Depends on dihedral - and twist really. On a clean flying wing you could assume that the center of drag is somewhere about the AC on the MAC. If the wing has a lot of dihedral then down thrust would help because the drag production is probably centered above the center of the motor. Also the natural twist will produce a nose up moment when speed increases - (ie at higher power setting) so down thrust can help with that as well.
Since Richard posted the drawing of the HoXVIII I've bee wondering how I could build this wing,one of my favourite Hortens,without paying for cad work.I've done measuring on the plan of the VII,and think I could adapt it.
My question is,would these airfoils work if blown up 50 or even 100%.At the larger size,which I would prefer,the centre would be 840mm long and 120mm at it's thickest point. I'm thinking foam,a two piece centre section split down the centre and each wing done in 3 sections.This would make the cutting easier and should give me a reasonable facsimile of the twist.The finished plane would be in 3 sections with the outer wings attaching at the u/c legs. Stuart |
This is the revised drawing.Not the best pic,but I think it shows where I'm going with this.I intend starting cutting this as soon as the VII is a compete airframe, as a time filler.The bigger sections will be good practice before I have a go at a Colibri.
So- does the panel think this will work aerodynamically? I would appreciate comments,as I don't want to spend time makings drawings to be blown up if this is not a practical project. Regards Stuart |
At a loose end today,can't get any gear till Tuesday(the lhs guys go flying sun/mon-what's the world coming to!)
So I did a drawing to get a sense of the size of this beast.All the measurements taken off the iPad screen;I just stretched the half span to 12cm and went from there. I slimmed the wheels a touch,and I need to check the u/c angle off a bigger printed copy,otherwise it looks ok. I should be able to get a max.60 mm edf in the nacelles so power should be adequate.Good wheel bearings and a firm tyre methinks. Not quite as scary as I thought it might be;just the pylon design to work out. Regards Stuart |
Joined Jul 2009
Stuart ...
I leave you alone for 5 minues and now its a jet powered rocket sled .... . So let me get this straight, you have drawn one pod and it has TWO EDF bolted to it?? is this right or am I interpreting the drawing wrong as this would mean the other wing will have the same for a total of 4 EDF??EDIT, oh I totally forgot on page two is where this rocket is heading sorry about that Stu, man that would be awesome if you can get her to work. !! Jens |
| Thread Tools | |
| Discussion Banana Hobby Customer Support Request/Q and A Thread! | banana hobby | Banana Hobby | 1022 | May 24, 2013 05:23 PM |
| Absalut Build Thread (Q&A) | tomi | Hand Launch | 211 | Sep 05, 2005 08:01 AM |
| A new 100% EPP foam Scram-Blur J-250 build/Q&A thread | sylair | Foamies (Kits) | 48 | Jan 22, 2005 02:22 PM |
