Old Mar 06, 2012, 12:48 PM
sprgfvr02 is offline
Find More Posts by sprgfvr02
Joined May 2011
Magnum 91 XL rebuild problem - How do I remove the conrod?
I am in the process of rebuilding a four stroke engine. I'm attempting to remove the con-rod from my Magnum 91 XL 4 stroke. It moves about a third of the way off but seams to not want to move any further. there are two holes at the base of the rod at about 5 and 7 o'clock. I don't know what these are for, and they do not appear to be housing any set screws.
Any ideas?
sprgfvr02 is offline Find More Posts by sprgfvr02
Old Mar 06, 2012, 12:52 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Remove the sleeve if you haven't already. The crank pin may need to be positioned about 30-60 down from TDC if there is a groove in the crankcase. If it still doesn't come out, the rod needs to be pushed aft in the piston.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Mar 06, 2012, 01:11 PM
Patxipt is offline
Find More Posts by Patxipt
engine-a-holic
Portugal, Lisbon
Joined Jun 2007
If I'm not mistaken, the wrist pin needs to come out in order to remove the conrod.
You will have to remove the cylinder and place the teflon bushing of the wristpin on the crankcase hole in the back. remove that bushing with a thin pointy screw, being carefull not to damage it, then do the same to pull the wristpin out through that hole.
Good luck!
Patxipt is offline Find More Posts by Patxipt
Old Mar 06, 2012, 02:15 PM
Joined May 2011
I'm trying to remove the connecting rod from the crank. I can't get to the piston without removing it, and the connecting rod prevents this. There is very little play at the top of the connecting rod but I did pull it as far aft as i can. Still no good.
Old Mar 06, 2012, 02:32 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Right, as eluded to above, there is a hole for the piston pin to be removed in the rear of the crankcase. The OS FS-91 does not have this hole.
OS FS-52 Four Stroke RC Glow Engine Disassembly (9 min 26 sec)
Greg
Old Mar 06, 2012, 02:59 PM
Patxipt is offline
engine-a-holic
Portugal, Lisbon
Joined Jun 2007
But the magnum has, Greg.
Good ideia on posting your disassembly video, I'd forgetten about it ;-)
Old Mar 06, 2012, 03:02 PM
Joined May 2011
Update;
I removed the sleeve and was able to remove the connecting rod. I now have to remove the crank shaft. Time to heat the oven or go buy a torch. This is fun.
Old Mar 06, 2012, 03:05 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Yes, it does. I forgot.
Hmm, so did you need to pull the wrist pin through the hole?
Old Mar 06, 2012, 05:42 PM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
First the two holes in the bottom of the conrod are lubrication holes.
Second to remove the crankshaft you will have to remove the cam first. It is driven by helical gears on the crankshaft. No amount of heating will get it out until the cam is removed. Once it is removed then the crankshaft will come out. That is the time to heat it to remove the main bearing from the crankcase (tight fit). Sometimes just a smart rap with a block of wood over the prop end of the crankshaft will get it out. Others it will take heat to get it out.
Chip01 is offline Find More Posts by Chip01
Old Mar 06, 2012, 06:00 PM
Joined May 2011
I removed the cam before I tried to remove the crank shaft. Figured that one out for myself ;>) The videos I viewed were great, although not for a 4 stroke. I now have all bearings out and soaking in fuel. The Main bearing appears to be fairly rusty. The engine has only been run for a lilttle less than 18 months. I use after run oil after each day's flying. Not sure why the bearings look that bad, but they do.
RC-Bearings has replacement bearings for the Magnum. Putting everything back together should be fairly simple.
Thanks for the advice.
Help! How do you remove the rear A-Arm Jato 2.5? seto Nitro and Glow Power Cars 0 Feb 26, 2012 09:28 PM
Sold Magnum XL 91 and XL 70 txshan130 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Oct 31, 2011 12:30 PM
Help! Magnum 70 XL 4-stroke problem big_poppa4904 Engines 26 Oct 03, 2011 03:05 PM
Discussion How long dose it take to run in a Magnum XL 91 RFS 4 stroke critter1340 Engines 18 Jun 28, 2011 02:54 PM
Question How to remove a crankshaft from a magnum xl .46? TrainerCrasher Engines 8 Jan 18, 2007 10:14 PM
