Old Mar 05, 2012, 12:52 PM
snauwaertj is offline
Find More Posts by snauwaertj
ASK 21 Jet glider
Hello,
I have buided a ful GFK ask 21 with a span of 5m66.
To power it I installed a Jetcat P160 on its back and mounted a piece of thin inox metal plate on the tail to absorb the heat a bit.
Yesterday I have made a few testruns with the engine and it seems that the tail is getting realy hot, I measured 92°C with the engine running on idle for less than one minute.
I have seen already a few big scale gliders with a jet on their back, how come they do not get to hot?
What can I do?
I added a few pictures to show what I mean.
Description:
Description:
Best regards Johan
snauwaertj is offline Find More Posts by snauwaertj
Old Mar 12, 2012, 09:42 PM
tjp is offline
tjp
Find More Posts by tjp
tjp
TJP
United States, NY, Syracuse
Joined Mar 2008
I have seen gliders that big fly with just a P60. I think you have way to much engine.
Search RCU's jet section and you will find info.
Tom
tjp is offline Find More Posts by tjp
Old Mar 13, 2012, 01:49 AM
jofro is online now
Find More Posts by jofro
Joined Jan 2010
Sorry my friend but it's simple common sense not to place your power unit where it is! Try to fit it to some twin boom design unless you like to melt Rudd. fin. Few years back at Avalon Air Show was a pilot with full size glider having twin 160's or 200's in the same position but lot higher and did some spectacular demo flying. Obviously the distance from his units to the fin was lot larger to worry about the heat, and having the twin the exhaust was not directly at the fin.
I built two large " foamies" powered by jet turbines and managed to prove to all sceptics it can be done but the design is totally different then your scenario, Joe.
jofro is online now Find More Posts by jofro
Old Mar 14, 2012, 12:45 PM
hmarmaizmd717 is offline
Find More Posts by hmarmaizmd717
Joined Jul 2007
Maybe you can ask Ali Machinchi about it. He's flown them before.
hmarmaizmd717
hmarmaizmd717 is offline Find More Posts by hmarmaizmd717
Old Mar 14, 2012, 05:32 PM
jofro is online now
Joined Jan 2010
hmarmaizmd717
Next time you are in the kitchen put your hand on 92deg.C hot plate and see how long you can keep it there? It's only an idle! Joe.
Old Mar 14, 2012, 08:13 PM
causeitflys is offline
Find More Posts by causeitflys
THAT'S WHY
causeitflys's Avatar
Eastern Ohio
Joined Aug 2004
I think that most angle the engine slightly to avoid the vertical damage. A slight angle wouldn't be noticed in the flying.
causeitflys is offline Find More Posts by causeitflys
Old Mar 17, 2012, 10:38 AM
yakhakker is offline
Find More Posts by yakhakker
still trying to get it right
yakhakker's Avatar
Belgium, Région wallonne, Tournai
Joined Feb 2009
Yep I think you are way over powered there, be careful with the throttle if you are going to fly it also check out the structural integrity of the plane to be sure it can handle the forces being put upon it.
It is possible to put 3 or 4 degrees of side thrust without it having much of an effect
Good luck.
yakhakker is offline Find More Posts by yakhakker
Old Mar 17, 2012, 11:18 AM
THAT'S WHY
Eastern Ohio
Joined Aug 2004
Tom
I don't think a P-60 would do on a 17ft glider
Old Mar 17, 2012, 03:19 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
I wish I had that much money.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Mar 17, 2012, 07:00 PM
Paul Wilson is offline
Find More Posts by Paul Wilson
I can 3 point
Paul Wilson's Avatar
Mount Dora Florida
Joined Aug 2002
Most of the 7metre 50pound avg flying weight fly on a jetcat 120 / 26lb thrust that I have seen. That means if yours is 5.66 m , then about 13 0r 14 pounds thrust such as a jetcat p60 sounds about right. . The 160 is the same size and weight as the 120 but has a higher egt.
You do however seem to have the engine mounted in the correct position, just too much of an engine, that is all.
good luck
Paul
Paul Wilson is offline Find More Posts by Paul Wilson
Old Mar 17, 2012, 07:07 PM
I can 3 point
Mount Dora Florida
Joined Aug 2002
This is Als 7 metre ask21 with jetcat 120, perhaps Jofro hasn't seen this configuration before, the central mount is quite common in fact. It is much bigger than yours and the lower egt and larger distance to the tail will keep heat down. As I said earlier, the p60 has a lower idle egt than the 160, 580C vs 650C and a lower idle thrust, .8 lbs vs 1.0lb. That would reduce the heat substantially.
http://www.alsgallery.co.uk/view_alb...lbumName=ask21
Old Mar 22, 2012, 05:42 AM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
how about making your own jet exhaust....divide into 2 exits one either side with a slight outward direction?
socommk23 is offline Find More Posts by socommk23
Old Mar 22, 2012, 07:06 AM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
Because they are loud, and you loose thrusts.
There is nothing wrong with the way it is. A few degrees on the engine mount will keep the tail from burning. (or a little foil tape)
Dr Honda is offline Find More Posts by Dr Honda
Old Mar 22, 2012, 02:26 PM
John Wright is offline
Find More Posts by John Wright
United Kingdom, Harleston
Joined May 2004
If you want a better material than the stainless sheet you have used then this is what you need for the fin.
http://www.zircotecshop.com/
Colin Straus used it on his Paritech 7m 1:2 scale Fox glider that is powered by a P120.
It is now common to have the engine offset slightly so the engine airstream does not hit the fin and so reduces temperature.
I have used the ceramic aluminium foil on my glider and have no problems with the heat.
John Wright is offline Find More Posts by John Wright
Old Mar 24, 2012, 03:10 PM
DreamArcher is offline
Find More Posts by DreamArcher
DreamArcher's Avatar
Joined Apr 2008
I assume you mean static test runs and not actual flights since you said the engine was idling. In flight you would have cold air mixing with exhaust going over the tail. Static you only hot exhaust... or almost all host exhaust. Likely the tail won't get as hot in flight. But that's all theoretical.
DreamArcher is offline Find More Posts by DreamArcher
New Product E-Flite UMX ASK-21 glider fragje Micro Ready-to-Fly 2557 Apr 12, 2016 08:00 AM
FAQ AS3X airplanes FAQ (Gee Bee, Beast 3D, Taxi, Mig 15, ASK-21 glider, Spitfire and Cub) RealGambler Micro Ready-to-Fly 1254 Aug 01, 2015 12:07 PM
Discussion Hobbyking ASK 21 2600mm Glider - good for first glider Charlescd Electric Sailplanes 27 Apr 26, 2012 12:47 AM
Discussion UMX Scale ASK-21 Glider interplanet Sailplane Talk 17 Feb 09, 2012 02:38 PM
Discussion ASK-21 Glider Murocflyer Sailplane Talk 2 Nov 26, 2010 04:42 PM
