Old Mar 05, 2012, 12:01 PM
andrewho83 is offline
Find More Posts by andrewho83
United States, CA, SF
Joined Jan 2012
Can you recommend a Slow Stick Setup?
My friend and I are looking to get into the sport of RC airplanes. Have only had some experience in RC helicopters.
I've done some research and there are many options for beginning RC airplanes, but as someone who likes to fiddle and tinkle, I've chosen the GWS Slow stick as my beginner plane.
Can anyone offer a good setup for the slow stick? I can buy the kit, but I also want something that can last me for a good year and future use. I want to be able to attach a camera, and fly with it.
I am known to shoot for the moon and miss all the asteroids along the way, and if this is too far fetched for me at this point, please let me know !
Hope this isn't TL;DR
andrewho83 is offline Find More Posts by andrewho83
Old Mar 05, 2012, 12:09 PM
HeeBeeGeeBee is offline
Find More Posts by HeeBeeGeeBee
Lysdexic I'm
HeeBeeGeeBee's Avatar
Spring, TX
Joined Oct 2010
There's already a HUGE thread on this plane for every mod and setup you can think of...
http://www.rcgroups.com/forums/showthread.php?t=407136
Good Luck! You'll love it.
HeeBeeGeeBee is offline Find More Posts by HeeBeeGeeBee
Old Mar 05, 2012, 12:34 PM
Joined Jan 2012
Thanks for the links !
Is a Ember 2 from Parkzone comparable ?
Old Mar 05, 2012, 01:36 PM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
No. Ember is an ultra micro, the Slow Stick is much larger. If you have the room to fly it, get the Stick!
http://www.radicalrc.com/search/slow.../searchCat/249
You can build a sweet Slow Stick that's 100 times the plane the Ember is for the same price, or even less.
shunyata is offline Find More Posts by shunyata
Old Mar 05, 2012, 03:15 PM
tdogg77 is offline
Find More Posts by tdogg77
Joined Dec 2006
http://www.planeinsanerc.com
This guy has everything you need including detailed Slow Stick build instructions with photographs of every step.
tdogg77 is offline Find More Posts by tdogg77
Old Mar 05, 2012, 03:24 PM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
Always nice to find a new source, but they don't have a single Slow Stick in stock.
Old Mar 05, 2012, 03:34 PM
Lysdexic I'm
Spring, TX
Joined Oct 2010
www.caliberhobby.com
and
www.gorillabobsrc.com
are a couple more worth looking into.
Gorilla Bobs has all the Millinium Gear and SS goodies as well.
Old Mar 05, 2012, 03:53 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
that's $30.00
http://www.headsuprc.com/servlet/the...K--dsh-/Detail
get the parts you need as well. from him if you like the SS Will not cost you an arm and leg. enjoy.
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Mar 05, 2012, 04:11 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
I'm about to go fly my Slow Stick right now
My current setup is a Suppo 2217/8 outrunner, GWS HD9050 prop, 18A ESC, 3S 1800mAh 30C lipo, and two old JR micro servos. Very powerful beasty.
I've flown many, many other motor/prop/battery combinations as well... This is just the latest.
Piece is offline Find More Posts by Piece
Old Mar 05, 2012, 04:37 PM
Rockin Robbins is online now
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
Wow C14, same size motor, totally opposite characteristics as mine! I have 2217/20 motor, 896 kv, 11X4.7SF prop, 40A ESC. I'm high thrust/low speed. You're the other way around, churning those high rpms for more speed.
The Slow Stick truly is the everything plane! It is what you build it.
Rockin Robbins is online now Find More Posts by Rockin Robbins
Old Mar 05, 2012, 04:45 PM
Byrdman is offline
Find More Posts by Byrdman
Winter Haven FL
Byrdman's Avatar
Joined Dec 2003
What ever you do, get a 28mm 150-200 watt motor with an aluminum stick mount. Although the cheap bell motors will power it just fine, the winding wires are thin and can break on hard landings.
IMO, the Slow Stick is "THE" best trainer I have ever flown. Good choice!
Byrdman is offline Find More Posts by Byrdman
Old Mar 05, 2012, 06:42 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Andrewho83,
In my idea it's better to use the following power set up if you are a beginner.
Motor: 400 or 450 size motor with about 1000KV
Prop. GWS EP9050
ESC: 20 - 30Amp one, the 30A one is better.
Battery: 3S 2200mAh 20C Lipo, 1500mAh one works well too, but 2200mAh one will give you more flight duration, and you'll find out that battery in this size is cheaper on markets.
Chen
twn Chen is offline Find More Posts by twn Chen
Old Mar 05, 2012, 08:42 PM
Joined Mar 2009
I completely agree. 200W at about 860 kv and a big slow fly prop is a great combination for a Slow Stick! Alternately you can go with the smaller diameter prop with more pitch and get a completely different kind of beast with a higher kv motor of the same wattage.
My Turnigy 2217-20 motor is 860 kv, puts out just about 200 watts at 18 amps with an APC 11x4.7SF prop and a Turnigy Super Brain 40A ESC plus Rhino 1350 mAh battery. 20 minute flights. Verticals accelerating all the way to terminal velocity of about 30 mph. It's a great match for a SS at a super low price.
Old Mar 05, 2012, 09:45 PM
Fredriksson is offline
Find More Posts by Fredriksson
Just having fun
Fredriksson's Avatar
United States, KY, Hopkinsville
Joined Feb 2008
I prefer a bigger slow flyer prop on my Slow Stick. I use a $12Turnigy 2209 26turn 1130kv 15A Outrunner motor with a 25 amp ESC on 3S 1300mAh LiPo spinning an APC 11x3.8SF prop. this system pulls 14 amps at about 150 watts. The prop spins at 6700 rpm. I set my timer for 15 minutes but the data says I could fly for up to 20 minutes without using more than 80% of the LiPo.
Really, any motor that you can get hooked up to the SS that is around 1000kv on 3S LiPo and can handle 15 amps will work well. The SS will fly on less too.
Nice, fun plane. Mine is 5 years old. It was my original trainer.
Freddy
Fredriksson is offline Find More Posts by Fredriksson
Old Mar 05, 2012, 11:10 PM
Joined Jan 2012
Thanks for the suggestions everybody. I cant wait to order it and fly it !
Discussion What batteries and charger do you recommend for this setup? POS2012 Multirotor Talk 6 Apr 23, 2012 10:21 PM
Help! Can you recommend a replacement kit for this battery/use? 5311 Batteries and Chargers 0 Oct 04, 2011 05:58 AM
Sold GWS Slow Stick RC plane RTF LPU only for $40!!! or parts can ship MJB9 Aircraft - Electric - Airplanes (FS/W) 2 Sep 27, 2011 10:16 AM
Discussion Can you recommend a slow, durable yard flyer? HeliDrew Parkflyers 25 May 30, 2011 08:59 PM
Discussion Slow Stick setup, can I get you guys to check this? Hellbore Parkflyers 3 Jul 13, 2007 11:02 AM
