Old Jun 07, 2012, 09:05 AM
Knoll53 is online now
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Originally Posted by Stupot46 View Post
Kent,carbon rod/strip would be simple to do,but wouldn't I need some sort of taper?
The EPP slope guys would suggest no.
Kent
Knoll53 is online now Find More Posts by Knoll53
Old Jun 07, 2012, 09:57 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Stuart,
Just to build on Kent's idea, why not taper the number of pultrusions? - 1 all the way to the tip, 1 half way out, 1 to quarter semi-span - that sort of thing would work. You mention needing strips longer than 1m; do you need to take the spar all the way to the tip? Probably not... Especially if you're only talking about finishing it a few inches shy of the tip.
Richard
Shedofdread is offline Find More Posts by Shedofdread
Old Jun 07, 2012, 10:45 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Sooo......if I used say 1.5mm rod(I'm looking at the XVIII wing here)would I lay these side by side,top and bottom?Seems to me that would be strong enough with the skin.
Maybe a single length on the Colibri style wing?
Kent,that is one BUSY forum!I did a search on it for carbon spars,loads of results which I have only skimmed the surface of.You don't have a link to the relevant info by any chance?Carbon ribbon gets quite a few mentions,any thoughts on it's use?
A more immediate problem is foam supply.Called Knauf this a/m looking for a stockist of 1200x600x52.5 30kg board to be told they no longer make the stuff.It has been replaced by 60mm which Wickes etc aren't going to be stocking.Warrens do 30 kg in 50mm which would be ok,just makes life awkward if I try to use two thicknesses in the same build.The search continues.
Thanks again for the advice,
Regards Stuart
Stuart A is offline Find More Posts by Stuart A
Old Jun 07, 2012, 11:40 AM
Derbyshire, UK
Joined Aug 2008
Have you tried Sheffield Insulations? The nearest, I think, would be the branch on Sheffield Parkway. They are IIRC Dow stockists so you can get the blue stuff rather than the peach coloured stuff. Far more suitable for a chap's aeroplane...
Old Jun 07, 2012, 12:00 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Thanks Richard,on the list.Current favourite is encon in Leeds.They list Knauf 30k space board,hopefully they'll have some.I just need a couple of sheets to do this build and then I can change to a different spec.
Anyway I like Peach.Shows off my complexion.
Stuart
This is an interesting one- www.kbpackagingandinsulation.co.uk.Looks like they do hot wire cutting,I'll have to send in a mole.
Old Jun 07, 2012, 01:25 PM
less is more
Knoll53's Avatar
Joined Sep 2006
I may have sent you astray
Check this link
Flat carbon starts out at about 1/32" thick.
Kent
Old Jun 07, 2012, 01:56 PM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
Kent,carbon rod/strip would be simple to do,but wouldn't I need some sort of taper?(going on the TLAR principle )
Stuart
Tapered CF laminates (strips):
http://www.cstsales.com/carbon_Laminates_tapered.html
Dr. Drela's sailplane designs use these for wing spar caps.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Jun 07, 2012, 02:01 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Thanks Kent.I've ordered 10x1m lengths of 1.5mm rod off eBay at about half lhs price,so I'll go with that on this one.I still like Verns tow either side of the hinge line;this is all preparation,plenty time to consider options.Once I get the foam sorted it'll be back to the VII
Regards Stuart
Old Jun 08, 2012, 06:43 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Kevin
Thanks for that K,I'll have a search for similar this side of the pond.they would be ideal,not bad prices either.
Regards Stuart
Old Jun 08, 2012, 07:09 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Found Some Foam!!!!!
2@2400x600x65 30kg £27.50 plus vat.Encon in Leeds,so not far to travel.
PEACHY!
Stuart
Old Jul 04, 2012, 01:56 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
I had to pick up some electrical gear today,so I added a dimmer switch to
the order.
The set up works ok,next I need to try some different wire gauges.A trial with the tapered wire idea is also on the list.
I also need a small one handed bow,the one I have (700 mm) is a bit unwieldy for smaller work.
Stuart
Old Jul 04, 2012, 04:27 PM
less is more
Knoll53's Avatar
Joined Sep 2006
I also use a dimmer switch to vary voltage on my home brew hot wire set up. Can fine adjust for any length wire.
Kent
Old Jul 04, 2012, 04:57 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Kent
You don't happen to know the gauge and type of wire you use?Mine is nichrome,but I've had it so long I've forgotten the gauge
Regards Stuart
Old Jul 04, 2012, 10:27 PM
less is more
Knoll53's Avatar
Joined Sep 2006
I use soft stainless steel aircraft safety wire. .020" dia. No complaints.
Kent
Old Jul 05, 2012, 12:24 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Thanks Kent.I've ordered some 0.5mm soft s/s,equivalent size.Loco1 used .3 for his taper so this should be ok for that.
Regards Stuart
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1157 Yesterday 09:16 PM
Absalut Build Thread (Q&A) tomi Hand Launch 211 Sep 05, 2005 08:01 AM
A new 100% EPP foam Scram-Blur J-250 build/Q&A thread sylair Foamies (Kits) 48 Jan 22, 2005 02:22 PM
