Old Mar 12, 2012, 07:07 AM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Which part of the wire do you find breaks on quad impact? Do you mean the stator lead wires coming off the coils into the 3 main lines? If so, I always epoxy at that joint, had a several motors fail there.
What size lipo do you think would work well with this setup on the 1811 2000kvs? I have 2 460 3s coming from another order. I was thinking some of these 950 2s. They're both around 45g.
Do you have a link to those cat's meow 3 blades?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Mar 12, 2012, 07:50 AM
scousethief is online now
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
The windings as they exit the stator are particularly weak and need reinforcement of any kind as that is preferable to none , i have had 2 go faulty inside the winding after a hard landing , out of a total of 12 motors i have 2 with bad bearings 4 on the quad 2 spare and the other 4 have had bumps were the winding has broken.
I use 950mah nanotech 2 cell or 1000mah 3 cell zippy on a bambucopter with a flying weight of 226.2g using 2 cell and 269.6g using 3 cell, either setup has more than enough power.
http://flyduino.net/5030-3-bladed-Pr...-2-CCW-B-Grade
Best blades ive had so far , im sure there are many other retailers but i would shy away from HK in blades this size. I have 4 sets of HK's new blades on order that were despatched today thats 12 of the red and 12 of the black so i will see for myself if they are any good , it makes no real difference as i use those gemfan but its always handy to have spares and at the price like their other 5x3 blades if theyre bad i will just throw them in the bin.
scousethief is online now Find More Posts by scousethief
Reply With Quote  (Disabled)
Old Mar 12, 2012, 10:58 AM
LEE KWANG HO is offline
Find More Posts by LEE KWANG HO
EPP RC
LEE KWANG HO's Avatar
Joined Jun 2009
Micro Quadcopter (2 min 26 sec)
indoor flying with epp guard .
LEE KWANG HO is offline Find More Posts by LEE KWANG HO
Old Mar 12, 2012, 03:33 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Originally Posted by LEE KWANG HO View Post
http://youtu.be/cv5O4HECZV4
Good idea, get HK to stock EPP guard kits.
Erknie is offline Find More Posts by Erknie
Old Mar 12, 2012, 04:34 PM
Rifraf is offline
Find More Posts by Rifraf
United States, CO, Golden
Joined Aug 2011
Just ordered, going to use FreeFlight FC with TC's multiwii load. Should be fun for around the house.
Rifraf is offline Find More Posts by Rifraf
Old Mar 12, 2012, 06:33 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Just ordered one. Cannot wait for it to get here!
3d astronaut is offline Find More Posts by 3d astronaut
Old Mar 12, 2012, 08:56 PM
dmize is offline
Find More Posts by dmize
United States, OH, Cleveland
Joined Feb 2010
what motors is everyone settling on?
dmize is offline Find More Posts by dmize
Old Mar 12, 2012, 09:25 PM
Erknie is offline
Joined Nov 2011
Something around 2900kv on 2S, like the Turning 1811 or the C10. That's with 2 blade 5 x 3 props, 3 blade might bog those down a bit. I am not sure if you can get 6 x 3 onto the frame, have to wait until mine turns up to test it.
HK seem to be out of stock of 2900kv motors.
There is a nice Hacker 2900kv Hacker A10-12S - 2900kv
You can also use a 2000kv motor with a small 3S battery, just make sure you don't fry the ESC.
Old Mar 12, 2012, 09:31 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
I am putting Avroto's on
just kidding Suppo 1510. That is what have at the moment.
NaterPin is offline Find More Posts by NaterPin
Old Mar 13, 2012, 04:29 AM
jaccies is online now
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
[QUOTE=LEE KWANG HO;21011540
indoor flying with epp guard .[/QUOTE]
Lee nice EPP guard, where can we buy it?
jaccies is online now Find More Posts by jaccies
Old Mar 13, 2012, 07:20 AM
Expat
Japan
Joined Apr 2010
Ya, that EPP guard would make the set complete. Real nice. It would be difficult to make yourself.
With those motors, does the lower KV just mean they put less windings on it? I have several BW 1300 and 1500kv motors, and I swear they used all the same parts, just wound less wires on the 1300kv. The 1300 doesn't have more torque or can push a bigger prop, just less power in the top end. So the 1500 seems a better overall motor, and only like 2 grams or something heavier.
Are these small 1811 motors the same situation? The higher the KV the better and just watch your throtle if you feel its overheating?
Old Mar 13, 2012, 04:17 PM
Erknie is offline
Joined Nov 2011
Yes, the windings determine the kv of the 1811 motor, the higher the kv the smaller props and higher revs you have to use. I wouldn't go over 2900kv on this frame, I don't think the 3800kv version would be very good due to a lack of decent props smaller than 5x3. The 2000kv on 3S or the 2900kv on 2S seem to be optimal.
Old Mar 13, 2012, 06:04 PM
Expat
Japan
Joined Apr 2010
Is there no advantage to either 2 or 3s as long as the kv match up?
As a side, why not for example buy the 3800 with the 5x3 on 2s and set your tx throtle to cap at 75%?
Old Mar 13, 2012, 06:37 PM
Erknie is offline
Joined Nov 2011
2S is 33% lighter than 3S for the same mAh, that can be significant.
The 3800kv won't work with 5x3, too much drag, it will just overheat. It even gets hot with a GWS 4530 prop.
Old Mar 14, 2012, 06:40 AM
BGauweiler is offline
Find More Posts by BGauweiler
United States, WI, Holmen
Joined Aug 2003
+1 on the EPP guard... Any interest in selling a few Lee?
B.
BGauweiler is offline Find More Posts by BGauweiler
Question Can i remove integrated esc bec (turnigy plush) Axefly Power Systems 12 Dec 28, 2014 01:19 PM
For Sale Micro Quad (9") + Parts for a new micro quad (ESC's + motors) ed.ge Aircraft - Electric - Multirotor (FS/W) 8 Jan 17, 2012 04:41 AM
Discussion cute UM quad :) - the flying PCB axelen Scratchbuilt Indoor and Micro Models 10 May 05, 2011 06:33 PM
For Sale Tri-Quad controller PCB populated EnigmaSoar Aircraft - Electric - Helis (FS/W) 3 Apr 15, 2011 06:13 AM
Sold TriCopter / Quad PCB's (3) EnigmaSoar Aircraft - Electric - Helis (FS/W) 2 Mar 21, 2011 04:41 PM
