Old Mar 05, 2012, 11:28 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
Question
I have a tail mold, now some questions
I was lucky enough to get a two piece cnc routed tail mold. Lots of curves in the outline. I've tried several things, but not having a cnc router to cut the cores, hand sanding isn't working well. While I can get close, and compress the foam with the molds during the build, it looks to me like the foam is compressing and then expanding a bit. So I'm not happy.
I thought I'd try bagging a thin piece of foam into each half of the mold, hot wiring it after it sets up and then joining them in the mold.
What foam can I hot wire, that also wont compress and expand? Is rohacell the only foam that has that wont expand? I understand if it dents that hot water wont cause it to expand.
Alternate methods would be considered, but I'd like to try this.
Gary
GaryO is offline Find More Posts by GaryO
Old Mar 06, 2012, 02:29 AM
chetosmachine is offline
Find More Posts by chetosmachine
chetosmachine's Avatar
Madrid, Spain
Joined Sep 2004
You can't hotwire rohacell! Or at least that's what I've seen a number of times.
Why don't you do a sandwich layup, with thin 1mm rohacell between light glass layers and apply vacuum?
chetosmachine is offline Find More Posts by chetosmachine
Old Mar 06, 2012, 08:10 AM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Gary, rather than hot wire the excess, try sanding it off. Tail feathers are small, so it won't be too big a job. Just tape off the flange area of the mold, and use a light touch.
Ward
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Mar 06, 2012, 12:34 PM
GaryO is offline
Joined Sep 2001
A sandwich layer would end up with a hollow vertical? Its a dlg. And if you can't hotwire rohacell, how do you get it 1mm thick? I didn't think it came in that thickness.
Ward, are you referring to rohacell for sanding or a foam?
Gary
Old Mar 06, 2012, 03:39 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Rohacell can be purchased down to fractions of a mm.
I used to hand-shape all cores. If doing it with vacuum, you want to use 6mm lower density XPS like 15psi pink or blue and bag it into each side. Hotwire / sand to the parting plane and add some splooge around the LE/TE then compress. If you sand the cores flush, cover the parting plane with tape or something else thin so it protects from scratching and leaves the foam a couple thousandths proud.
Hotwiring leaves the foam a couple thousandths shallow, which must be filled with a light splooge mix. Kerf is evil in this situation.
tom43004 is offline Find More Posts by tom43004
Old Mar 06, 2012, 03:42 PM
San Diego
Joined Mar 2003
Gary, I was saying you could use a sanding block to sand either a Rohacell or foam core half down to the mold flange.
Here is a thread that Fairlyfaded had where he was selling rohacell in either 1 or 1 1/2 mm thickness.
http://www.rcgroups.com/forums/showthread.php?t=1544867
Old Mar 06, 2012, 07:38 PM
GaryO is offline
Joined Sep 2001
Tom,
Did you try a product called cell80 or something like that? Is that a Depron like foam?
Gary
Old Mar 06, 2012, 11:02 PM
samc99us is online now
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Fairlyfaded hasn't returned my questions on Rohacell. Besides, you need ~3mm for tails, not 1mm.
Tom is using Cell Foam 88. I am going to give the sanding method a try with 15 psi XPS or regular Depron. That will be in 1 week at the earliest.
-Sam
samc99us is online now Find More Posts by samc99us
Old Mar 07, 2012, 02:01 PM
ptxman is offline
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
I used steel feeler gauge stock for this operation. Its very hard (I think high carbon steel) nominal 1/2" wide. You can get it down to low-thou thicknesses in lengths or even rolls from machining supply places. Just light 3M spray tack it on the flange so it stays put, do the sanding, then pop it off or use a little alcohol on the edge so it doesnt bend or kink. With steel you wont ever have to worry about sanding through it & scuffing up the mold flange.
ptxman is offline Find More Posts by ptxman
Old Mar 07, 2012, 03:02 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Basic question.
I missed something basic about your method here Gary.
You say you have a mould, but then you want to CNC cut foam cores?
Are you describing a hollow moulded flying surface build or a vacuum bagged over foam core surface?
Or some sort of hybridisation of the two techniques?
Maybe the cores you refer to is the core in the composite skin sandwich?
Jim.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Mar 07, 2012, 05:33 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Jim, DLG tails are so thin that hollow construction is impractical. They are typically a solid shaped core.
wyowindworks is offline Find More Posts by wyowindworks
Old Mar 07, 2012, 08:56 PM
Joined Aug 2008
Thanks Adam!
Old Mar 07, 2012, 10:37 PM
GaryO is offline
Joined Sep 2001
To elaborate: If a full core can be made, either by cnc routing or hand sanding, then the tail is made by putting skins an spars into the mold (epoxy also), joining the mold around the core and applying pressure. Tom Siler has some great video of making tails in molds on the hlg forum. Well worth watching.
Tails can also be made by forming foam in each half and trimming to the surface of the mold. If the skins weren't applied to each side, then the rest of the process could be similar to the above process. I'd guess that applying the skin to each half core , trimming and then joining the halves might work better, but just don't know.
Old Mar 08, 2012, 02:39 AM
Madrid, Spain
Joined Sep 2004
2 parts then join will be far worse than 1 piece core. Been there, donde that.
Depron, or xx psi foam, wil be far weaker than rohacell (at same density!).
If you want "A class" tails, 1 piece milled cores is the way to go.
If you just want tails, 2 piece core is convenient. But they are heavier and weaker.
Old Mar 09, 2012, 07:51 AM
tom43004 is offline
tom43004's Avatar
Joined May 2002
+1
Been there, done that too but if you don't have a machine for cores it's do-able. I have also hand shaped rohacell and cellfoam cores for solid core molding. The hand shaping seems like it would be a lot of work, but it really isn't. I can make cores faster by shaping by hand than by running my CNC... but they're a bit more oversized, which means more foam compression, which means more core weight.
Question Some questions that have not been answered topforce Multirotor Talk 2 Dec 21, 2011 03:34 PM
For Sale New JR Tail Servo Now Have Pics A&J Aircraft - General - Radio Equipment (FS/W) 0 Nov 02, 2011 05:25 PM
Discussion Have Mold Now What? sporter Composites Fabrication 39 Jan 27, 2010 09:23 PM
Just flew my e-starter for the first time, now I have some questions. _Lunchbox_ Electric Plane Talk 29 Sep 22, 2005 08:12 PM
New YS .63, have it now, and have some questions.. DsWright Engines 12 Jul 23, 2005 11:26 PM
