Mar 09, 2012, 07:07 PM
Marysville, Ca., US
Joined Jan 2007
Originally Posted by 824TSV
The issue that concerns me is when you switch to rate mode your basically turning the gyro off. Your rudder servo should return to centre without giving any rudder inputs. If it's not doing that, there is an issue you havn't found.
Not quite right. First you have to understand what they mean by "heading hold" and "rate" modes. Heading hold says if something blows the tail, measure how much it moved, and move it back to where it was as best you can. (Nothing's perfect.) Rate mode says if something blows the tail, detect the rate of change and adjust to make the rate of change zero. A gyro in heading hold will try to do just that, hold the heading you set until you change it. A gyro in rate mode merely tries to catch the tail and stop it from moving more. It has no concept of where it started, so it doesn't try to move you back to your original heading. That's why moving a stick on an initialized gyro in HH, or moving the heli, will cause the tail servo to slowly drift all the way to one side or the other. Jasmine's explanation is spot on, so no need to repeat it here. Since rate mode only seeks to stop rotation, moving an initialized gyro, or moving a stick, only causes a momentary movement of the servo, after which it returns to center. After all, sitting there, the heli's rotation rate IS zero.
As for which is easier, most who fly scale like to fly in rate mode, as the tail will "weathervane" to some extent behind the heli in a turn, without requiring much rudder to keep the turn coordinated. In Heading Hold mode, turns require rudder to keep the turn coordinated, and it takes more effort to make the turn look smooth.
