Old Mar 06, 2012, 07:00 AM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
Help!
Help finding part for TR-V7 1:16 Drivft Car
Hi.
I own this car
http://www.hobbyking.com/hobbyking/s...dProduct=20348
and broke this part
http://www.hobbyking.com/hobbyking/s...n_Chassis.html
It is not in stock as you can see,
Where can I buy a replacment ?
Thanks for helping bring my car to the road
Sharon
sharonx is offline Find More Posts by sharonx
Old Mar 07, 2012, 07:06 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Check a local hobby store to see if it's the same size as anything else, but otherwise hobbyking is pretty much your only bet.
wparsons is offline Find More Posts by wparsons
Old Mar 15, 2012, 12:11 AM
sharonx is offline
sharonx's Avatar
I got it from HobbyKing. I grabbed the last one (-:
Old Mar 15, 2012, 08:38 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Take the car to a local hobby store and see if they have a part that fits. Most of the cars from hobbyking are clones of name brand cars.
Old Mar 18, 2012, 08:38 PM
burnineyes is offline
Find More Posts by burnineyes
United States, FL, Seminole
Joined May 2009
Sharon,
I have an easy way to make proper parts if you have a few small hand tools, some brass tubing and a little patience.
This piece is called a dogbone. RC18T dogbones are a little too long and RC18R dogbones are a little too short, but if you can make one the correct length you will have an easy replacement part. I started with the RC18T dogbone, cut a few mm out of the center with a hobby knife. Then I found some brass tubing that fit tight over the cut digbone at my hobby shop. Drop some CA glue on the shaft and slide a piece of the tubing over it. If you have the correct size tube it will be as strong or stronger than before you cut it, and replacement dogbones are easy to find.
burnineyes is offline Find More Posts by burnineyes
Sold WTS/WTT 1/10 Slash Roller for 1/16 slash or rally zeroack Cars - Trucks and Parts (FS/W) 3 Jun 09, 2012 05:14 PM
Help! Help finding the source for video interference sharonx FPV Talk 20 Mar 21, 2012 01:39 PM
Discussion Help wiring BB gun to 1/16 tank roman1613 RC Tanks 5 Mar 05, 2012 01:19 AM
Wanted RC Car 1/36 , 1/24, 1/16, 1/12 , 1/10 thesoulcrusher Cars - Cars and Parts (FS/W) 5 Feb 20, 2012 08:41 PM
Discussion Help finding part for S031G the1inblue Coaxial Helicopters 14 Dec 27, 2011 08:55 PM
