Old Mar 20, 2012, 01:50 PM
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Thanks for the replys guys.
I'll run them in the jet to cycle the packs at 3C+.
Might as well blow the dust out of the garage at the same time!
Bruce
bmiller is offline Find More Posts by bmiller
Latest blog entry: Durafly Vampire 70mm
Old Mar 21, 2012, 04:47 AM
Norway
Joined Sep 2005
Im considering the 7s 5800 zippy compact packs to be used in a 14s configuration, but I cant find any info on that specific cell size. Anyone in here heard anything, or even better, tried them your self?
authomassen is offline Find More Posts by authomassen
Old Mar 21, 2012, 05:14 AM
Norway
Joined Sep 2005
OK, guess I will be the one to report back on the 5800mah cells, just ordered two 7s packs.
Old Mar 22, 2012, 02:12 AM
United States, NV, Las Vegas
Joined Nov 2010
subscribed. Ordering some 4s 2700s
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Mar 22, 2012, 05:55 AM
1,1,2,3,5,8,13,21,34
Shortman's Avatar
United States, OR, Portland
Joined Nov 2003
Looking forward to hearing some real world results. I am looking at the 6S 3300/3700mah Zippy compacts if they do hold up well over time, the weight savings would really help in my heli on a 12S set up.
Shortman is offline Find More Posts by Shortman
Old Mar 24, 2012, 06:15 PM
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Subbed
Just ordered 5 off 3s 2200 will see if will stand up to a nice summers flying
Space Bat is offline Find More Posts by Space Bat
Old Mar 24, 2012, 06:44 PM
Joined Nov 2010
Originally Posted by Space Bat View Post
Subbed
Hey Chris, what are you going to put them into?
Old Mar 25, 2012, 03:18 PM
Team Hillbilly (UK)
Space Bat's Avatar
Joined Oct 2011
Hi Gary -
They will go into the EF Edge as am on a 3s setup - also will go into a ST models MX2 that my son flies - will see how they will work out on the P51D as it cooks batteries when I put this thing around 100mph (Yup its that fast ) or Katana Mini when fully repaired...
Will need some 4/5s so if these are good may be an answer for when the 60 MXS finally comes available...
Old Mar 27, 2012, 09:50 AM
matjon's Avatar
Sverige
Joined Oct 2007
Just received my Zippy Compact 6S 4500mah 35C.
All cells were at 3.84 or 3.85.
With 6mm gold bullets and a antispark cable it weighs 683 grams.
Donīt have anything to compare the weight with.
Will use it in my HTG L-39 90mm EDF. I hope it will hold up, otherwise I will regret not buying brand lipo afterall
Why do they use 8 AWG cables, pain in the a** to solder. 10 AWG is enough.
matjon is offline Find More Posts by matjon
Old Mar 27, 2012, 11:22 AM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
8 gauge as they can deliver 157 amps constant. Think about it...
Rick
rampman is offline Find More Posts by rampman
Latest blog entry: mean well S-210-12 power supply
Old Mar 27, 2012, 11:37 AM
matjon's Avatar
Sverige
Joined Oct 2007
Rick
I donīt see another brand having 8 AWG.
Old Mar 27, 2012, 01:23 PM
Shortman's Avatar
Joined Nov 2003
Curious as how these hold up, I am looking at some 6S 3300mah sized packs for my 12S Heli set up.
Could you test the IR of each cell or do you have the ability to do so?
Old Mar 27, 2012, 01:57 PM
matjon's Avatar
Sverige
Joined Oct 2007
Are you asking me? Sorry, donīt have the ability to check IR.
Old Mar 27, 2012, 02:31 PM
Shortman's Avatar
Joined Nov 2003
Yeah was going to see what your readings were.
Old Mar 27, 2012, 05:41 PM
Banzai Institute
buckaroo's Avatar
Buffalo, New York "No matter where you go there you are"
Joined Oct 2005
Ace hardware stores sell an 80 watt soldering iron with a 3/8" chisel tip for around 30 bucks. I t will make all your large soldering jobs a breeze. The key is not the watts but the big fat tip, it holds all the heat than dumps it all on your part in an instant. A smaller tip will just slowly transfer heat to what you are trying to solder and never get the joint itself hot enough. I used the tool for soldering battery bars an 2600mah A1213 cells and it worked great. I was able to tin the cells with globs of solder and the tool was on and off the cell in less than a second, with no heat transfer to the cell. I wouldn't think of using anything else but that for #8 wire.
buckaroo is offline Find More Posts by buckaroo
Alert HK buddy code for Zippy 5000mah 45c 2s1p lipo wagondriver42 Racing Boats - Electric 0 Feb 28, 2012 03:00 AM
Wanted XT-60 connectors and 4s 2200mAh 30-40c lipo's (pref Zippy) Keenan smith Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 20, 2012 09:49 AM
Sold 2 Zippy FlightMax 6s1p 2650 LiPo's donpzal Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 12, 2012 03:07 PM
For Sale Xtreme blade 120sr motor & 3 zippy lipo's heliguyhigh Aircraft - Electric - Helis (FS/W) 1 Jan 05, 2012 08:23 PM
Discussion Zippy Lipo's.....any good. stuart warne Batteries and Chargers 27 Aug 13, 2008 02:22 PM
