Old Mar 06, 2012, 01:57 AM
Afraidtoregister is offline
Find More Posts by Afraidtoregister
Looking4Grass in AZ
Afraidtoregister's Avatar
United States, AZ, Mesa
Joined Feb 2011
Oh oh oh, I forgot one other thing. Motors have both a max amperage and max wattage rating. You shouldn't go over either by putting on too large of a prop.
And I'll use examples to explain C ratings of batteries, as I can't think of the words and that's my excuse for not knowing everything.
1800mAh battery rated at 40C discharge and 5C charge
1800mAh = 1.8Ah (duh)
1.8Ah x 40C = 72A discharge rating
1.8Ah x 5C = 9A charge rating
800mAh battery rated at 15C discharge and 1C charge
800mAh = 0.8Ah
0.8Ah x 15C = 12A discharge rating
0.8Ah x 1C = 0.8A charge rating
Your discharge rating matches up to what your motor can pull. So you make sure your battery has a discharge rating higher than what your motor pulls. You find out what your motor pulls by hooking up a meter between your battery and ESC. Your charge rating tells you how quickly your battery manufacturer says you can safely charge that battery. So you tell your charger to never go higher than that. Battery makers pretty much all also say if you go over a 1C charge rating that you may shorten the lifespan of your battery.
I have 2 chargers running off of a 10A power supply. So I never tell a charger to go over 4.5A to be safe from my stupidity. I change the rate for each of my batteries. All of my big batteries run at 4 - 4.5A and so they get charged at 2-3C. My smaller batteries I charge from 3-5C and are all rated for it. But it's ok because if they die, small batteries cost $4-6 so I don't care. It all works out.
I have these Turnigy NanoTech 1300mAh batteries, and these are the stats:
1300mAh = 1.3Ah
1.3Ah x 45C = 60A discharge
1.3Ah x 10C = 13A charge
They get charged at 4.5A and it goes faaaast. So charge rating is important if you like batteries that charge fast. Sky Lipo = 3C charge, GensAce = 5C charge. Tunigy Nanotechs are rated high like 8-10C, but who knows if that's real or not.
Afraidtoregister is offline Find More Posts by Afraidtoregister
Old Mar 06, 2012, 05:08 AM
skrez is offline
Find More Posts by skrez
Joined Dec 2004
Originally Posted by twiztidbowler View Post
Thanks for this link, I`m going to try some of these since the blue lipos are out of stock at Hobbypartz.
Frank
skrez is offline Find More Posts by skrez
Old Mar 06, 2012, 05:25 AM
Stuey is offline
Find More Posts by Stuey
Aylesbury,UK
Joined Apr 2000
I have just bought a couple of Gens Ace 2600 25c packs to try instead of 2200's. They are the same size as my Loong Max 25/30c packs, except for being about 1/4" longer. They are also about 20 grams heavier.
Stuey is offline Find More Posts by Stuey
Discussion Fatshark Dominator Sold out everywhere?! heinduplessis FPV Talk 11 Apr 14, 2012 07:25 PM
Wanted ImmersionRC 600mW vTX - sold out everywhere Adroc3905 FPV Equipment (FS/W) 4 Feb 23, 2012 06:18 PM
Discussion Where can I find SKY LIPO 2200mAh 3S 11.1V 30C battery? All sold out??? h8tow8 Batteries and Chargers 4 Jan 22, 2012 05:22 PM
Sold 2 Electric Power 3s 20-30C 2200mah 11.1v Lipos (for T-REX 450) ShokWaveRider Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 01, 2011 04:37 PM
Sold NEW E-POWER 3s 2200mah 20-30C Lipos punkindrublik Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 28, 2007 12:44 AM
