Old Mar 30, 2012, 11:16 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
What did you do with the twin* fus?
Martin Y is offline Find More Posts by Martin Y
Old Mar 31, 2012, 06:19 AM
xatled99 is offline
Find More Posts by xatled99
xatled99's Avatar
Joined May 2007
I never had it; I bought the wing a la carte.
xatled99 is offline Find More Posts by xatled99
Old Mar 31, 2012, 12:09 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
All dressed up and ready to go. 460W at 32A on 4s with an APC 11x6, 9500 rpm.
Old Mar 31, 2012, 01:09 PM
TwoHeadsBrewing is offline
Find More Posts by TwoHeadsBrewing
Moderately Dangerous
TwoHeadsBrewing's Avatar
United States, CA, Chico
Joined Apr 2011
Very cool! Are you planning to add a nose cone to it?
TwoHeadsBrewing is offline Find More Posts by TwoHeadsBrewing
Old Mar 31, 2012, 01:10 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Yeah, eventually I'll either stick the camera turret up front or make a proper nose cone.
Old Apr 01, 2012, 03:00 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
scratchbuilt rq7a shadow maiden (2 min 11 sec)
Old Apr 02, 2012, 08:44 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Flew about 5 times yesterday. Power consumption looked good and the plane should get nice long loiter times. Looked to be about a 1:1 thrust:weight ratio; AUW is around 80 (!) oz.
Overall, I'm pretty happy with how it flew. The lack of a proper nose probably didn't do it any favors in the wind. Comes down like a lead balloon at idle, but it didn't exhibit any bad tendencies. Rudder-only turns were a breeze. It didn't seem to like uncoordinated slipping turns.
I hadn't anticipated how much the foam wing would flex spanwise. I suspect it mostly happens on the ground, but I'm tempted to borrow an 808 camera to check it in flight to be sure.
Old Apr 06, 2012, 09:08 AM
xatled99 is offline
xatled99's Avatar
Joined May 2007
In the process of relocating the boom mounts to clean up the incidence angle. This should reduce the amount of up elevator trim required. Might add a thin CF rod to the inboard trailing edge to reduce wing flex. Also added some more plywood sheeting to prevent the trailing edge from bending around the edge of the fuselage.
Replaced the nosewheel steering arm with wheel collars to make the nose installation easier. Started laminating some foam. Undecided whether the nose will be fiberglass or foam or if I'll just use the camera turret after all.
Might pick up a mentor wing and trying using slow stick fuselages as tail booms. Would need to figure out the necessary tail area. I think the extra ~200 sq in would really improve the wing loading. Need to start figuring out ways to save weight.
Old Apr 06, 2012, 09:34 AM
tomer_inbar is offline
Find More Posts by tomer_inbar
Joined Jun 2008
I started to build this:
http://www.ebay.com/itm/Sky-explorer...62339055276231
Will update in the future.
tomer_inbar is offline Find More Posts by tomer_inbar
Old Apr 07, 2012, 05:26 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Next round of mods. Relocating the boom mounts improved the tail incidence. This will also lengthen the tail a little, which should help with stability. Hot glued the dome nose on.
The fuselage alone is about 2.8 lbs. Just the pvc and the motor should be about 1.6, so that leaves about 1.2 for the firewalls and landing gear and wheels. Time to find some fat to trim...
Old Apr 09, 2012, 06:22 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
hubris
I discovered spadworld.net today and realized that I grossly overpaid for that pvc tubing from amazon. 2.5" downspouts and 4" fence post sleeves seem more common and cheap, not to mention coroplast, but I'm not going there.
I also swiss-cheesed the fuselage with a 2.5" holesaw, which saved some weight.
Current totals:
fuselage+firewalls: 20oz
motor: 7oz
landing gear+tires: 10oz (oof!)
wing+tail: 20oz
lipo: 14oz
electronics: 4oz
total AUW: ~ 75oz
Needs some monokote and velcro but otherwise will be ready for remaiden this weekend, weather permitting.
Old Apr 11, 2012, 05:08 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
For posterity, should I ever build up another one of these, it would look like this:
  • mentor wing
  • Turnigy G10 810kv + APC-E 11x5.5
  • 3s 3000
Use swisscheesed 2.5" pvc downspout for the fuselage. Use slowstick fuselages as tailbooms. Cut channels in the wings and glue the tailbooms directly in for less drag. Should be close to 65oz. Tail sizing as follows.
Code:
inputs:
CG  = 3.300
wing: span=65.000, chord=10.750, area=698.750, AR=6.047
stab: span=22.000, chord=6.000, area=132.000, AR=3.667
fin:                            area=80.000
tail: length=22.000, arm=25.562
outputs:
V_h = 0.449
V_v = 0.045
NP  = 4.779
SM  = 0.135
equivalent vtail:
area                = 212.000
dimensions          = 35.333 x 6.000
true AR             = 5.889
dihedral angle      = 37.901
projected half span = 13.940
projected AR        = 4.647
projected height    = 10.853
Old Apr 11, 2012, 07:18 PM
charlienofun is offline
Find More Posts by charlienofun
charlienofun's Avatar
United States, CA, Santa Clara
Joined Mar 2008
Great work! The specs are much appreciated
charlienofun is offline Find More Posts by charlienofun
Old Apr 12, 2012, 07:34 AM
AirRecon is offline
Find More Posts by AirRecon
AirRecon's Avatar
Joined Oct 2011
Fantastic scratchbuild xatled99, you certainly know your planes!
I'd love to have a platform like this, but wouldnt really know where to start, let alone sourcing all the right components for the build, dimensions, plus fabricating it to completion like this!
Really enjoyed reading through this build, plus the pics and video on Page 3 are the excellent.
Well done. So are you turning this one into a fully featured FPV craft, or more for some AP work?
Very inspiring.
AirRecon is offline Find More Posts by AirRecon
Old Apr 12, 2012, 06:16 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Thanks! Yeah, the plan is to equip it for FPV once the kinks have been worked out of the airframe.
Monokoted the fuselage. While I had the gear off, it weighed in at 10 (!) oz; considering making some gear out of 5/32" music wire.
Question Twin Boom Pusher? bagofbones11 Foamies (Scratchbuilt) 5 Nov 23, 2011 11:23 AM
Discussion Another Twin Boom pusher AP plane Bob Chiang Aerial Photography 5 Nov 02, 2008 12:46 AM
Discussion Another twin boom pusher - spud dalbert02 UAV - Unmanned Aerial Vehicles 18 Feb 25, 2008 10:53 PM
Another Twin-Boom Foamy Pusher from Foamflyer foamflyer Foamies (Kits) 16 Oct 28, 2004 09:59 AM
