Old Mar 05, 2012, 09:43 PM
seasan is offline
Find More Posts by seasan
seasan's Avatar
China, Guangdong, Shenzhen
Joined Feb 2012
FLYCOLOR 10A-40A Quick-Response ESC
The application of ESC:
Three-axis/ Four-axis/ Multi-axis aircraft;
Unicycle;
Medical ventilator drive;
Industrial Quick-response control;
Other products demand for quick response .
Electric performance parameters of ESC:
Input Voltage:2-4s Lipo or 7-16V DC voltage
Continuous output current:20A
The maximum allowable instantaneous current (10s):25A
BEC output:5.5V/3A(SBEC) or 5.5V/0.5A(OPTO)
Standard:UBEC 5V/3A or OPTO 5V/0.5A
Shape and weight of ESC:
Size(L*W*H):54mm*25mm*11mm
Weight:30G(with BEC),28G(OPTP)
Shape and installation position can be changed according to demand .
The main features:
Quick response:The speed of response is ten times faster than the ordinary ESC.
Exquisite control:The accelerator is more exquisite than the ordinary ESC. The speed control increased substantially.
High sensitivity: The rate of speed for the same motor different ESC is substantial increase. The same control pulse width and the gap of Rpm is very small.
Good compatibility :Compatible with existing ESC' s interfaces .
High efficiency for high-hen quick response capacitance.
Standard configuration:
Power line length:100mm
UVW line length:80mm
UBEC:5V/3A
seasan is offline Find More Posts by seasan
Old Mar 10, 2012, 02:59 AM
seasan is offline
seasan's Avatar
Joined Feb 2012
To give myself a support,(*^__^*)
Discussion Servo / 6ch Reciever / ESC - Response Issues AZA9156 Electric Plane Talk 6 Jul 18, 2014 10:33 AM
Discussion Rctimer 40a V2 esc Sympster Power Systems 2 Feb 26, 2012 07:24 AM
Sold Turnigy K-Force 40A ESC and Programmer Box harcocjh Aircraft - Electric - Power Systems (FS/W) 2 Feb 25, 2012 02:23 PM
Sold HobbyWing Platinum-40A-PRO Brushless ESC for Trex 400/450 helifreak592 Aircraft - Electric - Helis (FS/W) 0 Feb 24, 2012 04:31 PM
Sold ESCs 40A,20A,10A darmar Aircraft - Electric - Power Systems (FS/W) 1 Feb 02, 2012 10:08 AM
