Congress, AZ
Joined Sep 2001
Gerald,
Synergy to me, just seems to large. I'd think a key element in glide performance for still air is weight. At the current area, it would be difficult to build a light plane. Since less area usually translates to less drag, it should also launch higher, I'd speculate. I haven't built one, just can't get enthused about another Blaster 3 or wide wing Encore size plane. Now if it were somewhat smaller than the current ZoneV2 wings ... Just speculation. Gary |
Joined Apr 2009
The reference Synergy design is not that large. What you have seen is the TS wing, which we enlarged quite a bit to get it to be floatier at higher altitude for the Team Select. The Synergy wing has about the same area as the other wings I've published.
Gerald |
I have a Synergy wing drawn up to compliment my ZV2 planes, but haven't had time to test yet. Hope to get to it later this year with some feedback.
Thomas |
Latest blog entry: Neos Layups
Joined Apr 2009
I'll be rather interested in what you think. Even from my very limited stick and visual time, I can safely say is very different from Zone.
Differences I've seen: Zones of all stripes like camber and can use lots of it if one wants. Edges don't like lots of camber. Synergy doesn't like lots of camber, very much like the Edge. Synergy is slower, though that could be the TS wing fooling me. Others have said the same thing with different wings though, so I think it is a safe statement. To make Synergy go fast, you have to mean it. What I mean by this is that a Zone is fast and easily goes fast. With Synergy, you put it into speed mode, but you also have to push on the elevator to get it moving. You might have to hold the down elevator to keep it moving. But when moving it is pretty fast and pretty flat. Gerald |
United States, MD, Lusby
Joined Nov 2003
Gerald,
Instead of responding to this thread last night I took the liberty of preparing my molds for another pull, you need a ZV2 wing. I'm expecting Synergy cores by Christmas (I know, 2 months away but CNC software is painful). You will have a wing from this batch of cores (think Orange Taboo). We've talked a fair bit about this in the past. My suggestion is to build something YOU will fly. I interpret a lot of passion for the Edge in your writing. I see Edge as a design that requires a lot of advanced techniques to build and fly right. Something that you could charge a fair price for if you built say 10 planes. I think developing Edge-II, and a plane based around that, perhaps build and fly it for 6 months to a year before you release the design, would be a very satisfactory effort. -Sam |
Joined Apr 2009
Hi Sam,
I'd love to have one of your wings! THANKS! ----- I screwed up another fuselage last night. This was the end of the material I used for the first batch so there won't be any more like it. Hopefully the second batch will be better though! In a few weeks I'll start to do a little layup testing and all that sort of stuff. Anyway I came up with another way to screw one up. Seems like there is no end to the possibilities. I think that is what makes fuselage work so annoying at times. Too many rejects for the level of work. My epoxy bottles were on the low side, so I topped them off. They are labelled, but, I put the hardener bottles back in swapped positions. When I went to make the fuselage, the first batch of epoxy smelled a little stronger and looked a little darker, but I just chalked that up to aging hardener. It did seem to be thickening up a touch faster than usual by the end of that batch. Then I went to mix up the second batch... The light came on "that's not right...". Read the label, and $@#@. I used all fast hardener for the first batch! It was MGS, so perhaps not all is lost. Tossed the second batch, and made a third but using slow hardener. I finished the layup, but this time used 60psi for the initial evacuation stage instead of the more usual 45. I'd hoped to squish more epoxy out. Didn't matter... The fuse looks very good, one of my better looking ones actually, but it is somewhere around 8g heavy. That's not good for a DLG. What a waste. So if someone wants an overweight DLG fuselage for a beater or a light sloper, first $80 + 15 shipping, continental US, gets it. What a waste. Gerald |
Joined Apr 2009
PVA cleaned off and screws installed, but the hatch opening isn't cut yet and the hatch is not trimmed. So it should end up gaining perhaps 1g from where it is now. Were it one of my planes, I'd be cutting about 2.4" off the tailboom. You don't have to of course - I just prefer the booms not as long as some. That would remove perhaps a couple of grams. Current weight is 47.4g. So I expect the final weight to be somewhere in the neighborhood of 48.5g before any trimming of the tailboom.
Gerald PS - Send me a PM with your address. Usual rules - don't send payment until you have inspected it and decided to keep it. Otherwise just send it back. I may get it shipped on Monday. |
| Thread Tools | |
| Question 500 & 600 Fuselages | flyingfish56 | Large Electric Helis | 1 | Mar 02, 2012 01:24 AM |
| Sold Sailplane fuselages, LPU, LA SoCal. Area | Doubletap | Aircraft - Sailplanes (FS/W) | 21 | Feb 25, 2012 11:40 PM |
| Sold Two DLG Fuselages, single-piece, oval boom | Jonas M. | Aircraft - Sailplanes (FS/W) | 3 | Nov 17, 2011 11:19 AM |
| Discussion Mini Titan Scale Fuselages | Robert Stinson | Scale Helicopters | 12 | Oct 19, 2011 01:54 PM |
| Help! Fuse box . . . or a box full of fuselages | Kookaburra | Sailplane Talk | 14 | Sep 25, 2011 11:16 PM |
