Old Mar 30, 2012, 01:19 PM
I_Can't_Fly is offline
Find More Posts by I_Can't_Fly
But I am learning
I_Can't_Fly's Avatar
USA, MD, Cumberland
Joined Apr 2008
Originally Posted by wyowindworks View Post
I was just simply curious how Gerald's fuses compared with mine in terms of mass distribution.
Assuming Gerald measured his @ approximately 75 to 80mm, how do yours compare?
Brian P.
I_Can't_Fly is offline Find More Posts by I_Can't_Fly
Old Mar 30, 2012, 01:32 PM
ShadowFalken is offline
Find More Posts by ShadowFalken
Jim C
ShadowFalken's Avatar
Joined Sep 2009
Brian P.
As I read that, Gerald had to add 7.3g to the nose to hit that point of balance. Perhaps he can verify that. I did "finger balance" a couple of the fuses that Gerald made and found the empty balance point to be similar what Adam's fuse comes out to. Adam's are around 120mm back from wing LE without a tail mount. I want to check one of my Stobi fuses to but have not done it yet.
EDIT: I see Adam has updated his layup and the CG has shifted forward about 5mm from my quote.
ShadowFalken is offline Find More Posts by ShadowFalken
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Brian P.
I've got 3 layups now. All my raw fuse balance points have been shifted forward since I started adding more fiber to nose portion since everybody was having to add lead (everything after serial #: DLG1054). The raw fuses all balance ahead of 115 mm from the LE since this change. The Economy Plus balance point is less than 108mm from the LE.
Economy weighs 51 grams with the lead to balance at 80mm (44.5 grams raw)
Economy Plus weighs 48.5 grams at 80 mm (44.5 raw - stiffer layup, higher hoop strength than economy)
UL weighs 41.5 g at 80mm (38.5 raw - stiffest layup)
wyowindworks is offline Find More Posts by wyowindworks
Old Mar 30, 2012, 02:39 PM
But I am learning
USA, MD, Cumberland
Joined Apr 2008
So in comparison to yours, Gerald's is a little heavier in the boom, or lighter in the nose depending on how you look at it. When doing a side by side comparison to your economy layup, Gearlds has a stiffer boom (no jokes from the peanut gallery). I do not have, and or have seen your UL layup for a comparison. Either way I think yours and Gerald's will both build out quite well, thanks for sharing.
Brian P.
Old Mar 30, 2012, 03:00 PM
Just fly it!
Cody, WY
Joined Nov 2007
I wouldn't be surprised by that. My economy boom only uses T700 UD carbon (upper-end standard modulus carbon) that is really easy to use and glass. The economy plus replaces the glass with woven carbon. This makes the boom lighter and stiffer.
Brian, did the fuse that you compared have a Serial # tag? All the serial # fuses has 30% more fiber in the boom by weight than the non-serial # fuse. Just curious for my own benefit.
Old Mar 30, 2012, 03:14 PM
But I am learning
USA, MD, Cumberland
Joined Apr 2008
I do not have it in my possession, and do not recall a number sorry.
Brian P.
Old Apr 04, 2012, 02:22 PM
G_T is online now
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
Originally Posted by NCDLG View Post
Not a problem, I'll keep an eye on things when it arrives.
I have a good idea this will be a keeper, you don't exactly keep low standards when it comes to DLG's or it's parts!
Thanks again Gerald.
Eric
I checked with Eric today and he received the fuselage ok. Good thing I caught him - he was about to mail back the PVC pipe I used for shipping! I appreciate the thought, but...
Folks, you get to keep the PVC pipe. That is covered in the $10 shipping cost (I suppose I should call it a shipping and handling cost). It would cost you as much or more to ship it back as it would cost me to replace it.
Gerald
G_T is online now Find More Posts by G_T
Old Apr 04, 2012, 05:01 PM
samc99us is online now
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Yeah, I think that's $2 in PVC...Eric has connections so he could probably ship it back for the same amount...
samc99us is online now Find More Posts by samc99us
Old Apr 04, 2012, 09:38 PM
NCDLG is offline
Find More Posts by NCDLG
NCDLG's Avatar
United States, NC, Raleigh
Joined Sep 2010
Nice to chat with you today Gerald, are you sure I paid you enough?...
Really, this is a beautiful fuse, simple and strong. As expected, Gerald's classification of a second quality or "blem" is what I normally see as firsts. Great work for #6, I hope you continue to pop them out as time/materials allow.
It's a gem!
Aurora should be quite happy mounted to this one!
The plan for it is to get Sam's Aurora wing and Brian's VeilTomTails on it.
Thanks again Gerald!
All the best,
Eric
NCDLG is offline Find More Posts by NCDLG
Old May 09, 2012, 02:26 PM
G_T is online now
G_T
G_T
Joined Apr 2009
It looks like I will be starting a production batch of 6 - 10 fuselages this Friday (exact number depends on how much fabric I have). One is spoken for (an experimental layup for one of my friends), and possibly I'll pick a blem (assuming) and keep it for myself.
I have one last thing to make - a foam cover that becomes the lid for my hot box. I just need to go to the hardware store and purchase a sheet of foam and tape it up. Then I'm ready to begin.
Soon... Soon...
After this first batch I'll need to purchase more fabric as I'll be out of some of what I'm using. My stock of fabric suitable for fuselages is unfortunately quite a bit smaller than my stock for wings. So there may be a delay between the first batch and the second. I plan to get enough fabric to last a while. Actually the first batch is to help pay for the fabric order so I can make more.
Three prototypes are in people's hands. If any of them get built or get flying, I'd love more feedback! Besides, everyone likes to see pictures and read stories about DLGs!
FWIW, the boom length as delivered is roughly 2" longer than what I generally use in my personal planes and in my designs. There is no need to keep the boom full length if you don't want to.
Gerald
Old May 09, 2012, 02:30 PM
Aurora Builder
Joined Nov 2003
PM's full, email sent!!!!
Old May 09, 2012, 04:15 PM
KevinSharbonda is offline
Find More Posts by KevinSharbonda
Make Flying Fun
United States, CO, Grand Junction
Joined May 2003
KevinSharbonda is offline Find More Posts by KevinSharbonda
Old May 09, 2012, 05:06 PM
jbarnhardt is offline
Find More Posts by jbarnhardt
jbarnhardt's Avatar
United States, WA, Seattle
Joined May 2011
PM attempted - I'll take one too to pair up with a "forgiving foils" wing if they're not already all spoken for. Thanks!
-John
jbarnhardt is offline Find More Posts by jbarnhardt
Latest blog entry: Latest creation...
Old May 09, 2012, 09:52 PM
tai626 is online now
Find More Posts by tai626
San Gabriel Valley, CA
Joined Mar 2008
I will take 2ea. I can send check to save fees.
Tai
tai626 is online now Find More Posts by tai626
Old May 10, 2012, 09:45 AM
G_T is online now
G_T
G_T
Joined Apr 2009
I've received requests for 10 fuselages so far, not counting any for myself. I've made a little list, and will be contacting people as fuselages are completed. There are no commitments yet! When a fuselage is done, I'll contact you to see if you still want it. If so, then I'll send it out. You can inspect it and either return it or mail me a check.
I probably won't get enough fuselages out of the first batch to fill all the requests.
I thought I posted it somewhere but can't find it... I'm looking for roughly $175 during the first batch. I'll finalize the price when they are in hand. Seconds, if they are GOOD seconds, will be cheaper. Or I'll fly them!
Gerald
Question 500 & 600 Fuselages flyingfish56 Large Electric Helis 1 Mar 02, 2012 01:24 AM
Sold Sailplane fuselages, LPU, LA SoCal. Area Doubletap Aircraft - Sailplanes (FS/W) 21 Feb 25, 2012 11:40 PM
Sold Two DLG Fuselages, single-piece, oval boom Jonas M. Aircraft - Sailplanes (FS/W) 3 Nov 17, 2011 11:19 AM
Discussion Mini Titan Scale Fuselages Robert Stinson Scale Helicopters 12 Oct 19, 2011 01:54 PM
Help! Fuse box . . . or a box full of fuselages Kookaburra Sailplane Talk 14 Sep 25, 2011 11:16 PM
