Old Jul 01, 2012, 01:03 PM
fishboy77 is online now
Find More Posts by fishboy77
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
I can't comment on longevity, but I just did a few static tests to see how well they hold voltage. I have two 4s 2200 35C Zippy Compact packs and compared them against a 4s 2200 25C Gens Ace. The ZC packs have about 5 cycles on them. I just bought the Gens Ace pack used. The seller said it had about 10 cycles on it. Anyway with a load of about 55 amps (25C) the ZC packs did just slightly better than the GA pack. That says a lot since the GA packs are well known to be excellent. The ZC packs are also about 20 grams lighter than the GA. I'm attaching the Eagle Tree file of the test. The first two packs are the ZCs. The last is the GA. Packs were charged in parallel to ensure that they all started with the same voltage.
fishboy77 is online now Find More Posts by fishboy77
Old Jul 01, 2012, 01:13 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
I dont have any graphs, but my 4s 2200 25c gens ace have more punch then my 4s 2200 25c zippy compacts, but I can feel a huge weight difference in the air, i am a 3d fixed wing flyer and the compacts fly way lighter, in my opinion they each have there advantages, we just need to see how they last.
keithy4129 is offline Find More Posts by keithy4129
Old Jul 01, 2012, 02:11 PM
motogman is offline
Find More Posts by motogman
Joined Mar 2007
Thanks guys they sound promising then, but longevity is what I'm after, I'm currently running 14s 10,000 mah zippy 20c in a 37% plane and they are fine, hovers at half stick, but after a year are puffing. I'm looking at the 7s 5800 mah 25c packs should only be about 8 ounce additional weight gain but in theory should give me 90 more pulling amps and at least 1.5 more minute flights. So anyone have the larger packs with more then 50 cycles any reports?
motogman is offline Find More Posts by motogman
Old Jul 03, 2012, 09:08 PM
wingster is offline
Find More Posts by wingster
Massachussets
Joined Nov 2005
Just received two 5s 25C 5000 packs that I'm going to run as 10s in a pattern plane.
After first charge one pack had cell Irs between 3.0 and 3.2mohm and the other between 2.9-3.2 mohms at 68F as measured on .PL8. That puts them in the same range as Hyperion 25c 5000 and Rhino 20C 4900. Looks like they fall short of the Gens Ace 30C 5300 which run between 1.6-2.1 mohm per cell.
584g and 588 with Deans connectors.
Overall not bad. I'll report back after a full breakin.
wingster is offline Find More Posts by wingster
Old Jul 03, 2012, 10:50 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
wingster, check the IR after 10 cycles. It will go down. Also, pretty good for 67F IMO. My tests showed my 25C rated packs to be true 25C cells.
Rick
rampman is online now Find More Posts by rampman
Old Jul 10, 2012, 11:11 PM
rchelijc is offline
Find More Posts by rchelijc
Pro beginner
rchelijc's Avatar
Melbourne, Australia
Joined Aug 2010
I bought 4 of the 2200 35C 3S Zippy Compacts. It's undergoing stress testing, and used for:
1. Protos 500 6S (2x3S) - Hover draw around 15A continuous, probably over 80-100A spikes
2. 58" Plank on 6S (2x3S) - Static WOT ~45A
3. 48" Foamie on 3s - Static WOT ~52A
Obviously the hottest application is the Protos.
Testing: Ambient around 8-12degC. Lipos pre-warmed to around 25degC
They come down about 25-30degC in the protos.
In the 58" plank testing,and my version of lightly pushing the pack reduces flight time from 12 mins to 8mins.Packs came down cooler than when it first started, something like 18-20degC.
In the 48" foamie, temps was the same as when it started, around 25degC.
Performance wise, not much different to TP 65C packs over the flight. Probably because I'm drawing no where near 30C continuous, which is where the TP would truly shine.
For my applications, I save over 36g for the Zippy Compacts over the TP packs in 6S.
I mark each cell with the no. of flights it has had on it, so we'll see what it looks like at 50 cycles. I consider a stressed flight to 3.8V per cell resting a full flight, as it has been exposed to high current draws. If you're interested I can post IRs from my PL8, which seems pretty accurate.
As everydayflyer has said, one brand may be good for one particular mAh and C and S size, and not necessarily at any other. So far, these are great and very light. At just under 180g including connectors, if these make it to 100 flights, they really are the best bang for buck and weight.
rchelijc is offline Find More Posts by rchelijc
Old Jul 28, 2012, 03:17 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
just got 4 of the 2200mah for a 4S upgrade on my 450 Sport. Basically identical in size to the 3S turnigys I was using previously and only about 18 grams heavier. I only have two complaints about them. A. The XT60 connector is ridiculously tight and extremely hard to separate and B. The heat shrink tubing used on the backs of the connectors is crap and will crack and fall off leaving an exposed terminal. The red used on the positive side is particularly susceptible being made out of some kind of brittle waxy plastic. Have some heat shrink tape ready. For the price I'm willing to accept it but if I was paying $25 a battery I'd be in Hulk mode over this.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Jul 28, 2012, 07:40 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
For the tight XT60 connectors, Take a pair of needle nose piers and go around the male pins and give them a little squeeze all the way around till you get them the way you like. If you get them too loose pull them out again with a jewelers screwdriver. Keep them fairly snug for a good connection. I do the same thing with the Deans by flattening the springs.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jul 28, 2012, 08:32 AM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
I believe its the plastic that's the tight fit. I've tried that method to no avail.
stgdz is offline Find More Posts by stgdz
Old Jul 28, 2012, 09:39 AM
The Tug is online now
Find More Posts by The Tug
Barbados
Joined Jan 2011
The plastic has no stifness i have adjusted the male pins until there's no contact and the plug just falls apart.
The Tug is online now Find More Posts by The Tug
Old Jul 29, 2012, 12:11 AM
Joined Dec 2011
It was partly brand new connectors on both the batteries and ESC. I switched back to the old 40 amp plush (60 amp wasn't really needed and just added weight) and the plugs are much easier to separate now.
Old Sep 21, 2012, 06:59 PM
wingster is offline
Massachussets
Joined Nov 2005
Back in post# 79 I reported that I had two 5s 25c 5000 packs that measured between 3.0 and 3.3 mohms per cell at 68F. After 19 flights they are now measuring between 3.7-4.3mohms at 64F. They are holding up well and were recording lower readings this summer when my basement was warmer, but didn't fall much if at all below the initil readings of 3.0-3.3.
Old Sep 24, 2012, 08:51 PM
Joined Dec 2011
Had a tab break off a cell inside a 2200 25c on the ground during spoolup causing complete power failure.
Old Sep 27, 2012, 12:53 AM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
ive got one flight on 2 packs 1500 4S in a jet drawing 37.5amps i dont know if its a coincidence or what but my C rating is also continuous 37.5amps? 25C zippy compacts
gazza2003au is offline Find More Posts by gazza2003au
Old Sep 27, 2012, 01:22 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Months down the line ----- I'm buying more and more compacts instead of standard blue LiPo's ... I have completely given up on Nanotechs as well.
I'm now hoping that Compacts sizes will be more wide spread ... as some sizes I want are not catered for ... yet !
Nigel
solentlife is offline Find More Posts by solentlife
Alert HK buddy code for Zippy 5000mah 45c 2s1p lipo wagondriver42 Racing Boats - Electric 0 Feb 28, 2012 03:00 AM
Wanted XT-60 connectors and 4s 2200mAh 30-40c lipo's (pref Zippy) Keenan smith Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 20, 2012 09:49 AM
Sold 2 Zippy FlightMax 6s1p 2650 LiPo's donpzal Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 12, 2012 03:07 PM
For Sale Xtreme blade 120sr motor & 3 zippy lipo's heliguyhigh Aircraft - Electric - Helis (FS/W) 1 Jan 05, 2012 08:23 PM
Discussion Zippy Lipo's.....any good. Stuart Warne Batteries and Chargers 27 Aug 13, 2008 02:22 PM
