Old Sep 18, 2012, 04:00 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
These exercizes are all well and fine but I fail to see their value in a model science forum.
richard hanson is offline Find More Posts by richard hanson
Old Sep 29, 2012, 12:03 AM
Crossplot is offline
Find More Posts by Crossplot
Joined Dec 2011
Sorry to to disrupt the train of thought here but I have a question pertinent to the theme of this thread.
First, we know that the flow around the wing does include downward mass acceleration equal to the lift. There is also a downward momentum aft of the wing that is approximatly equal to lift.
The question is, does anyone have accessto an authoritive source as to downwash beinga true reaction to lift?
A wing generates circulation which establishes the lift then is left behind as downwash.However, the "down" of downwash appears to come only from the mechanics of vortex pairs.
I cannot find anyway to rationalize the "down" of downwash to be a reaction to lift.
(Acknowlrdging Shoes admonition that one needs to understand the entire field)
Crossplot is offline Find More Posts by Crossplot
Old Nov 03, 2012, 06:27 PM
HX3D014 is offline
Find More Posts by HX3D014
t=1007606
HX3D014's Avatar
Joined Dec 2006
The lift formula contains an Acceleration Portion
Lift = Cl 1/2roh V^2 S
Force = MA
The V^2 is the Acceleration part
The CL is how well the sling shot works
1/2 roh is the size or the Shot (So to say) and the reaction (Opposite) to it
S is the # of sling shots or the surface area.
This is the old and still true to date formula for lift that involves reaction.
Though the Cl value is where we see the interesting Pressure functions, as is, CL as a # is almost a meaningless as to what is truly going on.
Sorry No Authority here
HX3D014 is offline Find More Posts by HX3D014
Old Nov 11, 2012, 10:08 PM
Joined Dec 2011
That is one way of looking at it. I see Cl as just a coefficient to trade the lift function with q and S as the variables.
In the F=Ma that lifts is from the accelerations the take place in the flow as it turns around the wing. So we are talking about the path of the flow as it passes the wing . The question being , is there any reason to believe that there is a downward component inherent in the basic flow aft of theTE? the predominent downwash that we see is created by the remnants of the creation of circulation.
Have a nice day .
Old Nov 12, 2012, 03:22 AM
ShoeDLG is offline
Find More Posts by ShoeDLG
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
How do we know this?
ShoeDLG is offline Find More Posts by ShoeDLG
Old Nov 12, 2012, 02:15 PM
HX3D014 is offline
t=1007606
HX3D014's Avatar
Joined Dec 2006
Because Every action has an Equal and Opposite reaction, and an object at rest or in motion will stay that way unless acted upon by an Extra force.
The tricky part is how some wings work to first allow/force the Air to Accelerate up before it is then Allowed to accelerate back down.
Crossplot That is one way of looking at it. I see Cl as just a coefficient to trade the lift function with q and S as the variables.
In the F=Ma that lifts is from the accelerations the take place in the flow as it turns around the wing. So we are talking about the path of the flow as it passes the wing . The question being , is there any reason to believe that there is a downward component inherent in the basic (?) flow aft of theTE? the predominent downwash that we see is created by the remnants of the creation of circulation.
yes, but the motion will quickly change to a vortex and the energy imparted to that air is Dissipated to heat through friction.
http://www.rcgroups.com/forums/showthread.php?t=1539175
Some good and Bad Information there
Old Nov 12, 2012, 05:42 PM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
So in order for a fluid to exert a force on an object (e.g. for the air to exert lift on a wing), the momentum of the fluid must change (at a rate equal and opposite the exerted force)?
Old Nov 12, 2012, 05:55 PM
HX3D014 is offline
t=1007606
HX3D014's Avatar
Joined Dec 2006
That about sums it up. But don't forget the Formula F=MA
If you increase the acceleration rate. You do not need as much mass. So different wing foils take advantage of this to get the same result.
PS
Got a bit lost with the Exerted and exerter. But for the wing to produce lift. The force has to be opposite to gravity, and that happens to be down. So there has to be some air that has had its velocity vector changed to something of a more Downward direction/vector.
Old Nov 12, 2012, 06:11 PM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
So if the momentum of a fluid must change in order for it to exert a force on an object, then when you're floating on your back in a swimming pool, you must be changing the vertical momentum of the water?
Old Nov 12, 2012, 06:28 PM
HX3D014 is offline
t=1007606
HX3D014's Avatar
Joined Dec 2006
Not quite. You are displacing the water and causing the total volume to increase. But what you are talking about is similar to a Hot air Balloon or Helium balloon.
http://en.wikipedia.org/wiki/Buoyancy
But if you were made of a material more dense than water you would need to work on the water to stay head above the water. (Like a skinny guy wearing a lead weight belt with out a wetsuit, or other buoyant devices)
Old Nov 12, 2012, 11:40 PM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
If the following statement is true:
"In order for a fluid to exert a force on an object, the momentum of the fluid must change."
How is it that the water can exert an upward force through buoyancy without its momentum changing?
Old Nov 13, 2012, 02:00 AM
HX3D014 is offline
t=1007606
HX3D014's Avatar
Joined Dec 2006
It has to do with the topic of lift/force, we are talking about lift of objects that are Heavier (Denser) than the Medium they are flying (With wings) in.
Or so I thought
Old Nov 13, 2012, 03:15 AM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
In the case of a lifting wing, you invoked Newton's Laws to suggest that the lift force exerted on the wing must be accompanied a change in the air's momentum.
In the case of a body floating in water, you seem OK with the idea that no change in the water's momentum is required for the water to provide an upward force.
Newton's Second Law says that an object's rate of momentum change is proportional to the unbalanced force acting on it.
In the bouyancy case, its obvious that the water in a pool doesn't experience an unbalanced force when you climb into the pool (the bottom of the pool will push up on the water with the same force that your weight pushes down).
You can write Newton's Second Law as it applies to a lifting wing:
Air's rate of vertical momentum change = Downard force exerted by the wing on the air - Upward force exerted by the ground on the air
Only in the case where the upward force exerted by the ground on the air is zero can you conclude that "the flow around the wing does include downward mass acceleration equal to the lift".
Neither people floating in pools nor wings are exempt from Newton's Laws. The same connection between forces and momentum exchange that exists in one case must exist in the other.
Old Nov 13, 2012, 06:16 AM
ciurpita is offline
Find More Posts by ciurpita
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
why is the above true?
while the pressure regions above and below the wing produce an upward force on the wing surface, don't they also exert a force on the air above and below the pressure regions. If the air displaces, then it is accelerated downward. But where would it displace too?
the air below the wing is blocked by air below it, and a vacuum would be created by the displacement of the air above the wing. The only place i can see it going is forward -- any air displaced below the wing movs forward and upward to fill in the vacuum left by the air displaced above the wing.
if true, then there would be little net movement of air if the air displaces (equal movement down and up). I don't understand why there wouldn't be displacement, but isn't that what the 2d theory suggests?
If so, why is there no displacement when there is a force applied to the air?
greg
looking for understanding
ciurpita is offline Find More Posts by ciurpita
Old Nov 13, 2012, 06:20 AM
HX3D014 is offline
t=1007606
HX3D014's Avatar
Joined Dec 2006
YES.
By the nature of the Wing it works that way (Unlike an Air Balloon)
Not talking about Buoyancy, without refreshing and further education on it on my behalf.
OK, I will talk a little.
That's a strange way of looking at it. But I agree that there is more Pressure on the pools bottom.
I can see that. No wait. Is that a minus ?
Not quite true, Its due to the Ground that there is Air Pressure of such a value, And because of the Ground, the Air will dissipate its energy into vortices and heat more quickly.
Can you blow a candle out from a distance of 15ft by Just blowing through a straw?
Its very hard to do (I doubt any one could), but to suggest that because the candle did not go out you did not blow any air in that direction is Presumptuous. The energy was dissipated
If you fly out of ground effect you are above the reaction time of air and ground and wing, and are needing more work to be done to the air than when you are in ground effect.
An aircraft is flying in a very tight turn (Bank Angle of close to 90deg).
Q/ Which way is the force vector that Caused it to change its Velocity vector.
A/ It's near Horizontal.
The horizon is not needed to be a wall or anything similar to what you are suggesting with the Ground and Lift.
It's the local air that was affected.
Of cause, This air being accelerated near Horizontally had energy added to it, but, it will dissipate and finally turn to heat before circling the earth. (may be even before getting close to the Horizon ?)
Bryce.
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Discussion Is there anything listed that you can't live without? P-51C Life, The Universe, and Politics 44 Aug 05, 2011 02:55 PM
Discussion Fast food that you just can't do without. Bilbobaker Life, The Universe, and Politics 101 Aug 17, 2010 11:30 AM
Joke What Would You do to get that Aircraft You Can't Have ? Chophop Humor 10 Feb 09, 2010 07:00 AM
Discussion HELPIf you have a problem that can't be solved here ccowboyearl Beginner Training Area (Heli-Electric) 2 May 14, 2009 12:31 PM
