Old Apr 13, 2012, 05:45 PM
xatled99 is offline
Find More Posts by xatled99
xatled99's Avatar
Joined May 2007
LHS had some 5/32" music wire, so I bent some new landing gear. With that and foam wheels instead of rubber, I should be able to save about 5 oz. If I can get the AUW down to 70oz, that would put the plane at about 20 oz/sq ft wing loading, which would be tolerable.
xatled99 is offline Find More Posts by xatled99
Old Apr 14, 2012, 04:10 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Remaiden went very well today. It flew great with only a small amount of trim required; even managed a respectable touch and go on pavement. Unsurprisingly, the battery placement had to change due to the lighter fuselage. Depending on how the lighter landing gear works out, I may consider swapping in the 3s power system.
Old Apr 18, 2012, 04:51 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
one pound lighter
Swapping in the wire gear, lightweight wheels, and the 3s power system brought it down to 64oz. CG is reasonable with the battery all the way up front. Looks to be about 48oz static thrust at 25A with the 11x6.
Approximate weight saving distribution:
foam wheels: 2oz
wire landing gear: 4oz
smaller motor: 2oz
smaller lipo: 4oz
fuselage holes: 4oz
Old Apr 28, 2012, 12:34 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Three flights today with the 3s configuration. Best flights yet!
It flew powerfully, gracefully, and economically; 8 minutes of flying took the pack down from 90% to 50%. The 11x5.5 APC-E prop was fine. Enabling the motor's brake improved the glide. Slow flight characteristics were good, as were both power-on and dead stick approaches. I could trim the plane for level flight at about half throttle and then fly it around all day long with only the rudder. Stalls were pretty gentle and it would only drop a wing if you really pushed it. Unlike before, I didn't notice any yaw instability on short final.
Time to start installing the FPV gear.
Old May 05, 2012, 02:28 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
First FPV flights today. Not too shabby! Pavement takeoffs were pretty straightforward. Pavement landings were trickier, but doable. Power-on, flat approaches seemed best.
Old May 20, 2012, 02:59 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
This was actually flown LOS, not FPV.
scratchbuilt rq7a shadow osd (7 min 51 sec)
Old May 20, 2012, 03:29 PM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Wow I think you might need to check your video system, doesn't look very good IMO.
boopidoo is offline Find More Posts by boopidoo
Old May 20, 2012, 04:19 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
No, it really doesn't. I had much better results with my previous camera.
Old Aug 18, 2012, 11:29 AM
joe_crash is offline
Find More Posts by joe_crash
Pelagicide
joe_crash's Avatar
United States, MD, Gaithersburg
Joined Oct 2010
I like your mock up - I have liked that design for a while. It seems like many commercial and military drones use the inverted V tail design twin booms.
My question is: Why invert it? What does it add to the design? Is it more efficient or just very cool looking? (lol)
Thanks, I appreciate your patience with questions like these.
joe_crash is offline Find More Posts by joe_crash
Old Aug 18, 2012, 11:41 AM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
using twin booms, it gives you yaw control without the need for two rudders.
it's inverted because having it as a V interferes with ground clearance.
Toysrme is offline Find More Posts by Toysrme
Question Twin Boom Pusher? bagofbones11 Foamies (Scratchbuilt) 5 Nov 23, 2011 11:23 AM
Discussion Another Twin Boom pusher AP plane Bob Chiang Aerial Photography 5 Nov 02, 2008 12:46 AM
Discussion Another twin boom pusher - spud dalbert02 UAV - Unmanned Aerial Vehicles 18 Feb 25, 2008 10:53 PM
Another Twin-Boom Foamy Pusher from Foamflyer foamflyer Foamies (Kits) 16 Oct 28, 2004 09:59 AM
