Old Sep 15, 2012, 02:58 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
There is one (1) force on a fixed plate in a moving airstream, or a moving plate in a fixed airstream.
We can resolve that force into the directions of interest. The resolution of the force up (or down) perpendicular to the direction of the airstream we call Lift.
The resolved force in the direction of the airstream we call Drag. With a good combination of air flowing over the plate and area of the plate, the object in question will move. Restrained, as in a wind tunnel, the forces on the supports for the model can be resolved into the desired directions.. Up(or down) is called Lift, and (restrained by the support) in the direction of the airflow we call Drag.
Flying machines can make Lift with motion forward into an air mass, using a propulsion system to "thrust" it forward. And by cleverly making the flying machine light and stiff, with lots of area that is also cleverly designed to permit the machine to rise off the ground with sufficient forward motion, provided by the propulsion system.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Sep 15, 2012, 03:11 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Bear with me -
If I see the directions of all the arrows correctly-----
the highest pressure is under the plate -along the FORCE line and the lowest is above that plate -along that line.
The forces on the plate will change the relative direction ofthe FORCE line as speed and AOA change.
The other two may remain the same .
I am assuming the lift and drag arrows are relative to the drawing (left right /up down) not the wing or stream
It makes sense to me if that is the case.
richard hanson is offline Find More Posts by richard hanson
Old Sep 15, 2012, 03:47 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
THE force on the plate is resolvable into whatever frame of reference one desires.
Typically the lift force component is taken as perpendicular to the airstream, and the drag force component parallel to the airstream.
Wind tunnel balances do this force resolution so that the designer doesn't need to know the magnitude of the force on the object nor its direction relative to the object, and its sin or cosine when dealing with the design.
Makes things easier to compute.
It's possible to determine the angle of the object relative to the airstream and find that angle where there is only the drag component, with no lift.
A flat plate or a symmetrical airfoil that's usually when it's aligned with the airstream.
A cambered surface, the zero lift line is generally with a negative angle of attack... F'rinstance the zero lift angle for a Clark-Y or similar semi-symmetrical shape is about 4 degrees below level.
On an airfoil polar, it's where the Cl line passes through the angle of attack zero line.
There will always be drag with motion.
Old Sep 15, 2012, 04:57 PM
DPATE is online now
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
Originally Posted by ShoeDLG View Post
How could you leave out that in 2012 you learned that wings make lift by knocking air down? With that gem there isn't much need for any of the complicated stuff you wasted your youth on.
That would have been a sarcasm overload!
DPATE is online now Find More Posts by DPATE
Old Sep 16, 2012, 01:13 AM
ShoeDLG is online now
Find More Posts by ShoeDLG
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
This is certainly true, but as you point out, some choices are better than others. Why not define the lift force as the component of aerodynamic force acting perpendicular to the chord, and the drag as the component acting along the chord?
Seems like a pretty small and inconsequential shift from the traditional definitions.
The plot below shows CL and CD as a function of AOA for a rectangular wing with a Clark Y airfoil. The solid lines show the traditional resolution axes (perpendicular and parallel to the air flow). The dashed lines show the same force resolved perpendicular and parallel to the chord. The CL behavior doesn't change dramatically, but the CD behavior changes completely. In this coordinate system the "drag" has to become negative in order for the "lift" and "drag" components to sum up to the correct net aerodynamic force. I think we'd all agree that the traditional definition of drag far better captures the concept we are referring to when we say "drag".
ShoeDLG is online now Find More Posts by ShoeDLG
Old Sep 18, 2012, 11:22 AM
Texas Buzzard is offline
Find More Posts by Texas Buzzard
Texas Buzzard
Texas Buzzard's Avatar
McAllen,Texas
Joined Mar 2004
Where are the definitions that you use?
Originally Posted by DPATE View Post
By definition lift does no work. Drag does, lift doesn't.
Mr. DEPATE,
If you were writing a paper for a Philosophy class I suppose that your "definitions" would be called "apriori statements".
Using your way of explaining things is analagous to one saying that a
God caused the thunder storms and eclipses. One then has to ask what is your "first cause" that produces these effects/
I really am sorry that I am not communicating well to you. I will try for the third time.
If you simply say that an effect is truley factual BECAUSE A DEFINITION
SAID IT WAS leaves something to be desired. Give your authority for that definition.
For the second time you fail to answer simple questions that a grad student
in aeronautical engineering should easily answer. Are you a Social Science Major? I have a Masters in Chemistry with a Physics Minor attached. But hey, I have known practising Electrical engineers who can't solve ordinary problems in Static Electricity.
Texas Buzzard is offline Find More Posts by Texas Buzzard
Old Sep 18, 2012, 11:32 AM
Joined Oct 2007
Originally Posted by Texas Buzzard View Post
Mr. DEPATE,
Asking the same question over and over and getting the same results -- leads one to think that :
A- you are asking the wrong questions
B- you are asking the wrong person
C- You are speaking different languages.
I would love to see some of these guys in front of a jury and being asked to explain in simple understandable terms , "what is lift?"
Old Sep 18, 2012, 11:43 AM
DPATE is online now
Joined Oct 2010
It's D for David. Feel free to call me David.
Because we define lift to be the force perpendicular to the free stream velocity, and because a force acting perpendicular to the motion of a body does no work on that body, lift does no work.
Old Sep 18, 2012, 11:46 AM
ShoeDLG's Avatar
Joined Mar 2012
If you can't understand that the component of force acting perpendicular to an object's motion doesn't do any work on the object, then perhaps it's time to detach that Physics Minor.
Old Sep 18, 2012, 12:03 PM
Joined Oct 2007
OK---- try that on a jury----- Not disagreeing that it has validity. It simply is too much of a leap from basic question.
Been there
Old Sep 18, 2012, 12:25 PM
ShoeDLG's Avatar
Joined Mar 2012
I thought this forum was for discussing science. I shudder to think of where we would be if the litmus test for scientific merit was the appeal of an idea to a jury.
Old Sep 18, 2012, 01:06 PM
Joined Oct 2007
Science at what level?
it is a model form-
as for appeal to a jury-
You missed the point
It is what can you present that can be readily grasped by non technically oriented folk Not stupid - just not technically sophisticated .
I have likely noted it before but an old friend who was head of Enginering at a larg university told me that of a given graduating class , only about 10% of the degreed engineers were of much value as engineers .
I had brought up the subject because of the engineering crew I had foisted on me to do detail work .
Nice people -good at math -no good at innovative stuff
Old Sep 18, 2012, 01:18 PM
ShoeDLG's Avatar
Joined Mar 2012
The term "work" has a very specific meaning in Physics. The work done on a body is the force applied to a body times the displacement of the body in the direction of the applied force. It follows directly from this definition, that motion of the body perpendicular to an applied force will result in no work done by that force. You don't need to be technically sophisticated to grasp that.
Old Sep 18, 2012, 02:22 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
David / Shoe
You are truly wasting your proverbial breath. You know that you are right, I know that you are right. But no matter how you explain these most simple principles of basic physics (such as 'work') some people cant, or wont grasp it. Best just accept it and move on, it saves a lot of frustration all round.
Steve
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
And there's a very good reason for this definition. Forces perpendicular to the motion of the body do not alter the energy state of the body. Thus, they do no work. If this were not true, you could say goodbye to the study of dynamics and many other fields.
Montag DP is offline Find More Posts by Montag DP
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Discussion Is there anything listed that you can't live without? P-51C Life, The Universe, and Politics 44 Aug 05, 2011 02:55 PM
Discussion Fast food that you just can't do without. Bilbobaker Life, The Universe, and Politics 101 Aug 17, 2010 11:30 AM
Joke What Would You do to get that Aircraft You Can't Have ? Chophop Humor 10 Feb 09, 2010 07:00 AM
Discussion HELPIf you have a problem that can't be solved here ccowboyearl Beginner Training Area (Heli-Electric) 2 May 14, 2009 12:31 PM
