Zooka's Super Cub Build Log
That’s right, yet another Super Cub build!
![]() My goal is to build a multipurpose supercharged cub that will be a blast to fly and meet/exceed all of my current needs. I dig the idea of having a speedy semi-acrobatic cub that I can also use to haul around my GoPro 2 without feeling loaded down. As some of you may recall from my research thread I’ve really enjoyed my stock cub, and even though I know there are planes out there that can meet my needs at a lower cost the thought of building a “Super” Cub sounds like too much fun to pass up. Components: • Motor: Brushless Eflite 480 910 KV... I went with the 910 over the 1020 for the additional thrust over speed, not that it likely matters much given how close these two motors are but with the additional weight of the components I plan to carry at times this seems like the best choice. http://www.e-fliterc.com/Products/De...rodID=EFLM1500 ![]() • Motor Mount: Custom RC Mount for eflite 480 BL’s. Almost too easy! Love this thing. http://www.customrcparts.com/index.p...products_id=17 ![]() • ESC: 40 amp Eflite ESC. http://www.e-fliterc.com/Products/De...rodID=EFLA1040 ![]() • Receiver: Spektrum 6210 http://www.spektrumrc.com/Products/D...odID=SPMAR6210 ![]() • Servos: 6x HS55’s http://www.hitecrcd.com/products/ana...ini/hs-55.html ![]() • Battery: Probably the Gens Ace 2200mah 11.1v 25c lipos as I have 6x on hand from my 450 helis. http://www.gensace.com/epages/genspo...-25C-2200-3S1P ![]() • Prop: TBD… I plan to try several out to find the sweet spot once the rest of the build is complete. Mods: 1. Standard SC mods such as hobby stick wing supports, gear supports, gear mods w/dubro wheels and rudder wheel, strut mods, divided fuselage compartment and a modified battery box to name the bulk. 2. Flattened wing with ailerons and flaps (planning on going with the large flap and smaller aileron). 3. Full length carbon spar in the wing for added strength and to finalize flattening of the wing. 4. Carbon fiber supports for the tail as an safety measure. 5. More to come. I hope to get started on the build this weekend. I’ll be sure to document my progress with photos and videos and the like. I have learned so much from build logs and hope that someone else can learn by my successes and failures as well. Thanks very much to NFZ and others who gave me some guidance on build ideas. ![]() ~Zooka |
Thanks for the info, Don. I did try my wife's hair dryer for several minutes but it didn't seem to be doing much. Maybe I just need to give it a little more time. I still plan to use the spar because I've heard horror stories of cub wings snapping on takeoff and dives with the force of brushless 480's, but if I can get the wing flat prior to cutting I'll feel better about the whole thing.
Should be an exciting day tomorrow! Most of my parts have arrived so I should be able to get a lot of work done if I make it a priority. I'm still waiting on two servos and some y-harnesses and extensions. Other than that we're good to go. |
Dillingham, Alaska
Joined Jan 2010
Moisture helps kick off the GG though excessive water causes a lot of foaming!
Also, a little bit of GG goes a long way.Wiping down the spar with a damp towel will only spread a bit of water down the entire length and will help glue setup. Just the hint of moisture (not dripping wet!) will be enough. ![]() -Mike |
Joined Feb 2012
All right, time to get to work!
I decided to use a soldering iron to carve out a channel in the foam by cutting a spare tip to the proper length and using a metal ruler as a guide. Credit to sdparkflyers.com and this vid.
I used a speed square and a pen to get a perfect line across the wing 1.5 inches from the leading edge. I used my Proxon rotary tool to cut a soldering iron tip to 5mm in length - the width of my CF spar. I thought I was going to have to make two passes with the hot iron to achieve the proper channel width because my spar is 5mm wide and the soldering tip is 3mm wide, but the 3mm tip ended up making a perfect 5mm channel! ![]() I'm glad I didn't try using a thicker tip as the channel would have been way too wide. ![]() The spar is sitting flush with the underside of the wing so I'm ready to glue this sucker in there. I've decided against the gorilla glue due to the unpredictability of expansion, so instead I'm going to coat the spar with a bit of epoxy and let it set. When the rest of the wing work is complete I plan to cover the spar channel with a strip of monokote. I'll report back shortly!
| Thread Tools | |
| Build Log Guillow's piper super cub build | tanner331 | Scale Electric Planes | 26 | Jan 13, 2013 04:45 PM |
| Build Log Dynam 4Ch Super J3 Cub PA-18 build and maintenance log | DragonDemiGod | Beginner Training Area (Aircraft-Electric) | 3 | Apr 23, 2012 10:45 PM |
| Discussion First Build, DHC-2 Beaver or Super Cub 25e? | Alaskan Flyer | Beginner Training Area (Aircraft-Electric) | 1 | Nov 08, 2011 05:50 PM |
| Question Super Cub build question | rcp123 | Beginner Training Area (Aircraft-Electric) | 7 | Nov 04, 2011 07:17 AM |
| Ami's super cub build! | warbird flyer | Parkflyers | 25 | Aug 18, 2004 07:28 PM |
