Old Sep 28, 2012, 05:19 AM
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
im limited to around 220-230grams this battery http://www.hobbyking.com/hobbyking/s...dProduct=21347 looks good perfect weight and its a zippy compact my local warehouse just sold out so i will have to buy from the international warehouse if they dont sell out before i place my order ill test that pack and report back
gazza2003au is offline Find More Posts by gazza2003au
Old Sep 29, 2012, 01:36 AM
thanks for your help, guys
brickie89 is offline Find More Posts by brickie89
Old Sep 29, 2012, 03:53 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
I've been using packs in that range and either side of and all have performed well. Only failure so far has been due to crash damage breaking of a tab from a cell and nothing left of tab to solder back to ! Was not batterys fault !
Nigel
solentlife is online now Find More Posts by solentlife
Old Sep 30, 2012, 09:59 AM
Sydney, Australia
Joined Jul 2003
i can run two packs of the 1500 4S zippy compacts vertical in my model they just fit and it balances so thats running a 3000 4S yeahhhhhhhhh baby just ordered 6 more packs of these batteries
Old Sep 30, 2012, 10:38 AM
Shut up and fly
papabatman's Avatar
United States, CO, Firestone
Joined Jun 2008
i got a 5000 a few days ago have ten flights on it numbers a 3,3,5,4 so i think that makes it a true 15c
used a icharger 106b
papabatman is offline Find More Posts by papabatman
Latest blog entry: on/off switch
Old Oct 09, 2012, 12:27 PM
Graham Dyer
pardus's Avatar
Johannesburg, South Africa
Joined Jul 2003
My four 5000mAh 3S packs have just hit 25 cycles each, three have puffed a bit and the fourth feels like it's going to soon.
All charges are done @ 0.7-1C to 12.6V on a Turnigy 200W charger, discharge always to minimum 10.4V under load (3.46V per cell, measured with telemetry).
About 70 of those 100 cycles have been in a quadcopter drawing 18A in the hover with up to 40A with full power climb out. Max current draw has been 60A (12C) in a big EDF with which I've had 6 flights. The packs have only been a little warmer than skin temperature even after the 60A.
They still take ~4000mAh on recharge which is 80% and seem to perform fine except the puffing which is a bit disapointing as there's been no abuse.
Edit: Note I fly at 1550m (5000ft) altitude, not sure if that has an effect on the the likelyhood of puffing?
pardus is offline Find More Posts by pardus
Old Oct 09, 2012, 01:01 PM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
good report thank you
Old Oct 09, 2012, 01:07 PM
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
My two 4s 2200 35C packs continue to please. Probably about 30 cycles on each, pulling about 50 amps or 23C each flight. I charge to 4.18V/cell and discharge to around 3.75V/cell. I've heard that the cheaper packs (Zippy, Turnigy, etc.) don't tolerate being discharged much below 3.7V/cell. I have always babied my cheap packs in this respect and generally get hundreds of cycles out of them before they poop out.
fishboy77 is offline Find More Posts by fishboy77
Old Nov 13, 2012, 02:00 PM
Joined Oct 2009
I use a 6S 3700mah 25C in an EDF.
Voltage drops considerably to 21V on a fresh battery with just a 65amp load.
On the plus side, it was cheaper than a comparable nano-tech and my flight times went up...
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Jan 14, 2013, 02:40 PM
United Kingdom, England, Stokeinteignhead
Joined Apr 2008
Just ordered 3 3600 5s for my edf. I will let you know how they go.
autoquip is offline Find More Posts by autoquip
Old Jan 29, 2013, 03:54 PM
Graham Dyer
pardus's Avatar
Joined Jul 2003
My four 5000mAh 3S packs have just hit 35 cycles each. In my quadcopter using ~17A in the hover, packs 1&2 take around 3400mAh flying to 10.5V (3.5V per cell - 12 minutes), packs 3&4 take around 2800mAh (also to 3.5V per cell - 9 minutes).
My old Turnigy's hit ~3500mAh @ 175 cycles in the same circumstances, so these 25C Zippy Compacts are utter junk. Don't know about the higher C ones but stay away from this 25C 5000mAh version at all costs!
Old Apr 28, 2013, 10:56 AM
Joined Oct 2007
hello,
last month, I received two 5800 zippy compact, one 4S, one 5S, there is an increase in weight,5S, 715grs vs 655 grs one year ago, cells are thicker.
Capacity has not improved , I got 5720 mAh/3.3V cut/"old" cell and the new one, 5500 mAh...
My next batteries will not come from HK...
brushman is offline Find More Posts by brushman
Old Apr 30, 2013, 03:04 PM
Syracuse, NY (USA)
Joined Dec 2004
Which Turnigy exactly?
I bet a thunder power would be fine after 100+ cycles, so paying 3x more for a 3x better battery might be worth it. The new 3900 and 4400mahr G8's are tempting.
This thread is "worrisome"...can't have multi-rotors (with expensive cameras onboard) falling out of the sky!
Block is offline Find More Posts by Block
Old May 03, 2013, 10:16 AM
Syracuse, NY (USA)
Joined Dec 2004
Seems the 35C compacts get good reviews (in this thread) but the 25C are iffy. The 35C Zippy Compacts are not exactly light though, and cost more, so the "regular" lipos (nanos for example) become an option too.
Alert HK buddy code for Zippy 5000mah 45c 2s1p lipo wagondriver42 Racing Boats - Electric 0 Feb 28, 2012 03:00 AM
Wanted XT-60 connectors and 4s 2200mAh 30-40c lipo's (pref Zippy) Keenan smith Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 20, 2012 09:49 AM
Sold 2 Zippy FlightMax 6s1p 2650 LiPo's donpzal Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 12, 2012 03:07 PM
For Sale Xtreme blade 120sr motor & 3 zippy lipo's heliguyhigh Aircraft - Electric - Helis (FS/W) 1 Jan 05, 2012 08:23 PM
Discussion Zippy Lipo's.....any good. stuart warne Batteries and Chargers 27 Aug 13, 2008 02:22 PM
