This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Old Mar 05, 2012, 04:03 PM
unclegeorge is offline
Find More Posts by unclegeorge
Trader Rating: 241
unclegeorge's Avatar
United States, FL, Sarasota
Joined Feb 2005
Trader Rating: 241
Sold
JT-100 Falcon Turbine from Jet Central never flown
Here is the last version of the JT-100 Falcon Turbine from Jet Central. It has been replaced by the new JFV-100 Rabbitt.
This Turbine has never been installed or flown in a plane.
This Turbine is complete with everything you need to run it.
New price was $2,795. I will sell it to you for $1,800 ship Priority Mail inside the US. Super reliable, hassle free, best value motor with unmatched performance in its class at 22 lbs of thrust. Ideal for Rookie, Gripen,etc .Designed to run at lower rpm, with low wear and extended service time; rapid acceleration times, giving you more thrust at the lower RPM settings. The fastest accelerations in its thrust class.
Engine ready for installation, with the newest in ECU's.
All motors tested at over 6000 ft.
Specs:
Thrust: 10 Kg (22 Lbs) @ 122,000 RPM
Idle Thrust: 0.40 Kg (0.88 Lbs)
Weight: 1.400 Kg (3 Lbs), including starter
Diameter: 98 mm (3.86 inches)
Length: 300 mm (11.8 inches), with starter
RPM Range: 35,000 - 122,000 RPM
Exhaust Gas Temperature: 650°C
Fuel Consumption: 0.27 Lt/min (9.1 Oz/min. avg.)
Fuel Types: Jet A1, 1-K kerosene
Lubrication: 2.5% Synthetic 2T Turbine Oil
mixed in the fuel
Maintenance Interval: 25 hours
JF-100 FALCON Turbine Complete Set with Auto Start includes:
• I.C.S1 (Intelligent Control System)
• HDT (Hand Data Terminal and Programmer)
• Fuel pump
• Electronic starting gas valve
• Electronic fuel valve
• Fuel tubing, tubing connector set, filters, and cable set
• TBM 4-cell, 4800mAh Li-Ion battery pack
• Starting gas tank
• Turbine SAFETY mounting clamps
• Detailed instruction manual
• Case
Manuel: http://www.troybuiltmodels.com/newsi...tesMfalcon.pdf
PM me if you want a new turbine at a great price!!!
Please give me your mailing address and please refer to the item you are buying in the “Subject line” along with your mailing address in your Pay Pal purchase. My account in Pay Pal is under uncgeorge@comcast.net
Uncle George
unclegeorge is offline Find More Posts by unclegeorge
Old Mar 06, 2012, 12:24 PM
Dr Honda is offline
Find More Posts by Dr Honda
Trader Rating: 19
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
Trader Rating: 19
I see you have 2 threads with the same engine... but one is closed. Did it sell, or do you have 2?
Dr Honda is offline Find More Posts by Dr Honda
Old Mar 07, 2012, 06:10 PM
Trader Rating: 241
Joined Feb 2005
Trader Rating: 241
I just have the one, are you interested in it???
Old Mar 13, 2012, 07:18 AM
Dr Honda is offline
Trader Rating: 19
Dr Honda's Avatar
Joined May 2004
Trader Rating: 19
No. I've decided to head a different direction. (Sorry)
Sold JET CENTRAL SUPER EAGLE Turbine Engine - $1500 Shipped CONUS chw757s6640 Aircraft - Fuel - Jets (FS/W) 1 Sep 21, 2011 09:31 AM
Sold Never Flown Nitroplanes 72" WingSpan Hero Eagle 100 (Cessna 550) Twin Jet $475 Shippe FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 1 Sep 06, 2011 03:55 PM
Sold Jet Central JF-100 Falcon gjhinshaw Aircraft - Fuel - Jets (FS/W) 0 Apr 16, 2010 11:05 PM
Wanted Swap or sell Jetcentral Falcon JF 100 Titanium turbine for Jet Central Rabbit Mavrik Aircraft - Fuel - Jets (FS/W) 0 Oct 29, 2008 05:11 AM
