I could have been more clear. I meant you don't have to worry about the effect of gravity on the downwash/upwash. You do need gravity to require there to be lift in steady state level flight of course. You could consider the case of flight within a hollow sphere. No net gravity there, so you could go in straight lines but to turn you would need to generate lift. Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
The Willamette Valley, Oregon
Joined Dec 2008
(Edit May 2012-- my thoughts on this matter have now changed significantly-- I'm still convinced that the earth "feels" a downward push from the wing of an aircraft in flight, equal in magnitude to the weight of the aircraft, which is also equal to the upward gravitational attraction that the aircraft exerts on the earth, but I no longer believe that this downward force need involve any specific amount of downward momentum of the air (downwash). For more, see posts 58, 61, and 72. End edit.)
The plane doesn't "need" to make an earth-directed downwash in order to make aerodynamic lift, e.g. at the top of a loop, where the downwash is aimed upwards. But over the long run, the earth "needs" to feel the downwash, in order to not accelerate upwards under the gravitational pull from the plane. Thus, over the long run, lift is always accompanied by an earth-directed downwash, which exerts a downward force on the earth equal to the upward pull of the plane's gravity on the earth. A key point is that the plane is flying in small circles above a point on the ground, not circling the whole earth-- in the latter case the plane would not pull the earth upwards in any particular direction over the very long run. Steve |
Joined Dec 2008
I don't necessarily disagree with the idea that the downwash may be converted entirely into pressure, but I do think that this pressure must exert a net downward force on the ground. The downwash cannot be dissipated in some way such that it is never "felt" by the ground. Maybe when motion is converted to heat in the atmosphere, it always ends up increasing the pressure at the ground? Even though we are not increasing the weight of the air column above that point on the ground? I am not completely clear on this. (But see rudder example below-- sidewash from rudder must be dissipated in a way that is NOT ultimately "felt" by the ground.) Steve |
Joined Dec 2008
rudder etc
However, the original contention of this thread is that over the long run, the earth must "feel" a downward force equal to the upward pull of the plane's gravitational attraction on the earth. This certainly suggests that lift always involves some sort of downwash or pressure wave that will be tangibly "felt" by a nearby (or even very distant) surface, if there is one. A key point may be that the thought experiment of what force is "felt" by the earth's surface even if it is very very far below the plane, is fundamentally different than the thought experiment of what force is "felt" by a horizontal wall of finite dimensions that is very very far away from a deflected rudder. I'm not sure about this. For example does heating the atmosphere due to kinetic energy of downwash or sidewash end up increasing atmospheric pressure, which would be noted as downward force on the ground, but not noted as a sideways force on a vertical plate of (infinite?) dimensions at some great distance from a deflected rudder? But that doesn't make sense because that suggests that as the rudder's sidewash is dissipated, it heats the air, and to be consistent, we would have to say that that heating also pushes downward on the ground, just as does the heating from the wing's downwash. That doesn't make sense. So, I guess I am saying that in some way or other-- downwash, pressure, whatever-- the downwash from a wing does end up pushing down on the ground in a real, physical way, exerting (over the long run) a force equal to the plane's weight. Whereas a sidewash of the same magnitude (plane vertically banked and pulling one G, or deflecting a gigantic rudder to make a one-G sideload) is dissipated in a way that may ultimately heat the air or whatever but does not press down on the ground (does not exert a downward force on the ground). The argument is not fully fleshed out at this point but I'm sticking to my position! Remember the argument is based on conservation of momentum which we really can't dispute. It appears to me that the downward momentum of the downwash must indeed be conserved all the way to the ground in some form or another. Just saying that the downwash is ultimately disipated into heat doesn't cut it, because the same is true of the sidewash from the rudder, yet the ground needs to feel the wing's downwash, and the ground needs to not feel the rudder's sidewash, so something is fundamentally different about the way the ground feels the two effects. If we simply postulate that the momentum of the downwash (and sidewash) is conserved indefinitely (or at least until collision with a solid surface) even as we do other things along the way (like heat the air), then the riddle is solved I think. If the plane could somehow fly along in a straight line with the rudder deflected, continually shoving (sidewashing) air to one side, then we would have another conservation of momentum problem. But we don't-- because producing a net sidewash will always make the flight curve, so the direction of travel will not be a straight line. Considering the rudder issue has strengthened the case that the momentum of the downwash (or sidewash) is in fact conserved indefinitely as it passes through the atmosphere, for me at this time at least! Maybe the right word is not "momentum" but rather the "ability to exert force"-- including like a directed pressure wave (key word directed)-- is there such a thing? Is this just a form of momentum? I suppose so. Key point-- I'm talking about "the ability to exert force" on a very large object. Like the ground. Granted the area of the downwash increases , so the net downforce measured on a plate of some fixed size decreases, as we move the plate progressively further below/ behind the aircraft. Steve |
Trying to bring the earth's reaction into the mechanics of lift generation is nothing but a distraction. it won't help to understand what is going on in any meaningful way
I have a friend who always wants to bring Quantum mechanics into the discussion of physical phenomena. So from that perspective should we be analyzing lift from the point of view of Quantum electro dynamics? Or classical physics and use electromagnetics since it might be interactions between the shells of air molecules and those of the wing's atoms? You could spend a lot of time with any of these approaches, but none of them will help you to design wing sections, planforms, models etc. Pat MacKenzie FWIW the weight of the plane is continued to be felt as pressure on the earth, much like a fish in a tank adds to its weight whether it is swimming or resting on the bottom. All it has to do to do this is increase the average air pressure by a tiny amount since the surface area the pressure acts on is so huge. |
Joined Dec 2008
Keep in mind that we are staying within the confines of classical Newtonian mechanics here.... surely a worthy subject for "Modelling Science".... Steve |
Joined Dec 2008
Yes I certainly agree the effect is very dispersed. |
Steve,
OK - so let's go back to an earlier example: The downwash angle is determined by the coefficient of lift Cl The Cl is determined by the angle of attack Lift then is proportional to velocity squared v Using a flat plate section at an angle of attack A and some area S set v so the lift is 20 lbs Now double the chord of the wing at the same angle of attack and velocity The downwash angle and velocity will remain the same because the Cl and v have not changed However twice the chord will produce twice the lift from the same amount and angle of downwash If lift was in anyway dependent on downwash the downwash would have to have doubled or changed it's angle Tom |
Tom -- Bruce, I can't believe that you guys continue to take part in this silly discussion.
Downwash - sidewash - upwash - dragwash - propwash --- all are the effects - the result - of aerodynamic forces, not the cause of them. Momentum is conserved in a closed system - so if you fly your helicopter inside a box there is no net force on the system. Not so in an open system - an aircraft in flight is an open system, - so the aerodynamic forces on the aircraft produce local downwash - upwash - sidewash dragwash propwash - jetwash ad nauseum ![]() yak yak yak yak -- this thing must have gone to about sixty pages of just trolling and blather. --- almost as bad as downwind turns. unsubscribed again |
| Thread Tools | |
| Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? | TDboy | Hand Launch | 5 | Apr 21, 2012 02:26 AM |
| Discussion Is there anything listed that you can't live without? | P-51C | Life, The Universe, and Politics | 44 | Aug 05, 2011 02:55 PM |
| Discussion Fast food that you just can't do without. | Bilbobaker | Life, The Universe, and Politics | 101 | Aug 17, 2010 11:30 AM |
| Joke What Would You do to get that Aircraft You Can't Have ? | Chophop | Humor | 10 | Feb 09, 2010 07:00 AM |
| Discussion HELPIf you have a problem that can't be solved here | ccowboyearl | Beginner Training Area (Heli-Electric) | 2 | May 14, 2009 12:31 PM |
