Old Mar 07, 2012, 09:11 AM
liukku is online now
Find More Posts by liukku
mostly gliders
liukku's Avatar
Skellefteċ, Sweden
Joined Sep 2003
High voltage servos, such as Hitec's do they work with 4.8V-6V voltage?
Hello
The high voltage servos, such as Hitec's, do they work with 4.8V-6V voltage?
/Ville
liukku is online now Find More Posts by liukku
Old Mar 07, 2012, 09:26 AM
mighty9 is offline
Find More Posts by mighty9
United States, AZ, Cochise
Joined Sep 2011
Im going to say yes . But maybe if you list some specific models people can give a more educated answer
mighty9 is offline Find More Posts by mighty9
Old Mar 07, 2012, 09:43 AM
mostly gliders
liukku's Avatar
Skellefteċ, Sweden
Joined Sep 2003
I was thinking about the Ultra Premium Digital-serie, e.g.HS-7115TH HV Ultra Slim Titanium Gear Servo
http://www.hitecrcd.com/products/dig...hs-7115th.html
But I also ask the question in general, what about other brands servos?
/Ville
Old Mar 07, 2012, 10:15 AM
MikeMayberry is online now
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
All the HV servos have specs listed at 6.0 /7.4v... using them at 4.8v is also possible with reduced performance.
Mike.
MikeMayberry is online now Find More Posts by MikeMayberry
Old Mar 07, 2012, 10:20 AM
mostly gliders
liukku's Avatar
Skellefteċ, Sweden
Joined Sep 2003
Mike.
Thank you Mike
That is what I wanted to hear.
/Ville
Old Mar 07, 2012, 02:16 PM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
IF-- you are using smaller ESC with internal BEC setups - don't bother with HV servos Mot of those run an output of 5-5.5 volts for the rx and servos
Other than that exception, HV servos have a lot going for em.
I run A123 battery packs on anything othe than small electric powered models . these and 2 cell Lipos proved same servo power at lower amps.-
The servo wiring, which is really WAY behind the curve in all of the present radios, is not as likely to overheat.
Any larger models , now get HV servos -
richard hanson is online now Find More Posts by richard hanson
Old Mar 07, 2012, 06:23 PM
mostly gliders
liukku's Avatar
Skellefteċ, Sweden
Joined Sep 2003
If, as Mike says, I see no problem to use high voltage servos via a 5V-5, 5V bec circuit. Why not bother? I can think of several reasons to want to use a mixture of high voltage servos and my old (4.8V-6V) low voltage servos. Above Said Hitec servos would suit me very nicely because of its size.
But as I said, my question was mostly meant as a general question about the usage possibility.
/Ville
Old Mar 26, 2012, 11:35 AM
Jaguar22 is offline
Find More Posts by Jaguar22
Never Stop Learning
Jaguar22's Avatar
United States, GA, Atlanta
Joined Mar 2005
If you go to Hitec's webpage and read the specs for their HV servos it states 7.4v and 6.0v input voltage for their HV servos . Running lower input voltage than 6.0v would work but the servo performance will be very weak and slow. I have several planes with HV servos and have been running them for quite a while. The HV model servos have similar performance specs to their equivalent standard voltage servos, not extra power from higher input voltage or different power source. It is still best to run a regulator to keep input voltage constant under load and flight to flight. This is very helpful for precision aerobatics etc.
There are two advantages to HV servos, weight savings of lipo cells and running higher input voltage to the Receiver. Higher input voltage for a 2.4 receiver helps prevent brown out situations that can happen with most any brand receiver. An ounce of prevention saves pounds of cure.
Originally Posted by liukku View Post
Hello
/Ville
Jaguar22 is offline Find More Posts by Jaguar22
Old Mar 26, 2012, 12:06 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
The regulator can do more harm than good in situations with high instantaneous current demand. For voltage stability under load, a 2S A123 pack is all the regulation you need.
I have a set of the new Hitec HS-430BH going into a new build, though will be on 2s A123. Looks like a nice dual BB servo for less than 15 bucks.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Mar 26, 2012, 12:35 PM
Joined Oct 2007
Pete
The guys who have not used A123 and really understand WHY the differences - won't agree - but -then it's their choice --
Lipos have their place tho-
Discussion What do you use to recharge your small 4.8v battery packs? wolfv Slope 24 Apr 04, 2012 07:43 PM
Discussion XQ-POWER’s new waterproof high voltages at 9.6V-12V servos cathy_yin Electric Power Cars 1 Feb 24, 2012 11:40 PM
Question Using 4.8v & 6v UBEC's simultaneously 9XTremist Power Systems 2 Jan 08, 2012 10:30 AM
Sold 4x Hitec HS-7954SH high voltage servos jaylude22 Aircraft - General - Radio Equipment (FS/W) 1 Nov 08, 2011 09:12 AM
For Sale 4.8v 6v Receiver Packs & Voltage Monitor/Watch stretch1100 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jul 07, 2011 03:01 PM
