Old Mar 05, 2012, 09:24 PM
mudcan is offline
Find More Posts by mudcan
Joined Apr 2011
control line
is there a guide as to the length the control lines should be? i am running .049, and 098 and was wondering.
mudcan is offline Find More Posts by mudcan
Old Mar 05, 2012, 10:15 PM
The Kiwi is offline
Find More Posts by The Kiwi
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
.049 engines vary widely in performance
The most common ones were made by L M Cox Company as Babe Bee engines, and related engines included in Cox RTF planes. These are ordinary small motors and 30' of line is about right for those.
Some of the very best of the .049s were also made by Cox, and were called "TeeDee" model engines. They will pull 35' of line fairly easily. Sold at costs of nearly ten times as much, several extremely high powered .049s have been made that are flown with 42' lines (I am thinking of one made by "Fora" in eastern Europe).
The only ".098s" that I ever heard of weren't as good for power as the TeeDee .049s (although Cox Company made a pair of excellent .09s). I'm thinking specifically of the .098s made by McCoy back in the early 1950s. They were really weak sauce, so about 35' of line for those.
Kiwi
The Kiwi is offline Find More Posts by The Kiwi
Old Mar 05, 2012, 10:48 PM
mudcan is offline
Joined Apr 2011
line length
good info, no sense trying to pull 45 ft then.
Old Mar 06, 2012, 03:45 PM
gcb is offline
gcb
Find More Posts by gcb
gcb
Joined Sep 2008
What engines are you running, and what diameter 45' lines?
A Tee Dee .049 should pull .008 x 45' lines OK.
A Tee Dee .09 can handle .012 x 52' lones OK in most appropriate airplanes...it has the power of an older .15. So should most .09 diesels.
If you are running an old engine like the McCoy .098 or an OK Cub .09, the 45' lines should be appropriate.
As Kiwi already said, most Babe Bees, OK Cubs, etc. would be better with 30'-35' lines.
The real answer can only be seen by trying. If you are inexperienced, go for the shorter lengths. You can try longer lines later.
George
gcb is offline Find More Posts by gcb
Sold Vintage J. Roberts 3-line Flight Control PLUS Bell Crank Units NIB wfortney99 Aircraft - Fuel - Airplanes (FS/W) 3 Oct 01, 2011 09:32 AM
Sold Vintage T/F Gieskie Nobler Control Line Kit wfortney99 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 30, 2011 08:34 PM
Discussion Ornithopter on a control line? mrexcel Ornithopters 15 Sep 26, 2011 09:03 PM
Discussion My first control line flying micro_builder Control Line 15 Sep 22, 2011 10:04 PM
Sold Vintage J. Roberts 3-line control line Flight Control & Bell Crank Units NIB wfortney99 Aircraft - General - Miscellaneous (FS/W) 2 Jul 03, 2011 09:10 PM
