Old Mar 05, 2012, 01:45 PM
eMoon is online now
Find More Posts by eMoon
I meant to do that
eMoon's Avatar
United States, NY, Albany
Joined Sep 2011
Looking for a Flat Foamie Project
Hi All,
I did a quick search and found some potential options for what I'm looking for but:
I would like to find a set of plans or ideas for a flat foamie build to use a Hextronic 24 gram 1500Kv motor and 2s 800mAh lipos. I found some options for the motor but they all need 3s lipos. A 4-channel with ailerons would be preferred as well.
Would you guys be so kind as to point me in a direction for a 2s bird?
eMoon is online now Find More Posts by eMoon
Old Mar 05, 2012, 02:15 PM
Jsutherland8 is offline
Find More Posts by Jsutherland8
ELECTRIC R/C
Jsutherland8's Avatar
Canada, ON, Woodstock
Joined Feb 2006
I have been flying a Flatana by Great Planes w/ BL 2208/14, 1450kV and a 25 (30)Amp ESC, 3S 800mAh LIPO. This combo is ok in NO wind or indoors. The small diameter of the carbon rods lets the wing flex too much in any wind, or hard fast pullout. It has been a good plane for the price, ($35) but after 2 years and close to 100 flights it is stressed out. It took way too long to build and had poor assembly instructions. After running a beed of polyurethane glue into all the edges it was ok to fly. The RX, ESC, motor, and servoes are all ok, so I am also looking for a new body or whole plane to fly 3D with.
I got a 5.5mm 31" ws, blue foam short kit off a local club member, and have seen the same model fly at our Indoor Fly-in, and it works well. The BL2208/14 may be too much motor for this one, But I will try it and see.
There is a pic of a F-22 with mid mount motor 2800 Kv, fun but not real 3D.
Jsutherland8 is offline Find More Posts by Jsutherland8
Old Mar 05, 2012, 04:02 PM
hankg is offline
Find More Posts by hankg
Lost but making good time
Joined Nov 2008
new,
Try this one... a little different but flys really well.
Regards,
Hankg
hankg is offline Find More Posts by hankg
Old Mar 06, 2012, 08:12 AM
eMoon is online now
I meant to do that
eMoon's Avatar
Joined Sep 2011
Thank you for the suggestion. Looks nice.
Anybody else have a suggestion for comparison/discussion?
Ok, did a bit more digging and stumbled on this thread...seems like a good fit even though not a flat foam, but it's flat enough and looks way cool. http://www.rcgroups.com/forums/showt...0#post11738182
Discussion Flat Foamie Series from RA Cores coreman Foamies (Kits) 156 Jun 22, 2015 07:25 AM
Question Looking for a flat 3S 11.1V LiPo with medium-high capacity.. ZSimon Batteries and Chargers 1 Sep 12, 2011 06:16 AM
Deadline extended for the flat foamie video contest Dave Lauck Site Chat 0 Sep 16, 2005 05:53 PM
New idea for flat plate foamie fuses rcmann Foamies (Kits) 0 Feb 08, 2004 12:49 PM
