This thread is privately moderated by avi8tor0, who may elect to delete unwanted replies.
Old Mar 07, 2012, 07:29 PM
KK4CCD
United States, NC, Gastonia
Joined Apr 2011
ER9X Pan & Tilt Setup
Need mixes for your ER9X flashed FlySky or Turnigy 9X so you can set a throttle hold and use the throttle/rudder stick to pan and tilt your camera?
Here are my mixes to help get you there:
CH01: +100%AIR
CH02: +100%ELE
CH03: +100%THR
R +100% Switch(ELE) noTrim Curve(c3)
CH04: +100%RUD
R +100% Switch(ELE) noTrim Curve(c4)
CH05: R +100%CH5 Switch(ID2) noTrim Curve (c1)
CH06: +100%P3 noTrim (Front Knob on Transmitter)
CH07: +100%RUD Switch(ELE) noTrim
+100%P1 noTrim (To use the Left Top Knob on the radio for Tilt)
CH08: +100%THR Switch(ELE) noTrim
+100%P2 noTrim (To use the Right Top Knob on the radio for Pan)
Curves:
Curve 1 -100, -100, -100, -100, -100 (for 3 pos switch)
Curve 3 0, 0, 0, 0, 0 (Half Throttle)
Curve 4 0, 0, 0 ,0 ,0 (Don't move the rudder)
Safety Switches:
CH3 AIR Value -125 ((Make sure your Extended Limits is checked on the Setup Tab))
CH5 ID0 Value 100
When you switch the ELE switch to on, several things happen. First, the throttle is set to 60%. Curve 3 is where you set what percentage you want for throttle.
Curve 4 does not allow the rudder move when the rudder stick is moved. You don't want your rudder turning you while panning for example. Channel 7 is tied to your rudder stick. This channel is plugged into my Pan Servo.
Channel 8 controls my tilt and the throttle stick controls it.
WARNING!!! Remove your prop before you test this. It will turn the motor on!
Need a Return to Home switch for your throttle:
Go to your Safety Switches and add your switch to Channel 3. Set the value to -125. I know for Eagle Tree you can set this lower range and the OSD recognizes anything below -100 as out of range and sets RTH.
I have an EEPE file that I am using for my Bixler. Tested and works fine. Still trying to get used to using the stick for pan and tilt but I like it!
Let me know if you see something not right here.
avi8tor0 is offline Find More Posts by avi8tor0
Old Apr 06, 2012, 03:31 PM
dean420's Avatar
Canada, BC, Nanaimo Regional District
Joined Mar 2012
I added a third stick thru the hovthr. and the pittrm. pots, works really well can use all three sticks at the same time.
dean420 is offline Find More Posts by dean420
Old Apr 07, 2012, 09:38 PM
KK4CCD
Joined Apr 2011
That's too cool! If you don't mind me asking, where did you get the mini stick?
r/avi
Old Apr 08, 2012, 03:41 PM
dean420's Avatar
Joined Mar 2012
well i was playing my old psp when i decided that i really like the control stick, its really easy to do i will post some pictures soon
Old Apr 09, 2012, 03:23 PM
dean420's Avatar
Joined Mar 2012
http://www.rcgroups.com/forums/showthread.php?t=1629580 here is a little diagram
Old Apr 15, 2012, 03:57 PM
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
Any news on your flight tests, any changes ?
mr..speed is offline Find More Posts by mr..speed
Old Apr 15, 2012, 05:06 PM
KK4CCD
Joined Apr 2011
Yes..sorry for the delay. It works great. I uploaded the final version of the EEPE file which I am using for a Bixler right now.
I'll update the blog as I found a few issues.
R/Avi
Old Apr 15, 2012, 05:15 PM
KK4CCD
Joined Apr 2011
I made a few changes:
I decided to also use the two top knobs on the radio for pan and tilt as well as the mix that keeps the engine running and uses the sticks. One thing that I found is that you have to calibrate your sticks and knobs to get all of this to work correctly. Especially if you are using the P3 knob for the Guardian.
Before calibrating the knobs, put them at half travel so when you do calibrate, the radio will see the full travel. If you don't do this, your Guardian will be stuck on a gain setting of 4 and not move down to 0.
Do this procedure also for the remaining knobs so you get all of the travel out of your pan and tilt servos.
The EEPE file also sets the throttle hold switch for either 80% or 100% dual rates. My roll rates were way too fast and I may set them even lower.
R/Avi
Old Apr 16, 2012, 04:06 PM
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
Thanks for the info.
Old May 17, 2012, 01:02 PM
Ukraine, L'vivs'ka, L'viv
Joined Feb 2012
Thanks!!!
valerabox is offline Find More Posts by valerabox
Old May 17, 2012, 09:45 PM
KK4CCD
Joined Apr 2011
You are very welcome. Hope it works well for you.
R/Avi
Discussion tilt servo for prefab pan/tilt assy? rob10000 Video Piloting (FPV/RPV) 3 Apr 07, 2013 12:23 PM
Cool Easy pan tilt fmkit Video Piloting (FPV/RPV) 2 Mar 06, 2012 04:04 AM
Wanted XAircraft CM130-TPS Pan/Tilt Camera Mount Guntars Aircraft - Electric - Multirotor (FS/W) 0 Mar 03, 2012 08:07 AM
Question SETUP Turnigy 9x with ER9X setup for NAZA? Medicineman76 Radios 0 Feb 26, 2012 08:51 PM
Discussion Best Pan Tilt, Best pan tilt servos??? justind123 Video Piloting (FPV/RPV) 19 Feb 26, 2010 08:42 AM
