Old Jan 17, 2013, 04:04 PM
sidneylopsides is offline
Find More Posts by sidneylopsides
Leeds, UK
Joined Dec 2003
I'd have thought the 2700kv would be better than the 2100? They are a bit heavier than the Turnigy ones, and need a 10A esc.
sidneylopsides is offline Find More Posts by sidneylopsides
Old Jan 19, 2013, 07:07 AM
Leeds, UK
Joined Dec 2003
http://pages.ebay.com/link/?nav=item...d=250966008641
These look ok, shaft comes out both ends though which seems odd.
Old Jan 24, 2013, 01:56 PM
Stenkryparen is offline
Find More Posts by Stenkryparen
Get Airborne
Sweden, Skåne County, Hofterup
Joined May 2012
Yesterday my Turnigy quad arrived.
  • Mounted receiver
  • Reversed two servo settings in transmitter
  • Zero adjusted stick input
  • Mounted props
  • Atached 950 mAh battery
  • Armed
Maiden flight was successful and very pleasant.
Stenkryparen is offline Find More Posts by Stenkryparen
Old Jan 24, 2013, 05:30 PM
stevo0476 is online now
Find More Posts by stevo0476
België, Vlaams Gewest, Brugge
Joined Sep 2011
Originally Posted by dang View Post
How's that kit working out for you?
The Rx site is working but I ruined the Tx side of the FPV set, sloppy soldering caused a short circuit (my fault). I worked to fast and sloppy and that 's never a good idea with micro size electronics . Lesson learned the hard way....I'm waiting for a new Tx I ordered I guess I'm back to square one.....Oh well it's a hobby ;-)
Cheers
Steve
stevo0476 is online now Find More Posts by stevo0476
Old Jan 25, 2013, 07:44 AM
Get Airborne
Joined May 2012
Is it possible to view what version of firmware loaded in the FC (KK2), from the LCD screen?
Old Jan 25, 2013, 07:52 AM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
Mine shows the version on power up. But then I'm on V1.4, so I'm not sure if that was added later.
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Jan 25, 2013, 08:04 AM
Get Airborne
Joined May 2012
Si.
Thanks for quick answer, I have a look.
Old Jan 25, 2013, 08:26 AM
Get Airborne
Joined May 2012
Don't see it when power up, then I have firmware < 1.4.
Old Jan 25, 2013, 08:29 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Si.
All kk2.0 board from firmware 1.1 show the firmware version at start up ...
But HK may put on the board their customozed firmware ... Mr KK has no control on it
For be sure ... update to 1.5 ... older firmware is not as good as latest one
e_lm_70 is offline Find More Posts by e_lm_70
Old Jan 25, 2013, 08:51 AM
Get Airborne
Joined May 2012
I will update, but have to buy or borrow the needed adapter.
Old Jan 25, 2013, 09:25 AM
dang is online now
Find More Posts by dang
USA, WA, Olympia
Joined Jan 2001
Cheers
Steve
Thanks for the report and being a beta tester for us! Stuff happens, good luck.
Dan
dang is online now Find More Posts by dang
Old Jan 25, 2013, 04:33 PM
Get Airborne
Joined May 2012
Sorry I was not awake, KK2 board shows version 1.2 direct after power up.
New question.
Default was "Self level settings":
Gain 40
Limit 20
and it was hard (almost impossible) to take off, when self leveling was "ON".
Changed to :
Gain 20
Limit 10
and the bird flies great when Self leveling is "ON".
What adjustment settings is recommended and works good for a newbie?
Also wired the voltage alarm and connected a piezo buzzer. The buzzer was desoldered from a cheap voltage alarm board. I think its big and heavy 1,5gram.
Is there any tiny and light weight buzzers to buy.
Old Jan 27, 2013, 05:18 PM
rickgode is offline
Find More Posts by rickgode
I'm just a 2.5D Pilot
rickgode's Avatar
Fort Worth, TX
Joined Dec 2005
I hate you...
I still can't get mine going. I got a new motor and new esc but now I'm 99% mine is vibes... I rotated the landing gear so that I could use the foam standoffs in the corners. And I was able to get about 1 minute flights until the right front motor this time would seem to cut out. Then after that it was just wobbly.
I've balanced the props and can still feel vibes and at certain RPMs it looks like the prop is fluttering (kinda like poor tracking in a heli)
If I hold the little quad I can feel vibes and the motors cut in and out, but if i grip the quad tightly, the motors get in sync and sound really good.
I noticed that one of my props had a pretty good nick in it, so I changed it out with a brand new balanced one... Now it is worse and I can't even get it off the ground...
This is killing me.
Ricky
rickgode is offline Find More Posts by rickgode
Old Jan 27, 2013, 08:10 PM
dklein is offline
Find More Posts by dklein
The geek in Rotorgeeks
Canada, ON, Toronto
Joined Oct 2011
[QUOTE=rickgode;23950398]
/QUOTE]
maybe worth a shot - when I received mine, one of the motors was not moving smoothly and was intermittent because it was binding. Turned out the c-clip wasn't sitting properly on the shaft. Maybe try removing the clip, pulling the shaft out and refitting it.
dklein is offline Find More Posts by dklein
Old Jan 27, 2013, 08:11 PM
dklein is offline
Canada, ON, Toronto
Joined Oct 2011
Question Can i remove integrated esc bec (turnigy plush) Axefly Power Systems 12 Dec 28, 2014 01:19 PM
For Sale Micro Quad (9") + Parts for a new micro quad (ESC's + motors) ed.ge Aircraft - Electric - Multirotor (FS/W) 8 Jan 17, 2012 04:41 AM
Discussion cute UM quad :) - the flying PCB axelen Scratchbuilt Indoor and Micro Models 10 May 05, 2011 06:33 PM
For Sale Tri-Quad controller PCB populated EnigmaSoar Aircraft - Electric - Helis (FS/W) 3 Apr 15, 2011 06:13 AM
Sold TriCopter / Quad PCB's (3) EnigmaSoar Aircraft - Electric - Helis (FS/W) 2 Mar 21, 2011 04:41 PM
