Old Mar 06, 2012, 08:17 PM
tonytiger20 is offline
Find More Posts by tonytiger20
tonytiger20's Avatar
USA, MS, Picayune
Joined Jan 2011
Can a nimh esc be used for lipo?
Like the title says I have inherited a nimh 15 amp esc. I guess there is no way to use this with a lipo battery right?
Thanks in advance
Wrong Brothers RC
Picayune, MS
tonytiger20 is offline Find More Posts by tonytiger20
Old Mar 06, 2012, 08:40 PM
Lammergier is offline
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
is the esc for a brushed or brushless motor. What matters is voltage. Not what kind of battery makes the voltage. Also the cutoff voltages are different.
Lammergier is offline Find More Posts by Lammergier
Old Mar 06, 2012, 08:41 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
As long as it can handle the lipo's voltage and you time the flights so the pack doesn't get drained too low, you'll be fine. The ESC doesn't care what's driving the current.
Piece is online now Find More Posts by Piece
Old Mar 06, 2012, 10:07 PM
USA, MS, Picayune
Joined Jan 2011
It was for a brushed motor.
Old Mar 06, 2012, 10:18 PM
exeter_acres is offline
Find More Posts by exeter_acres
Extreme Flight Tech Support
exeter_acres's Avatar
Johns Creek, GA
Joined Jan 2005
as mentioned... assuming you can get the voltage in the same range...
the ESC doesn't care where the voltage comes from
exeter_acres is offline Find More Posts by exeter_acres
Old Mar 07, 2012, 05:05 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Provided your battery is within the voltage range that the ESC is designed for, the only thing that need concern you is the ESC's low voltage cutoff: Many Nixx ESCs are designed to cut off at a fixed percentage of whatever the starting battery voltage was when you plugged it in. Other ESCs may have some kind of user selection for cell-count, in which case you'll have to select the closest equivalent voltage. For LiPos, the percentage the ESC's lvc uses will generally result in them going down significantly below the level that's generally regarded as being advisable, before lvc kicks in.
The solution, as others have mentioned, is to time your flights so that you land before the ESC's lvc kicks in. You need to find, by trial-and-error, a duration that uses 80% or less of your battery's capacity.
abenn is offline Find More Posts by abenn
Old Mar 07, 2012, 07:08 AM
USA, MS, Picayune
Joined Jan 2011
It is a Tactix TSC600 ESC. 6-7 NIMH. 15 amp. It was running a 7 cell 8.4 volt 2/3 amp 1100 Mah battery. Was hooked to a 370 brushed motor.
Old Mar 07, 2012, 08:31 AM
abenn is offline
Joined Jul 2004
That should be okay with a 2S LiPo, so long as you time your flights instead of waiting for lvc to stop the motor. The power may be down slightly, compared with 7-cell NiMh (slightly lower voltage fresh off the charger), but that should be compensated for by the reduced weight. You'll also probably have to move the battery, to get the model's c of g in the same place as it was with the NiMh pack.
Old Mar 07, 2012, 09:13 AM
USA, MS, Picayune
Joined Jan 2011
The old plane was scrapped for parts. I build a few scratchbuilts out of $tree foam and was looking for a use for it. I will hook it up and run some bench tests. Yes I do time my flights with my DX6i.
Thanks for all the info.
Discussion Can old Novak ESC be used with new radios? shahram72 Car Talk 3 Feb 21, 2012 07:48 PM
Discussion Is there an actual binding remote that can be used for the parrot ar drone quadricop the desolate one VTOLs 1 Dec 15, 2011 07:01 PM
Discussion What is the lowest frequency that can be used for FPV? GJH FPV Talk 10 Sep 29, 2011 01:59 AM
Question Can an Electrifly C-20 ESC be used with a 3c LiPo? Don H. Electric Plane Talk 0 Jun 09, 2007 06:48 PM
Can a TEKIN BC112C Charger be used for LiPo batteries? glennhl Batteries and Chargers 18 Dec 22, 2004 09:31 AM
