Old Dec 20, 2012, 05:38 AM
ShoeDLG is offline
Find More Posts by ShoeDLG
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
Originally Posted by ciurpita View Post
how would the answer be different for a vertically mounted rotor (propeller) operating horizontally?
The presence of the ground would still influence the path of a fluid element. I would expect the influence of the ground to be far less for the case where the thrust is parallel to the ground.
The only reason we're talking about helicopters in ground effect is Tim Green asked: "How close to zero can the rate of momentum transfer be, when a 1000lb copter is hovering?"
I responded that: "in the limiting case of ground effect (rotor height very small compared to rotor diameter), the rate of momentum transfer goes to zero."
I'm not exactly sure where the discussion is going, but through a series of follow-on questions, I believe we have agreed:
1. The dynamics of an isolated bowling ball provide an inadequate analogy for describing the dynamics of subsonic fluid flow. The path that a fluid element follows can affect the pressure on the surface of a wing even if that fluid element never makes direct contact with the wing.
2. The momentum of an object that is composed of a collection of elements that are free to move relative to each other (like the air) can be zero even if some or all of the elements are in motion.
I have suggested that the acceleration experienced by a fluid element in the vicinity of a helicopter operating in ground effect is influenced by both the rotor and the ground. Not sure if we agree on this or not.
ShoeDLG is offline Find More Posts by ShoeDLG
Old Dec 20, 2012, 06:08 AM
ciurpita is offline
Find More Posts by ciurpita
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
i'm just trying to make sense of this. Sorry if this is tangential to your helicopter analysis. Is this a matter of perspective? Based on your description of "net momentum transfer", of course it's zero. Holes (vacuum) aren't being created in the space above the ground when aircraft move through it.
but is it true that no net momentum transfer means no downwash and this means no organized movement of air due to lift?
isn't it true that on a smaller scale, < wing chord/10, the air is displaced by the airfoil, first traveling upwards and then downwards on the top surface? Isn't this organized movement of air which means there is a local transfer of momentum in the region close to the airfoil surface?
But perhaps more specific to issue being discussed, isn't there is also organized air movement and momentum transfer upward just in front (chord < 10) of the airfoil and something similar behind the airfoil?
can you relate what you've been saying on this scale, chord < 10? (Of course it's influenced by the air > chord/10 distance from the airfoil).
my understanding is if there is roughly equal organized upward movement of air in front of the airfoil and downward movement behind it, there is no net momentum change on a scale of 2* chord. But the airfoil has affected the air near it (< chord/10). Isn't there some local momentum change < chord/10?
i'm not looking for specific answers to my questions, but hoping they give you a sense of my confusion.
ciurpita is offline Find More Posts by ciurpita
Old Dec 20, 2012, 08:56 AM
Tim Green is online now
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
Originally Posted by ShoeDLG View Post
The temptation is to respond with the obvious answer: that the air is accelerated downward by the rotor blades. In many ways this answer is correct, but it isn’t complete. If you consider a fluid element near the rotor, the acceleration it experiences is determined by the sum of the forces acting on it (in accordance with Newton’s Second Law). For a rotor operating in ground effect, the forces acting on a fluid element are influenced not only by the presence of the spinning rotor, but by the presence of the ground as well. The path that any given fluid element follows is obviously different depending on whether the rotor is operating near the ground or not. This means that the accelerations experienced by the air are different.
Your question is: “What's accelerating the air downward?”
The answer is: both the rotor and the ground are responsible for the acceleration experienced by the air.
The ground? Get Real. It can only slow the air down - it cannot accelerate it - the ground doesn't move - not in my world.
To answer my own question correctly - what's accelerating the air downward? THE WING.
Then according to Newton's Third - the wing is reacting with a lifting force equal to the mass of the air times the acceleration of the air.
How do we know the air's accelerated? That air wasn't moving before the wing got to it. It's moving after the wing goes through it though.
How do we know the air has mass? Every thing has mass.
How do we know the wing was the object that moved the air? Nothing else there but the wing. Has to be the wing.
How do we know the wing will react with a lifting force to the action of moving all that air down? Newton's third law - for every action, there's a reaction.
Sure there are side shows, lots of complex math needed, in order to actually design a wing. But the lifting mechanism is straight down simple - the wing reacts to the air it causes to move downward per Newton's third law.
Tim Green is online now Find More Posts by Tim Green
Old Dec 20, 2012, 11:16 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
I 'll be darned - - I foolishly believed lift occurred because there was a pressure difference .
pressure higher on bottom than top- seems to want to equalize - for some strange reason and as long as pressure difference is sufficient - you got lift. Complex, math required - In some cases - in most nope
richard hanson is offline Find More Posts by richard hanson
Old Dec 20, 2012, 11:52 AM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
"Acceleration" in the Newtonian sense refers to a change in (vector) velocity. If the ground is slowing the air down, it is accelerating it (and there is a force required to create the change velocity).
No one said anything about the ground moving. If you don't think the stationary ground can accelerate the air, then I recommend you jump off a tall building and tell us if you experience a reaction force as you come to a stop.
I will continue point out that the mechanism you describe is generally incorrect. Your assertion that a wing must change the air's vertical momentum is nothing more than an expression of faith. Until you actually compare the momentum in a wing's upwash to momentum to its downwash you are speculating about net momentum transfer. Simply stating that there is more momentum in the downwash than in the upwash does not make it so.
Old Dec 20, 2012, 12:28 PM
Ashtabula, OH USA
Joined May 1999
Feeling a bit sarcastic today, are we? Anyway, F=MA is the math you need to understand first, before trying anything more complex.
Old Dec 20, 2012, 12:39 PM
Ashtabula, OH USA
Joined May 1999
The ground absorbs energy from the air - it doesn't add energy. Only moving things can add energy to the air. Nor is the ground, part of the plane.
Anyway, it's a moot point - cause you seem to be denying that wings move air (accelerate the air downward) ... just so you can deny that the wings react to the air they move with a lifting force.
Wow.
Old Dec 20, 2012, 12:56 PM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
Energy and momentum are two fundamentally different quantities. The ground doesn't need to change the air's energy in order to change its momentum
Old Dec 20, 2012, 01:12 PM
Crossplot is offline
Find More Posts by Crossplot
Joined Dec 2011
[QUOTE=ShoeDLG;23559575]. I think we are in complete agreement about how the radial pressure gradient at any point in the fluid is related to the acceleration normal to the flow streamlines:
(1) dr = -(r/v)dv or equivalently: dv = (-v/r)dr
(2) dp = density *( v^2 / r) * dr = density *( v^2 / r) * (-r/v)*dv
(3)dp = - density * v * dv
QUOTE] (823)
Thanks again for the imput, However, there is a little more work to be done!
As stated, your equations fit the min pressure point on the circular cylinder where dv/v = .5
When we move to the eliptical cylinder where the max velocity = v=V(1+h/l), dv/v falls as h/l gets smaller. The same problem arises when we move away from min pressure point on all cylinders.
Either the .5 is a constant, based apon its being defined by the circular cylinder being a dipol or a correction needs to be added for different h/l.
The momentum of air passing the min pressure point is the same for equal h but the vertical profle changes with h/l.
Crossplot is offline Find More Posts by Crossplot
Old Dec 20, 2012, 01:46 PM
Joined Dec 2011
The bottom line remains that you can't determine the pressure at a point on the surface of a cylinder or airfoil purely from the boundary conditions there. You have to know the conditions over the entire fluid boundary,:.
One has to keep things in context. For the hundreds of web pages and the thousands of visiters, 98% are only looking for principles, they are not going to try to solve any four element equations.
To the best of my knowledge no one that completely understands has produced a truly accurate description of lift for the "common" man. They have produced papers of "chicken scratches" for each other. When I started this what was out there was terrible.
As for conditions at a point on the surface, if you have the local velcity it was established from the source/ sink displacement pattern that shapes the entire field. It also includes the overall effects of circulation. That should be close enough for principles.
Old Dec 20, 2012, 05:01 PM
Joined Oct 2007
Sarcastic -
not really
prove my staement wrong.
Old Dec 21, 2012, 01:37 AM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
A little knowledge is a dangerous thing.
We “know” F=ma, so if I push on something it will accelerate. Example, I lay a piece of plywood on the floor and stand on top of it. If the plywood has mass m and I have weight W then the piece of plywood accelerates downward at a rate a = W/m.
Same thing applies to a helicopter hovering in ground effect. If the helicopter has weight W and the air has mass m, then the air accelerates downward at a rate a = W/m.
Old Dec 21, 2012, 07:10 AM
Joined Oct 2007
If I paint a picture of a piece of plywood on the floor and stand on it -
Does the picture accelerate?
Just wondering -
Merry Christmas!
Old Dec 21, 2012, 12:54 PM
Ashtabula, OH USA
Joined May 1999
We're working on wing's reaction to the air - not the ground's.
Old Dec 21, 2012, 12:58 PM
Ashtabula, OH USA
Joined May 1999
Great - so therefore, the chopper will react with an equal and opposing force called lift.
Do you agree with the above statement?
If not - you clearly don't understand physics, particularly Newton's third law.
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Discussion Is there anything listed that you can't live without? P-51C Life, The Universe, and Politics 44 Aug 05, 2011 02:55 PM
Discussion Fast food that you just can't do without. Bilbobaker Life, The Universe, and Politics 101 Aug 17, 2010 11:30 AM
Joke What Would You do to get that Aircraft You Can't Have ? Chophop Humor 10 Feb 09, 2010 07:00 AM
Discussion HELPIf you have a problem that can't be solved here ccowboyearl Beginner Training Area (Heli-Electric) 2 May 14, 2009 12:31 PM
