Old Mar 08, 2012, 04:29 AM
neo__04 is offline
Find More Posts by neo__04
Australia, VIC, Warrnambool
Joined Feb 2012
Help!
Buying FPV gear.. need advice on initial setup
Hey all,
Getting myself setup in the world of FPV.
Purchased a few bits and pieces based on recommendations on these forums. See below...
- Eurgle 9x controller, frsky module with telemetry
- 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera OSD Menu 2.8mm lens
- Sunsky 1.2GHz 800mW 8 Channel Digital Wireless AV transmitter &
receiver
- PL8006 Portable 8" Color LCD Monitor TV w/ YPbPr + VGA Input
I have a few questions.
1. What am i suppose to get in the way of a low pass filter to stop any problems with 2.4ghz controller and 1.2ghz video tx?
2. What size lipo would you recommend to run the video tx on the plane?
Do i need any voltage regulators here?
3. What size lipo would you recommend to run a ground station with the parts listed above, also do i need a voltage reg with recommended battery?
4. Also can anyone recommend a good cheap OSD to get me started?
Just trying to work it all out and get everything ordered so i dont try and set myself up and have parts missing that i overlooked.
Thanks heaps!
neo__04 is offline Find More Posts by neo__04
Old Mar 08, 2012, 03:44 PM
neo__04 is offline
Joined Feb 2012
bump bump.. I would have thought these were easy questions for you pros out there :P
Old Mar 08, 2012, 05:01 PM
alexedit is offline
Find More Posts by alexedit
alexedit's Avatar
United States, FL, Miami
Joined Dec 2008
check out this OSD
http://www.urbandrones.com/Urban-Dro...cker_p_36.html
an 800mah lipo should be sufficient to power the camera and tx
Low pass filter
http://www.urbandrones.com/13ghz-low...nce-_p_88.html
use the website contact page and you will get any other questions answered.
alexedit is offline Find More Posts by alexedit
Old Mar 08, 2012, 05:12 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
I just bought my FPV equipment, too. I actually invested a bit more in the OSD.. I initially had the same thought as you and go cheap for the first but "cheap" is still around $1000 and I spent a bit more in a reliable OSD with RTH, so I went for the DragonOSD...
Attached is my list of components.
I am using the x9 with FrySky as well, but for the VideoLink I am going for 5.8GHz.
I also prepare my FPV plane for night flying (most of my planes are) with anti-collision light since we are close to an airport here (about 5mls away).
Also I ordered a military dog tag with my phone number on it which I will mount inside the fuselage, in case it get's really lost and some finds it. Actually I think it's part of the regulations here in the US.
Hope that helps.
flyandi is offline Find More Posts by flyandi
Last edited by flyandi; Mar 08, 2012 at 05:24 PM. Reason: Forgot to add some components that I got yesterday. Check ZIP.
Old Mar 08, 2012, 05:34 PM
neo__04 is offline
Joined Feb 2012
cool thanks for the replies.
I was thinking of a cheap OSD because i have an Ardupilot Mega 2 on its way and was just going to get the osd for it.
As far as i know the APM2 has RTH and all those sorts of functions, so is there any advantage of a dragonlink vs APM2 with OSD for non uav flying?
Thanks again
Old Mar 08, 2012, 05:44 PM
flyandi is offline
Joined Aug 2009
The only thing is that DragonOSD is extremely reliable from what I heard and read. I probably will get at one point the APM2, too. But for now I am more interested to get a working setup and get some good experience before I start tinkering with components.
Old Mar 08, 2012, 05:53 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
If you are new, then why are you even bothering with RTH? RTH is a horrible idea for a new pilot. Skip the auto pilot for at least 100 flights.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 08, 2012, 06:07 PM
neo__04 is offline
Joined Feb 2012
Absolutely agree, have plans for quadcopters etc in the future and the apm2 are on a masive backorder, so i ordered one just to get in the queue.
This is why im trying to work out what OSD to use, because the apm2 is another project down the line. Most likely after 100 flights.
I have pretty much ordered all the fpv running gear, just have the OSD to work out.
Old Mar 08, 2012, 06:26 PM
flyandi is offline
Joined Aug 2009
Oh I agree - doesn't make really sense to use RTH/Autopilot since you flying 300ft around yourself for the first couple times, but once you feel comfortable you want to go a little bit further and even only to save your investment you want a reliable RTH. If you don't have it, you probably going to end up buying it anyway. Why not saving $100-$200 and have it right from the get-go. Doesn't mean you have to use it. Just my .02 cents.
Old Mar 08, 2012, 06:32 PM
neo__04 is offline
Joined Feb 2012
So would the dragonlink osd2+ be the choice of most?
Old Mar 08, 2012, 06:46 PM
flyandi is offline
Joined Aug 2009
I was reading a lot about OSD and I decided between the Nova ($150) and the DragonOSD ($215) ... in the end I went to the DragonOSD since it has a very good reputation amongst FPV'ers, 4 Channel RTH, 20 Waypoint Autopilot and 6000 points recorder. Also I like the different customizations you can do with the DragonOSD.
The NOVA OSD is a bit cheaper and has a two-channel (Aileron/Elevator). The Nova is a very good OSD and it comes with a more and less reliable RTH, has a very clean OSD layout and doesn't need a lot of configuration.
However I know that at one point I want to use the autopilot and GPS recorder and spent the extra bucks for the DOSD.
Old Mar 08, 2012, 07:00 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
Thanks again
Ardupilot has an OSD available that integrates with Mavlink.
vertcnc is offline Find More Posts by vertcnc
Old Mar 08, 2012, 07:30 PM
neo__04 is offline
Joined Feb 2012
again, thanks for all the replies.
The only question unanswered is can anyone recommend which lipo and rating to use for a ground station with the parts listed in the original post.
Thanks heaps!
Old Mar 08, 2012, 08:18 PM
vertcnc is offline
Illinois, USA
Joined Aug 2009
I am sure you would be good with 5000 mah. But I would put a meter on the power leads and see how much it uses. RX and related components don't draw much.
Old Mar 08, 2012, 09:13 PM
flyandi is offline
Joined Aug 2009
Hey Neo, If you wanna read more about the DOSD: http://forum.tsebi.com/viewtopic.php?f=7&t=37
Help! landing gear on an fpv radian. need advice. ne1 try it? g3f0rc3 FPV Talk 6 Aug 19, 2016 05:29 PM
Help! Need advice on FPV Groundstation and ImmersionRC PowerBox nk4787 FPV Talk 1 Sep 04, 2013 10:27 AM
Discussion Advice wanted on buying an airbrush. brett.c Australia 12 Mar 08, 2012 06:21 PM
Discussion Daemon: Advice on slope soaring FPV setup? philthyy FPV Talk 8 Feb 16, 2012 11:45 AM
Discussion Need advice on E-setup for Lanier Shrike! KC10Chief Sport Planes 2 Oct 20, 2011 08:54 PM
