Old Mar 06, 2012, 01:11 PM
minnreefer is offline
Find More Posts by minnreefer
United States, MN, Medina
Joined Mar 2007
trailer help
I have an old 60's pop up type trailer that I use fir my airplanes, I need to redoubt the trailer and I have a question. If I make the tongue longer, how will it effect towing and ride?
Jon
minnreefer is offline Find More Posts by minnreefer
Old Mar 08, 2012, 08:33 AM
ctrout is offline
Find More Posts by ctrout
Waiting for the paint to dry.
ctrout's Avatar
Pasadena Maryland
Joined Oct 2009
Just like a tracter trailer. It will track to the % you move it as the wheel base has moved to the rear But the load on the tow ball needs to be the same. The replacement tongue need to be as thick or more then the one your taking off. The longer your replecement the more it can bounce if the tube is to thin.
Hope it helps. ct
ctrout is offline Find More Posts by ctrout
Old Mar 08, 2012, 09:11 AM
Joined Mar 2007
Thanks, right now it is a pretty small trailer, and I need to replace the plywood bottom that holds it together. I figure that if I need to take it apart, I may as well make it a little longer and taller to hold more planes. The longer tongue makes sense, I am not worried about tongue weight, but it is a good idea.
Old Mar 08, 2012, 11:22 AM
ctrout is offline
ctrout's Avatar
Pasadena Maryland
Joined Oct 2009
In a few of the areas are trailer build in this site that can help you out with ideas but if you need more just ask. I do mods to my trailers for models just about every year.
Good luck.
trout
Old Mar 08, 2012, 11:33 AM
Joined Mar 2007
Thanks, I really like your current 19' trailer project.
Gallery RC trailer build twinstick The Builders Workshop 7 Mar 10, 2012 07:44 AM
Discussion FPV AIR RACING - Trailer and Teaser Video!!! wac FPV Talk 2 Sep 19, 2011 09:44 AM
Discussion Who will insure my modelling trailer and its contents? (Plus trailer pictures) Trent Collins Australia 21 Aug 09, 2010 05:00 PM
Need help fixing pop-up trailer FAAST!! tenover Life, The Universe, and Politics 1 Jan 09, 2003 11:03 PM
