View Poll Results: With the impending release of the Tempest, what Dynam Warbird would you like next?
Bristol Beaufighter 14 13.33%
Bf 110 26 24.76%
Curtiss P-40 8 7.62%
P-38 Lightning 10 9.52%
Mitsubishi Zero 16 15.24%
de Havilland Mosquito 15 14.29%
Grumman F7F Tigercat 16 15.24%
Voters: 105. You may not vote on this poll
Old Nov 28, 2012, 11:25 PM
Warbirds and More Warbirds
Whitey22's Avatar
United States, GA, Dahlonega
Joined Aug 2012
rehafner like the poster above you said in wing guns did not appear in the 109 after the E model all the pics on the link you gave were of an E (note the small pointed spinner) almost all including the Dynam model 109's are G models (large rounded spinner) these as far as I know never had in wing mounted guns though they did have hard points under the wing for gun pods I believe.
And I have to agree Merlin I would kill for a Dynam Tempest or Typhoon just gotta love those large intakes under the cowl
Whitey22 is offline Find More Posts by Whitey22
Old Nov 29, 2012, 03:36 PM
Addicted to Warbirds
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
The Dynam Corsair is a really nice plane. It flies super. Better performance than I got from their 109 and 190 models. The shorter gear retracting towards the rear is much more forgiving and durable than the gear in either of the models mentioned above. This is a great size too.
scootrb4 is offline Find More Posts by scootrb4
Old Dec 03, 2012, 12:50 PM
Just throw it up!
Merlin Power's Avatar
Australia, VIC, Melbourne
Joined Jul 2011
I was checking out the 109, 190 and Corsair at my local hobby shop who stock all of the Dynam planes and who have all of them on display.
I must say that I was impressed with the corsair. It is a fine looking plane. I am torn between the 109 and the corsair.
And I hope that Dynam is working on their new Tempest/Typhoon as we speak.
I would be happy to test and prototypes for you Dynam if you are reading this! Haha.
Merlin Power is offline Find More Posts by Merlin Power
Old Dec 03, 2012, 01:25 PM
scootrb4's Avatar
Joined Nov 2011
I have had all three of those and they are all NICE flyers... Had because I was foolish enough to fly the 190 in the fog and the blue gray devil, well, you know... I think I read you have had them also? This new Corsair is just great. A bonus is it is a very good slow flyer too.
Old Dec 03, 2012, 07:30 PM
320pilot's Avatar
Joined Mar 2009
Too lazy to keep trying the search function for Dynam ME-109. the big one, 1270 mm wingspan.
Nitroplanes have it on sale for $129. With a discount code I can get it for $140 shipped. Code is CYBERWK10 for 10% off.
http://www.nitroplanes.com/60a-dy8951-bf109-arf.html
Is it worth it? Looks nice and big, but I guess it's beer-cooler foam? Are the retracts, gear setup worth the trouble?
I have the E-flite Sea Fury and the PZ P-47, both great flyers.
Any comments/advice welcome.
ps. finally found the ME-109 thread here.
http://www.rcgroups.com/forums/showthread.php?t=1645020
320pilot is offline Find More Posts by 320pilot
Old Dec 04, 2012, 08:50 AM
scootrb4's Avatar
Joined Nov 2011
It has been a fun plane for me. The weak point has been the LG. The struts are weak and anything less than a perfect landing may bend the struts. To straighten the strut you do one of 2 things.
Remove them and hold the motor case in a vise & bend the strut. The foam mounting in the wing is not strong enough to hold up to repeated manual bending of the LG (my opinion). Later I slotted a heavy piece of metal which the base of the strut could be slipped into and then bending was done against the metal piece. (not my idea- works great)
It is a really nice flying plane and a better pilot would not have had so much LG trouble.
Fit and finish was good. Hard to see in a gray or blue sky ...
Old Dec 31, 2012, 03:28 PM
United States, IL, Aurora
Joined Oct 2012
Can a dynam f190 be flown with a 3cell 2200/2650 11v battery?
john97618 is offline Find More Posts by john97618
Old Dec 31, 2012, 04:57 PM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
I would not try it. It would be very slow and on the egde of stall speed IMO. With the 500 KV motor its not the fastest on 4S.
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Jan 04, 2013, 03:14 PM
Joined Oct 2012
I have questions about the dynam f190. I am new to building these planes and got this for Christmas.
I t came with two tubes of glue. The instructions don't say anything about where to use the glue only one spot and that is gluing the plastic hold down for the back of the wing where the screw goes into hold the wing to the fuselage. Where have you gents been using glue on this plane.
I also have a t28 by dynam which I bought used. It takes a 3cell 11.1 2650mah battery. I am a little frustrated that now I have to buy another set of batteries that are 4 cells. I posted earlier and was told that I shouldn't use a 3cell because it wouldn't be powerful enough. Opinions please.
In regaqrds to a 4 cell, is it ok to have a larger mah rating than the 2200 the specs say?
Old Jan 04, 2013, 03:27 PM
Nebby58's Avatar
Joined Dec 2012
Where are you ordering your batteries from? If you look at the original listing on Nitroplanes, they have two aftermarket batteries that work for the t-28. Sky lipos I believe. As for the 2650mah, I just ordered one, so I hope it works!
Nebby58 is offline Find More Posts by Nebby58
Old Jan 04, 2013, 04:00 PM
Joined Oct 2012
I have batteries for the t28 and they are 2650mah and work ok. It's the fw190 I am asking about larger mah than the book says. The book says 2200 and I am asking if I can go with a larger mah rating than that. And an opinion on using 11.4 volt 3 cell instead of 14.8 4 cell on the fw190.
Old Jan 04, 2013, 04:09 PM
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Both tubes of glue are the same, they are a rubber cement type of glue. It works, but you may consider using an alternative.
As far as the difference between the T-28 and the FW-190, the power systems are completely different. The T-28 (and P-51, AT-6, Spitfire) use the 820kv motor/30A ESC/11x7x3 prop combo and it was designed for 3 cell batteries. These were the warbirds that were released last year. All of the newer warbirds that have been released this year (FW-190, BF-109, Corsair, P-47, etc) use a 500kv motor/40A ESC/13x7x3 prop and it was designed for 4 cell batteries.
Now, you can use 4 cell batteries on the T-28 system if you upgrade the ESC to at least a 40A unit. Then you could use 4 cell batteries on it and your FW-190. As far as sizes go, you can go higher. I plan on getting some 3000mah 4 cells later this year for my birds as I would like a little more flight time that what the 2200mah's offer. The battery compartments can definitely accomodate it
Kman
kman24 is offline Find More Posts by kman24
Old Jan 04, 2013, 05:24 PM
Nebby58's Avatar
Joined Dec 2012
Hey guys! I own a Dynam T-28 Trojan, and I just ordered the Dynam P51D! Very excited for the P51 after seeing how nice of a finish the T-28 had. Did they change the pilot from it's original? Or does it still have a civilian pilot?
Old Jan 04, 2013, 05:26 PM
Flying from Vic Park
Australia, SA, Adelaide
Joined May 2011
Yes you can use a larger mah battery than the spec say. The mah rating will only effect your flight times and AUW (hence CG) it does not impact on the motor and ESC.
With my Dynam Spitfire the recomended battery 3s 2200mah I changed to 4s so I had upgrade the ESC to 50amps as the motor draws 32 amps on 4s whereas on 3s the draw was 22amps. I wanted longer Flight times so I had use a battery with a higher mah rating. I switched to zippy 2800mah 4s they weigh about 60g more than the 2200mah the only changes where to enlarge the battery bay by removing some foam and adjusting the CofG to allow for the extra weight..
Great_Goose is offline Find More Posts by Great_Goose
Old Jan 04, 2013, 07:19 PM
Joined Oct 2012
But where did the glue get used on the fw190. On the wing halves?
Discussion Dynam PBY Catalina Owners Thread. Orion Pax Electric Warbirds 4419 Today 04:44 PM
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1687 May 15, 2013 01:43 AM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 216 May 04, 2013 06:03 AM
Discussion fms warbird owners thread warbird_cowboy Electric Warbirds 115 Mar 05, 2013 05:09 AM
Question Dynam Warbird Retracts fuzzyhead Electric Warbirds 16 May 04, 2012 06:10 PM
