Old Mar 05, 2012, 04:01 AM
Rabeendra is offline
Find More Posts by Rabeendra
Joined May 2011
Setting up Dynam E-Razor 450
I bought a Dynam E-Razor 450 about 10 months ago and still could't fly properly. The TX/RX came with that and very dificult to fine tune. I have already broke several parts and how can I tune this to fly. Do you need me to change the TX/RX
Rabeendra is offline Find More Posts by Rabeendra
Old Mar 05, 2012, 06:41 AM
tom4416 is offline
Find More Posts by tom4416
Tom
United States, AZ, Tucson
Joined Dec 2011
If this was your first helicopter, I've no doubt you cant' fly it and will rebuild it several times before you can. I managed to get it off the ground with the stock radio but quickly decided it needed a better system. Installed a FlySky th-9x and that has helped a lot along with some other modifications to the servos and gyro. However, everything that has gone wrong with the helicopter has been pilot error.
You need, at a minimum, a flight simulator program that is realistic and you need to practice for many, many hours. Then you need to read all over the Internet on how to setup a helicopter - lots of good instructional videos on Youtube. And even after you get it setup properly, it will not fly itself in any way shape or form. From the moment you apply sufficient throttle to take off, your fingers will be moving sticks. It will never hover on its own (at least mine won't) and requires constant pilot input.
Altitude is your best friend and worst enemy . Height gives you some time to react but it also means the heli can get away very quickly and you've still got to bring it in for a landing which requires hovering it close to the ground. I cannot control it when it's only a few inches off the ground and yet that's critical to feeling confident and being able to actual return the machine to earth when the time comes. Right now I cheat it down from about two feet by hitting the throttle hold (at 0%) and giving it full positive collective which gives me a little auto rotation effect to bounce off the training wheels but that won't work in real life with the training gear off.
I consider the dynam my "disposable" helicopter. Hopefully I'll learn on it, likely crash it a few times, rebuild whatever breaks and then when it's a battered and beaten mess, I'll build a kit with all better components and salvage whatever I can from the Dynam.
Good luck. It isn't easy but it is (eventually) fun.
tom4416 is offline Find More Posts by tom4416
Old Mar 06, 2012, 02:11 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Start here:
http://www.mycoolheli.com/reviews/ReviewERazor450.html
Note the eRazor specific RCG thread link
then here:
http://www.mycoolheli.com/HeliTraining.html
Melnic is offline Find More Posts by Melnic
Old Mar 06, 2012, 02:16 PM
winginman is offline
Find More Posts by winginman
United States, KY, Louisville
Joined Aug 2010
Get rid of the factory radio. I use an Orange 6ch Spektrum compatible Rx from HK and my Spektrum DX6i.
Set up for a beginner it flies and hovers beautifully.
winginman is offline Find More Posts by winginman
Discussion Turnigy FlySky Imax programming with Dynam e-razor - a noobs guide tom4416 Beginner Training Area (Heli-Electric) 10 Aug 14, 2014 01:36 PM
Sold Dynam E-Razor 450 w/ a lot of spare parts. NoSlow5oh Aircraft - Electric - Helis (FS/W) 5 Feb 29, 2012 09:53 PM
Discussion Learning on Dynam E Razor 450 PLZZZ HELP heliferret Electric Heli Talk 6 Feb 23, 2012 09:19 PM
Found Dynam E-Razor 450 or other 450 class erikdravn Aircraft - Electric - Helis (FS/W) 2 Sep 22, 2011 11:33 AM
