Old Mar 08, 2012, 03:48 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Originally Posted by Erknie View Post
I don't mind the design, everything seems well protected. Not sure about ESC airflow.
You could try the board upsidedown so the ESC would get more air. Like Flitelab, I would use 10amps
NaterPin is offline Find More Posts by NaterPin
Old Mar 08, 2012, 03:52 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
What sort of glue would you use to assemble it?
I suspect just some CA. All it does it hold the sides and top frame in place, nothing really with any force/load on it.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Mar 08, 2012, 04:13 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Yeah, I think 10A are the go. The 1811 motors they suggest, really need to run on 3S. Those 5 x 3 props like to spin at 20,000rpm for reasonable thrust, so you would need at least 2,500kv on 2S to get up to those kind of rpms.
Warthox running 3S on the Turnigy 1811 motors:
mwc quad // flydumini (2 min 9 sec)
Erknie is offline Find More Posts by Erknie
Old Mar 08, 2012, 04:18 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
I use the Suppo A1510-15 2200kv on all my micros with 2S, works great. That is with 5X3X3 props. Plan to use same setup on this as well.
Site Sponsor
Old Mar 08, 2012, 06:09 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
looks like a really neat little frame. had to make a small order from HK anyway today, so ordered one to try.
tc3wins is offline Find More Posts by tc3wins
Old Mar 08, 2012, 06:28 PM
Erknie is offline
Joined Nov 2011
It's interesting to note the 5 x 3 props they recommend for the 1811 motors, 2mm press fit it looks like:
http://www.hobbyking.com/hobbyking/s...ropellers.html
Will press fit stay on well enough?
I also noticed that the 1811 motors they are suggesting are the 2900kv ones, not the usual 2000kv so that means 2S will be just fine with those and 5 x 3 props.
Old Mar 08, 2012, 06:29 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Can't imagine press fitting a prop. Not sure how they intend to mount them. I use the GWS/GF 5x3x3 props which fit with the A1510 motor prop adapters.
Site Sponsor
Old Mar 08, 2012, 06:59 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
I have the little infinity hobby quad with 92mm propellers that press fit onto the 2mm shafts of the motors. I was a bit sceptical but have had no problems as yet.
kaz1104 is offline Find More Posts by kaz1104
Old Mar 08, 2012, 08:22 PM
Erknie is offline
Joined Nov 2011
I guess if the props start slipping when press fit to the 2mm shaft, it's no big deal to drill them out and put them onto prop savers/adapters which come with the recommended 1811 2900kv motors. I do like the red prop color, should make it easier to figure out which way the micro-quad is pointing
Old Mar 09, 2012, 03:00 AM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
No chance , after unfortunatley being in receipt of over 100 of HK's 5x3 blades i would rather stab myself in the eye than use them again , very very badly balanced, brittle and fragile ive also had some detonate in the air they were on 2 cell and 2000kv 1811 motors, and press fit ? ill leave someone else to spend their money first this time.
scousethief is offline Find More Posts by scousethief
Old Mar 09, 2012, 04:01 AM
Erknie is offline
Joined Nov 2011
I would suggest comparing the 5 x 3 blades you used to the photo above before you jump to concusions. I doubt they are the same, I have been using HK 5 x 3 for many months and I have never seen these before.
Old Mar 09, 2012, 04:06 AM
Henni is offline
Find More Posts by Henni
vAMPire
Germany
Joined Aug 2010
Exactly my feelings, thoose HK 5x3 are just Garbage but Im still using them since there are not so many alternatives. Are thoose 5x3x3 GWS 3 blades much better?
Henni is offline Find More Posts by Henni
Old Mar 09, 2012, 04:31 AM
Erknie is offline
Joined Nov 2011
Why do I feel I am banging my head against a wall!
These are the 5 x 3 HK props you would have used.
These are the new ones made for the Turnigy micro-quad.
If you don't see they are not the same props, then I can't help you.
Old Mar 09, 2012, 05:46 AM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
They look much better than the garbage 5" props however I bet they are heavier. A small price to pay for better quality props. I have been waiting for some decent 2 blade 5" props.
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Mar 09, 2012, 05:47 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Originally Posted by Z06 Tony View Post
Can you post a link for these props? They look much better than the garbage 5" props however I bet they are heavier. A small price to pay for better quality props. I have been waiting for some decent 2 blade 5" props.
http://www.hobbyking.com/hobbyking/s...s_per_bag.html
Site Sponsor
Question Can i remove integrated esc bec (turnigy plush) Axefly Power Systems 12 Dec 28, 2014 01:19 PM
For Sale Micro Quad (9") + Parts for a new micro quad (ESC's + motors) ed.ge Aircraft - Electric - Multirotor (FS/W) 8 Jan 17, 2012 04:41 AM
Discussion cute UM quad :) - the flying PCB axelen Scratchbuilt Indoor and Micro Models 10 May 05, 2011 06:33 PM
For Sale Tri-Quad controller PCB populated EnigmaSoar Aircraft - Electric - Helis (FS/W) 3 Apr 15, 2011 06:13 AM
Sold TriCopter / Quad PCB's (3) EnigmaSoar Aircraft - Electric - Helis (FS/W) 2 Mar 21, 2011 04:41 PM
