Old Nov 12, 2012, 03:27 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Cool design, nice modeling.
Are you concerned about torsional flex on the long torque tube controlling the entire tip? It will certainly be good for low speeds but possible flutter at high speed.
You could try the prototype with the tip acting as both aileron and elevator and if some how too weak for elevator, then cut in elevator flaps elsewhere, but my money is on them providing adequate elevator control. This is a plank. They are quite pitch sensitive. It doesn't take much to throw them around.
Think of them as rudders at the tips. Imagine if they were both kicked up 1 1/2" at the TE. Wouldn't that produce lots torque to affect the pitch? It may not be "clean" but should be effective. Your 3rd image would produce nose down.
As always, I may be missing something here. Hope you build this one....very interesting.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Nov 12, 2012, 04:38 PM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
Kent
Yes, I want to lean real hard along with your thinking of the pitch sensitive traits of a plank wing, but to be on the safe side, and given this is a prototype, maybe I should just go ahead and add in the elevators (only 1 more servo needed) and fly it both ways. Like money, guns and lawyers, better to have and not need, than to need and not have.
Anyway, here is what I am thinking for elevators. Looks about right. Note that not all the ribs and such are drawn in yet - just for visual reference. Thanks for the kind comments. I do try with the CAD, being self taught and all, it's good to hear when others think I'm dong OK.
Oh, and I have been thinking about the twisting in the CF tube. At these lengths (~12") and weight, I don't think it will be much of an issue. Now going bigger and heavier, I will be looking at drill rod or custom CF / FG tubes built for torsional loading.
Mark
Quick61 is offline Find More Posts by Quick61
Old Nov 12, 2012, 05:19 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Sweet !....(and safe)
If that elevator was acting alone, it would probably be just big enough to get the job done. Assuming the CG is pushed way back.
If you happen to suffer from a need to know (as I do) you could program the tips to act as elevons and then add a program to drive the inboard elevator flap as a slave to the elevator function. Put that program on a switch and test fly with everything working. Once at a safe altitude, turn off the inboard elevator program and try to fly with just the tips as elevons.
This will be one cool little plane.
Kent
Old Nov 12, 2012, 06:03 PM
Quick61 is offline
Quick61's Avatar
Joined Jan 2011
Kent
Shiny, I'll get the rest of the parts drawn up, mod the ribs on the cut sheets and make a run at it.
Mark
Old Nov 23, 2012, 03:08 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Central fin on a plank.Is there a way to come up with an optimum size of fin area:wing area.Lots of variables I can see,profile,shape,position etc.The only figures I've found are "between .015 and .025"
Any thoughts?
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Nov 23, 2012, 07:40 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
stuart the articles from Peter Wick on RCSD explain all what you ask and bring some small formulas how to calculate them
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Nov 23, 2012, 11:05 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
EZ
Thanks EZ,took some interesting reading to find it but got there.As I expected,a lot of ifs and buts,but a quick run of the formula gives a close result to the above figures.
Regards Stuart
Old Nov 25, 2012, 05:31 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
First try at a fin.I'm going to have a go at a split air brake.Most of the examples I've looked at comment on a pitch up when they are deployed,so lowering the hinged area may help reduce this.
Bit more triangulation will let me get a good idea of the surface area.
Stuart
Old Dec 16, 2012, 04:48 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
After a bad dose of something or other,done a bit of fin and fuselage.Waiting for wings to arrive,so no final shaping till then.
I'm using Kents method,glassed foam plug,but I'm going to try dissolving the foam with acetone.
To fit some formers I was considering slicing the plug at the required positions,taking the former shapes and then tack glueing it back together.
If I did this,but took a 2mm slice out,then replaced it with a section of foam of the same thickness but 2mm smaller on the outer dimension,this would leave a groove in the reassembled plug.
Fill the groove(push the first layer of cloth in/ strip of cloth/carbon tow/ micro balloons,whatever's best)
When the foam is dissolved an internal flange will be left,adding stiffness and a fixing point for the formers.
The pic is a template I used to cut out the plug,the lines are positions for a hatch and battery bay.
Do you guys think this is a workable idea?
Regards Stuart
Old Dec 21, 2012, 10:39 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Did a trial.First pic.is the foam cut in 3places;horizontal for a hatch,depron spacer;l/h for a former position,depron spacer,r/h a former set in.Next is the grooves filled with tow,and then a couple of layers of light cloth spray glued on.
Last two are after the foam dissolved out.Very messy.
The fixed former worked well,the tow flange is a qualified success,a couple of places I didn't fill the groove quite enough and it hasn't adhered well.
With a bit of refinement I think formers and wing seat etc can be set into the plug this way
Old Dec 21, 2012, 12:17 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
I see that you have the loose tow fibers in a groove. I wonder if the tow could be better attached with spray adhesive? I haven't tried it yet, but thinking something along the lines of:
  • light spray of adhesive on the foam core
  • stretch the tow tight and press it into the adhesive
  • press with waxed paper, cure and remove paper
  • repeat for glass cloth
just a thought from the guy with miles of tow and who is looking for ways to use it.
Kent
Old Dec 21, 2012, 12:20 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Stuart
the reason for the pitch up during split rudder deployment is because those gliders have an inclined hinge line. As in backward leaning hinge line. If there was a forward leaning hinge line, there would be a nose pitch. A vertical hinge line will produce a neutral pitch response.
Kent
Old Dec 21, 2012, 12:46 PM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
Kent
I vote for the height of the drag from the split rudder above the CG:
http://www.rcgroups.com/forums/showp...43&postcount=6
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Dec 21, 2012, 01:23 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Kevin
I was toying with the idea of drawing an arc from the cog to the line of the hinge,but I still can't figure out the optimum angle.
Stuart
Ill have to study the Drela link
Old Dec 21, 2012, 01:39 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Kent
The idea was to make an internal flange as a stiffener,hence the groove.Not sure if I'll go that route,the ply former worked really well.With a bit of planning it should be possible to pre-install all the formers into the fuse plug before glassing.
I'm still waiting for the wing cores,so can't go much further.
Stuart
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1163 Yesterday 11:37 AM
Absalut Build Thread (Q&A) tomi Hand Launch 211 Sep 05, 2005 08:01 AM
A new 100% EPP foam Scram-Blur J-250 build/Q&A thread sylair Foamies (Kits) 48 Jan 22, 2005 02:22 PM
