Old Mar 11, 2012, 03:11 PM
xatled99 is offline
Find More Posts by xatled99
xatled99's Avatar
Joined May 2007
Discovered that www.intothewind.com has reasonably priced fiberglass tubing. Ordered some 3/8". It weighs 2.45 oz for 54.5". Weight & balance calculations look good so far.
xatled99 is offline Find More Posts by xatled99
Old Mar 13, 2012, 08:17 AM
xatled99 is offline
xatled99's Avatar
Joined May 2007
The tail volume coefficients are more or less in a happy place. There will probably be some fine tuning, but I at least have some confidence that the design will work. Preliminary plans are drawn up. Most of the parts should show up by the end of the week, and then the building will begin.
Code:
inputs:
CG  = 3.350
wing: span=56.000, chord=9.000, area=504.000, AR=6.222
stab: span=16.000, chord=5.000, area=80.000, AR=3.200
fin:                            area=45.000
tail: length=20.000, arm=23.000
outputs:
V_h = 0.406
V_v = 0.037
NP  = 3.775
SM  = 0.125
equivalent vtail:
area                = 125.000
dimensions          = 25.000 x 5.000
true AR             = 5.000
dihedral angle      = 36.870
projected half span = 10.000
projected AR        = 4.000
projected height    = 7.500
Old Mar 15, 2012, 05:15 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
ObSketchup:
Old Mar 15, 2012, 05:17 PM
rclab1 is offline
Find More Posts by rclab1
USA
Joined May 2010
rclab1 is offline Find More Posts by rclab1
Reply With Quote  (Disabled)
Old Mar 15, 2012, 07:02 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Firewalls cut, landing gear/wing/tailbooms laid out.
Old Mar 16, 2012, 05:55 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Landing gear and motor mount. I used nylon standoffs from ace hardware; I had to drill them out a little to fit the 6-32 dubro hardware. An 11x6 prop should do the job according to ecalc.
Old Mar 16, 2012, 08:53 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Tail framed in.
Old Mar 16, 2012, 11:11 PM
rclab1 is offline
USA
Joined May 2010
....are you using a 'Multiplex Twin-Star' wings? or just using for mockup?
Old Mar 17, 2012, 08:59 AM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Boom mounting concept, work in progress. This should distribute the tail loads around the wing spar. The booms will need to be pinned in somehow.
Yes, I'm using a twinstar wing.
Old Mar 17, 2012, 04:28 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
If I had to do it over, I would have put the mounting brackets in before building the tail. Glue doesn't stick to the clamps so I had to use some 6-32 x 1/4" hardware.
I castered the nosewheel a bit.
The 11x6 prop is a bit tall; I may need to raise the motor mount.
Old Mar 17, 2012, 06:33 PM
charlienofun is offline
Find More Posts by charlienofun
charlienofun's Avatar
United States, CA, Santa Clara
Joined Mar 2008
Awesome Progress!
charlienofun is offline Find More Posts by charlienofun
Old Mar 18, 2012, 06:39 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Learned that the wing and stab incidence angles are zero on this bird.
Going to need 3 1/4" wheels to make the fuselage level on the ground.
Moved the motor mount to the top of the firewall. Also realized that flush mounting the motor will buy a little more prop clearance on rotation.
Old Mar 23, 2012, 07:41 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
The new main wheels and wing dowels are installed and the access hatches are cut out. The CG looks good so far.
The prop collet that came with the motor was bunk, so I had to order an eflite one. I'm currently waiting on some pushrod hardware and a servo wire crimper and then I can start wrapping things up.
Old Mar 25, 2012, 12:07 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Firewalls epoxied in. Glued in some 3/32" ply strips to prevent the rubber bands from gouging the foam. ESC and rx and servos are in, pushrods are made. Chopped off the nacelles. The eflite collet showed up, but the shaft is a different diameter. I'd already reamed the props, so now I need new props. Argh. Hoping to maiden by next weekend.
Old Mar 30, 2012, 08:46 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Servos, pushrods, horns, etc. are all in. New props showed up and thankfully Just Worked with the eflite collet. Aileron Y harness is in. Still need to strap down the vtail wiring and program the radio. Looks like 300ish watts with 10x6, 400ish with 11x6, on a half charged pack. Wondering if a 3 blade would help with ground clearance.
Should be good to go for a maiden this weekend.
Question Twin Boom Pusher? bagofbones11 Foamies (Scratchbuilt) 5 Nov 23, 2011 11:23 AM
Discussion Another Twin Boom pusher AP plane Bob Chiang Aerial Photography 5 Nov 02, 2008 12:46 AM
Discussion Another twin boom pusher - spud dalbert02 UAV - Unmanned Aerial Vehicles 18 Feb 25, 2008 10:53 PM
Another Twin-Boom Foamy Pusher from Foamflyer foamflyer Foamies (Kits) 16 Oct 28, 2004 09:59 AM
