This thread is privately moderated by wamsy55, who may elect to delete unwanted replies.
Old Mar 07, 2012, 10:21 AM
Professional Toothpick maker
nalby's Avatar
USA, NY, New Hampton
Joined Jan 2005
Great job you really explain the maneuvers well. Thanks
nalby is offline Find More Posts by nalby
Old Mar 07, 2012, 10:57 AM
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Great job on the ones I've seen so far Wamsy! Can't wait to get back inport to see the latest.
Eagle34 is offline Find More Posts by Eagle34
Latest blog entry: Landing by Ben Fisher
Old Mar 07, 2012, 11:06 AM
VOLTS > AMPS
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Originally Posted by UCDme3D View Post
Can you develop a reccomended order in which you learn maneuvers? I know everybody takes their own route, but it would be helpful to list what comes first in your opinion.
One turn spin
Loops
Rolls
Elevators
Parachutes
Inverted harrier
Harrier
Ke spins
Tumbles
Mastering the basics helps a lot, understanding stall and spins helps with harriers, and learning elevators will transition into harriers, can't do rolls? Well you wont be able to master rolling harriers. I put tumbles at the end as they are easy to do and like me you will probably find yourself doing them all the time
stgdz is offline Find More Posts by stgdz
Old Mar 07, 2012, 01:03 PM
too busy looking forwards
theKM's Avatar
central PA.
Joined Sep 2004
many people still jumping up to the hard stuff... like Wamsy, jumped straight to rollers before the usual progression of maneuvers
...but in general, what has been a good order of progression...
- solid foundation: loops, axial rolls, immelman turns, and cuban eights, stall turns
- moving on: snaps and tumbles, four point rolls, spins
- adding complexity: slow rolls, longer point rolls (stretch the four point rolls, make them 8 points, etc), and try to add precision to maneuvers (loops are to be round as possible, everything on a line, etc)
- add the 3D: elevators > harriers > harrier turns > inverted harrier
- some more fun: KE spins, waterfalls
- keep practicing the slow and point rolls, then start to try rolling maybe circles, or slowing the speed of the plane to try rolling harriers
...that would be the general recommended progression by the old-school. flesh out and play with other maneuvers as they come along. many people see they want to string maneuvers together one after the other, it's an easier thing to do if you have a solid base on the more traditional maneuvers.
theKM is offline Find More Posts by theKM
Old Mar 07, 2012, 01:26 PM
blueapplepaste's Avatar
United States, TX, Keller
Joined Jul 2009
I'd just add that what helped me was flying precision a lot more. Being able to draw big lines really helped me to make minor corrections and fine tune my fingers to put in smaller more precise inputs.
Also really learning to use your left thumb as well. I spent a lot of flights just in KE at all different orientations, rolling into KE from different orientations, etc to really get used to inputing in rudder from all sorts of different orientations.
Other than that, nothing beats stick time.
blueapplepaste is offline Find More Posts by blueapplepaste
Old Mar 07, 2012, 03:10 PM
Team 3DHS
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
Originally Posted by Irg View Post
great work, wamsy.
I'd love to see one on snaps .
Will do though will take some time.
I really like this idea.
Good info.
I plan to make a video on the topic.
wamsy55 is offline Find More Posts by wamsy55
Latest blog entry: 72" Extra Flying
Old Mar 07, 2012, 03:25 PM
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Great Stuff, don't forget Knife Edge flight across the field "both" ways. I am getting better with rollers but still struggle with knife edge straight lines.
The best thing about these videos is there is more to learning them than what stick positions you need to be in. That's the perfect world - learning them is not perfect.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Mar 07, 2012, 06:28 PM
Stuck in a tree
ARaviator's Avatar
Clarksville, AR
Joined May 2009
subscribed! Thanks to everyone for great tuts, vids, and general help!!! Kudos all!!!
ARaviator is offline Find More Posts by ARaviator
Old Mar 07, 2012, 07:29 PM
Joined Aug 2009
Thanks!
pete_g is offline Find More Posts by pete_g
Old Mar 07, 2012, 08:27 PM
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
subbed. Wamsy is the man.
djmoose is offline Find More Posts by djmoose
Old Mar 07, 2012, 09:39 PM
Team 3DHS
wamsy55's Avatar
Joined Jan 2009
New tutorial is under the works. Its going to over some cool turnaround maneuvers.
Should be up either tomorrow or Friday. Just depends on if I get distracted by plane building or not.
Old Mar 07, 2012, 09:54 PM
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
Wow - I just started to post someting about that... brilliant. Quality turnarounds just make everything look better! Nice going and all the best
uptime4downtime is offline Find More Posts by uptime4downtime
Old Mar 07, 2012, 11:13 PM
Support Your Local Hobby Shops
Nashville, TN
Joined Feb 2005
aero104 is offline Find More Posts by aero104
Old Mar 07, 2012, 11:51 PM
Australia, NSW, Sydney
Joined Sep 2011
Ahhh mode 2 :P
bwbkx125 is offline Find More Posts by bwbkx125
Old Mar 08, 2012, 04:59 AM
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Has a good point regarding mode
May be helpful to offer this out for our down under friends that use mode 1 - it is easily done through playback as you just change the mode on the TX
Space Bat is offline Find More Posts by Space Bat
Mini-HowTo Nitroplane's 3D-Hawk PNP (They say ARF) Tutorial Dellagd 3D Foamies 41 Sep 09, 2011 08:00 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Question Brushless Tutorial/Help Thread? thatchf137 Power Systems 0 Jul 31, 2004 01:24 PM
