Old Mar 11, 2012, 01:07 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Subscribed.
Brian
cpdude is offline Find More Posts by cpdude
Old Mar 25, 2012, 06:22 AM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
Evening all well I've been doing lots of filling and sanding the last couple of weeks of the fuselage to clean things up after paint stripping. So tonight I set about glassing in some honeycomb corematt between the fin and some 1 1/2oz tight weave glass cloth to remove the oilcanning of the fin, this in turn allows me to fill and sand the fin before spraying on the two pack epoxy primer and sanding again...... and so on and so on......
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Mar 26, 2012, 04:07 AM
Joined Jul 2004
Well the corematt was a partial success, stiffer than it was but not as stiff as I'd hoped for but usable.
In hindsight I think I would have been better off using some 6k carbon twill..... Oh well, live and learne.
Old Mar 28, 2012, 12:54 AM
Joined Jul 2004
So while feeling a little better today having survived a bad dose of gastro the day before and with the sun beaming down I set about and primed the wings to the ASW 22 with two pack epoxy primer, marvelous stuff this. Once cured for a few days I'll attack the wings with a 16"air file fitted with 120 grit paper, followed buy primer cure and wet rub with 600 grit wetn dry used wet. If all is well then I start the next process..... cutting out both flaps and facings.
Think I need to go back to bed now.....
Old Mar 30, 2012, 06:03 AM
Joined Jul 2004
Started the sanding process tonight and after an hour of sanding 95% of the first side is now looking like this, all I can say is thank G*D for power tools!!
Old Mar 31, 2012, 05:19 PM
Gudmund is offline
Find More Posts by Gudmund
Joined Mar 2005
A huge model... :-)
Is it this one?
ASW22 1/2 Scale Radio Controlled Glider (1 min 10 sec)
Gudmund is offline Find More Posts by Gudmund
Old Mar 31, 2012, 05:33 PM
Joined Jul 2004
Hi Gudmund this was the model before being shipped to me for a redesign and refit.
Old Apr 01, 2012, 05:24 AM
Gudmund is offline
Joined Mar 2005
I guess there`s not many of them around..
Old Apr 01, 2012, 06:29 AM
Joined Jul 2004
To the best of my knowledge the last and only one.....
Old Apr 09, 2012, 01:33 PM
Gudmund is offline
Joined Mar 2005
A absolute ripper project... And subscribed
The one and only
Any progress lately?
Old Apr 09, 2012, 07:20 PM
Joined Jul 2004
Hi Gudmund I'm afraid I've been a little slack the last week on the ASW 22 but I have secured a tow plane in the form of a 45% CA models Edge 540 including all the gear to run the model including pilot. She should be back together in the next week or two while workng on the 22.
Old Apr 10, 2012, 11:20 PM
SZD16 is online now
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
That doesn't look like a 22.......8-)
SZD16 is online now Find More Posts by SZD16
Old Apr 11, 2012, 03:42 AM
Joined Jul 2004
Well you did ask what I was going to tow the ASW 22 with.....
Old Apr 16, 2012, 01:48 PM
Joined Jul 2004
Did some more work on the 22 last night, nothing overly exciting, more sanding to the wings, do next up with the good weather coming this Wednesday on Anzac day I'll reprise the wings and the fuse before starting the wet rub process and then the real fun begins....... Cutting out the flying surfaces and facing.
Old Apr 16, 2012, 03:04 PM
yyz is offline
yyz
Find More Posts by yyz
yyz
yyz's Avatar
USA, CA, Paso Robles
Joined Dec 2004
It's looking good! What are your plans for treating the exposed sides of the wing and control surface once you make the cuts?
yyz is offline Find More Posts by yyz
Sold Turnigy nano-tech 22.2v 6s 45~90C 3300mah Lipo Packs / $50 Each Shipped leespaddock Aircraft - Electric - Batteries & Chargers (FS/W) 5 Mar 06, 2012 07:26 PM
Forsale 4-meter ASW 22 robdoyle Aircraft - Sailplanes (FS/W) 4 May 14, 2004 09:23 AM
HELP! How do I set the Correct CG on my ASW-22? marmal43 Electric Sailplanes 0 Aug 08, 2001 02:33 AM
