Old Mar 09, 2012, 12:55 AM
eazyA is offline
Find More Posts by eazyA
Joined Mar 2012
Question
Syma s800 Battery Upgrade
Hey, just got the Syma s800 after having the s107 for a couple weeks. Noticed the battery on the s800 and the s107 appear to be the same, both say "3.7 V 150mAH" The battery from the s800 also says "651723HP." And the s107 also says "Fullymax" and "1J07FDQ17E." There is also a K next the the 3.7V on the s107 battery.
Thats a lot of information but I also saw there is a curcuit board on the batteries, I was wondering if they would make a standard s107 upgrade battery(200mAH one) incompatible with the s800.
My question is can I use the upgrade battery for the s107, the 200mAH on amazon, as an upgrade for the s800 too.
Also, would this work for the s800? And would it be better or too heavy? Thanks http://www.amazon.com/gp/product/B00...00_i00_details
eazyA is offline Find More Posts by eazyA
Old Apr 12, 2012, 12:52 PM
Turin is offline
Find More Posts by Turin
Joined Feb 2012
Should work with every batery aslong as the voltage is the same.
Turin is offline Find More Posts by Turin
Old May 20, 2012, 04:19 PM
SymaBayRC is offline
Find More Posts by SymaBayRC
Joined May 2012
Syma S107G UPGRADE Battery 240mAh 3.7V 30C
The 240mAh is the recommended battery upgrade by Syma.
I sell them but am out of stock right now, they are stellar batteries, received tons of great feedback from them! I have a website dropping soon http://www.symabayrc.com/ & have some things on eBay http://myworld.ebay.com/cnote4 but are higher in price due to their fees...
That 200mAh is going to be too heavy. I tried those and it adds a slight amount to it, but nothing like the 240 which is actually lighter and smaller than the 240mAh.
Hope this helps you and anyone else wondering the same!
SymaBayRC is offline Find More Posts by SymaBayRC
Old May 20, 2012, 07:16 PM
SubtleT is offline
Find More Posts by SubtleT
Vroooom putta putta putta
SubtleT's Avatar
Joined Feb 2011
Er, it just confused me.
It sounds like you are saying that the 200 sold on Amazon is too heavy, but you have a 240 (that may or may not be available?) which is significantly lighter than that 200.
SubtleT is offline Find More Posts by SubtleT
Old May 24, 2012, 07:51 PM
Joined May 2012
You got it. The 200 is compatible but not an upgrade.
http://www.symahelicopters.com/Syma-...-19-240mah.htm
$15 is a bit much, I will have them for about 1/3 that price! I am out of stock because they are an extremely good seller, they make 240mAh's that are heavier and larger, equivalent to the 200mAh size, slightly different types.
The 240mAh's I get are about the same size as the 150mAh's, which are the correct type.
Thanks, hope i cleared up some confusion.
Old May 24, 2012, 08:44 PM
SubtleT is offline
SubtleT's Avatar
Joined Feb 2011
That helps. So you get some 240s that fit well, surely they weigh more though don't they? Must mess up the trim a bit.
Help! Syma S107 battery upgrade chemikal99 Coaxial Helicopters 338 Feb 25, 2014 11:15 AM
Help! JXD 342 Battery Upgrade suggestions Tutexx Micro Helis 1 Mar 20, 2012 06:21 PM
Discussion Syma S107/G, up the mAh, battery upgrade? oneballjay Coaxial Helicopters 7 Nov 25, 2011 09:33 PM
Discussion Upgrade from Syma s107 oyacteen Scratchbuilt Indoor and Micro Models 22 May 06, 2011 09:07 PM
Question Syma S.026 7.4v li-po upgrade? dragon56 Micro Helis 2 Feb 22, 2010 05:11 PM
