Old Oct 18, 2003, 02:32 PM
GeeBeeFan is offline
Find More Posts by GeeBeeFan
The Faster the Better
GeeBeeFan's Avatar
Michigan
Joined Mar 2003
Question
1/4 scale Cub??
I'm looking into building a 1/4 scale Piper Super Cub, I have a really good reference...plans to build a full scale version! I would like to build it as authentic as possible but I'm running into a problem. Are there any flat four engines that look authentic and could carry a perfect scale cub? The only scale looking one I've found so far is the OS engine but I dont think its big enough to do the job. Any ideas? Thanks.
GeeBeeFan is offline Find More Posts by GeeBeeFan
Old Oct 18, 2003, 04:55 PM
Mike Smart is online now
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Do you mean the OS engine is not big enough power wise or big enough physically to scale.
As an example an OS Gemini twin cylinder four stroke will easily fly a 1/4 scale Cub.
Mike Smart is online now Find More Posts by Mike Smart
Old Oct 18, 2003, 11:14 PM
GeeBeeFan's Avatar
Michigan
Joined Mar 2003
Okay I dont know what I was smokin earlier! Sorry about that, I guess I just didn't realize the exact size of this cub. Now that I've done a bit of homework, I realize that the OS four cyl. is acctually a bit big! To use the OS engine, accurately; The plane would have to be something like 1/3.85 scale, or maybe it was just a mathematical error on my part. But none the less the OS engine would look decent in the cub. I'm not positive because I can never be sure whos measuring what, where, etc... You know how it goes. So do you think the OS four cylinder has the power to pull a fully detailed 1/4 scale cub? I know its a bit of an opinion question and that I will only truly findout closer to completion.
Thanks.
Old Oct 19, 2003, 11:09 AM
Mike Smart's Avatar
Joined Jan 2000
GeeBeeFan,
I don't think you would have any problem at all, unless you are going to build it out of oak
My own plan for a 1/4 scale Cub weighs in at around 12-14lbs and flys realistically on a .91 two stroke or 1.20 four stroke.
Old Oct 19, 2003, 11:23 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
A friend of mine had a 1/4 Cub (Plain Cub, not the Super) and his flew wonderfully on a OS 1.20 twin old vintage. Power of that one would be equivalent to a new .91 single 4stroke.
Haldor is offline Find More Posts by Haldor
Old Oct 19, 2003, 07:32 PM
GeeBeeFan's Avatar
Michigan
Joined Mar 2003
Okay, now that my little mathematical error has been sorted out, I only have one remaining problem....A 1,200 dollar problem! Now I just have to wait for OS to bring their price down a bit. Thanks guys.
Old Oct 20, 2003, 07:19 AM
Tim Jonas is offline
Find More Posts by Tim Jonas
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
I have the Sig 1/4 standard Cub with the OS FT160 twin in it. Very dependable engine which looks awesome in the cowl. It is much more engine than the plane requires, but it was well worth the expense.
Tim Jonas is offline Find More Posts by Tim Jonas
Old Oct 20, 2003, 09:42 AM
Citrorob is offline
Find More Posts by Citrorob
Citrorob's Avatar
The Netherlands
Joined Oct 2003
The OS engines are beauties but expensive, how about a 2T petrol engine?
Citrorob is offline Find More Posts by Citrorob
Old Oct 20, 2003, 11:29 AM
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
I've seen Zenoahs in Cubs, but you have to do an awful hack job to get it in the cowl.
Old Oct 20, 2003, 05:45 PM
GeeBeeFan's Avatar
Michigan
Joined Mar 2003
I know there's always a cheaper route. If I'm going to build this thing just like the real thing is built then I've gotta have an accurate, scale engine. Unfortunately, if I'm not mistaken, the OS 4cyl is the only game in town. So if there's a cheaper 4cylinder in the appropriate size range, PLEASE let me know!
Thanks.
Old Oct 21, 2003, 07:48 AM
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
I believe you are correct. Saito has twins and radials.
Old Oct 21, 2003, 08:42 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
For a 1/4 Super Cub I'd look close on this one : http://horizon.hobbyshopnow.com/prod...prod=SAIE182TD ($670)
A plain 1/4 Cub would be perfect for this :
http://horizon.hobbyshopnow.com/prod...?prod=SAIE100T ($500)
The bigger 4cyl 3.0 OS motor you're powerwise in the 1/3 scale domain ad its way too big for a 1/4 model of this kind.
Old Oct 21, 2003, 09:55 AM
Citrorob is offline
Citrorob's Avatar
The Netherlands
Joined Oct 2003
This 80cc twin from zenoah should do!
Rob
Old Oct 21, 2003, 10:04 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Yea an 80cc twin on a 1/4 scale cub. A 7.5 lb motor on a 10 lb airframe. Hmmmmmmmmm
Old Oct 21, 2003, 09:15 PM
GeeBeeFan's Avatar
Michigan
Joined Mar 2003
I have no problem up scaling my idea just to go that extra step. I know I'll probably never get around to building this thing but whenever I do get around to it I want the four cylinder! Putting a two cylinder engine in a scale cub is just not something that I dont want to do, my kind of scale is a little different than most people. Thanks for the advice.
1/4 Scale Cub - Wiring & Redundancy madkiwi Giant Scale Airplanes 13 May 29, 2004 06:54 PM
1/4 scale cub-ryobi 31cc highfly68 Giant Scale Airplanes 2 Feb 26, 2004 07:36 PM
1/4 scale cub - do I need 1/4 size servos? madkiwi Radios 5 Feb 21, 2004 11:43 AM
Sig 1/4 scale Cub and Astro 40G Matt Dyer Power Systems 7 Sep 06, 2003 04:28 PM
100 in 1/4 scale Cub w servos $275.00 GoodTill Aircraft - Fuel - Airplanes (FS/W) 1 Jan 18, 2003 08:25 PM
