Joined Mar 2012
-In order for the helicopter to be in a steady hover, the upward force exerted by the air on the helicopter must be equal to the helicopter's weight.
-Newton's Third Law tells you that the force exerted by the helicopter on the air is equal and opposite the force exerted by the air on the helicopter. Therefore the helicopter exerts a downward force on the air equal to its weight.
-The reading on the scale tells you that the air is exerting a downward force on it equal to the helicopter's weight.
-Newton's Third Law tells you that the force exerted by the air on the scale is equal and opposite the force exerted by the scale on the air. Therefore the scale exerts an upward force on the air equal to the helicopter's weight.
-The net vertical force acting on the air is the vector sum of the downward force exerted on it by the helicopter (equal in magnitude to the helicopter's weight) and the upward force exerted on it by the scale (also equal in magnitude to the helicopter's weight). The vertical forces acting on the air sum to zero.
-Newton's Second Law tells you that an object's rate of momentum change is equal to the net force acting on it. The net vertical force acting on the air is zero, therefore it's rate of vertical momentum change is also zero.
Old Dec 30, 2012, 01:03 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Heli-hovering.... Bernoulli and Newton..
Bernoulli works all the time, but can be thwarted.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 30, 2012, 01:18 PM
ShoeDLG's Avatar
Joined Mar 2012
Sparky,
What if you were to measure the force on the scale in the case where you place a large plate just above the rotor of the single-rotor helicopter? I predict that you would see a noticeable drop in the force measured by the scale.
I suspect that you would have to fix the helicopter in place for this because a stable hover would be next to impossible to achieve. I predict that the lift generated by the rotor would go up even as the reading on the scale went down.
Old Dec 30, 2012, 02:03 PM
ciurpita is offline
Find More Posts by ciurpita
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
Wheli = Fair = d(m.v)/dt = ma
causing the air to accelerate downward and increase its velocity
Fscale = Fair = d(m.v)/dt = ma
causing the air to de-accelerate and decrease its downward velocity
ok, the net result is no change in momentum, but what happens to the air between rotor and scale compared to the same mass of air without a helicopter? what is the velocity of the air above the rotor, halfway between the rotor and scale, and at the scale?
what's the definition of net?
ciurpita is offline Find More Posts by ciurpita
Old Dec 30, 2012, 02:48 PM
Joined Dec 2011
Bernoulli equation without having to resort to a mysterious and unsupportable r/2 “integration factor". .
For anyone that was following pressure change from normal acceleration:
Shoe was right in saying that the pressure sum accumulated accross the field from normal acceleration (turning flow) Requires a proper math solution.
However, for practical understanding, we can resort to old fashoned graphing.
At the surface we have the curve r and the velocity relative to it providing a dP/dr pressure gradient at the surface. For the gradients of r's outboard we can use v = V(1+a^2/r^2).
If we plot the pressure gradients, density*v^2/r, against r , the area under the plot curve will be the local pressure difference from P(total).
If we count squares we find that it is equal to the surface gradient times 1/2 the surface r. This leaves us uderstanding the source of lift while able to contiue the use of the Bernoulli equation
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Discussion Is there anything listed that you can't live without? P-51C Life, The Universe, and Politics 44 Aug 05, 2011 02:55 PM
Discussion Fast food that you just can't do without. Bilbobaker Life, The Universe, and Politics 101 Aug 17, 2010 11:30 AM
Joke What Would You do to get that Aircraft You Can't Have ? Chophop Humor 10 Feb 09, 2010 07:00 AM
Discussion HELPIf you have a problem that can't be solved here ccowboyearl Beginner Training Area (Heli-Electric) 2 May 14, 2009 12:31 PM
