Old Aug 25, 2012, 05:28 AM
PITPUP is offline
Find More Posts by PITPUP
Joined Nov 2011
Originally Posted by JeremyBB View Post
Hi Pitpup - It looks pretty good to me . From the size of the lift duct, you must be using an impeller as did the real things. Do you have an idea of the lift thrust you will get in relation to the weight of the craft? Are you building to a specification which someone else has already used or are you working from scratch?
A member of the Model Hovercraft Association in the UK is also building a 1/12th scale SRN6 and I think others have done before. I will let him know what you are doing and he may well have good advice to pass on.
Hi Jeremy.
Yes im having a go with a lift fan impellor, the information for which i got from the book that Mark Porter published. If you look back on this blog you will see some pictures of it which i posted some time ago.
Regards
Pitpup (steve)
PITPUP is offline Find More Posts by PITPUP
Old Sep 01, 2012, 06:48 AM
PITPUP is offline
Joined Nov 2011
Out on the open water for the first time. I have fitted a baffle in the air duct to try and counteract the turning motion when stationery. Seems to work at least to some extent. U-tube video: http://www.youtube.com/watch?v=Mms2NS3nbgU
Great vid, do you have one of it operating on land ??
Old Sep 06, 2012, 04:42 PM
JeremyBB is offline
Find More Posts by JeremyBB
Farnham Common, UK
Joined Oct 2009
No run on land yet - I still have to find a suitable location, smooth and traffic free. Hovertravel operated only as a ferry at sea with ramps onto land at either end of her crossings.
A second run at Black Park today almost ended in disaster. The lift prop flew off and she settled gracefully onto the lake.
SRN6disaster060912 (0 min 18 sec)
Fortunately, the box structure containing the electrics is water tight so she stayed afloat and the thrust prop was still able to get her back to land. That will teach me to check the prop fixings before every run. There is a fair amount of vibration so things can work loose. We live and learn!
JeremyBB is offline Find More Posts by JeremyBB
Old Sep 07, 2012, 01:16 PM
HoverTim is offline
Find More Posts by HoverTim
HoverTim's Avatar
Joined Mar 2007
there should be very little vibration what size prop have you used and did cut it dow even a new prop that has not been cut down needs to be balanced
HoverTim is offline Find More Posts by HoverTim
Old Sep 07, 2012, 03:29 PM
JeremyBB is offline
Farnham Common, UK
Joined Oct 2009
Prop is an 8*4 cut down to just less than 6". It was balanced and I have also balanced the replacement. We shall see how it goes. Maybe it's more noise than vibration.
Old Sep 07, 2012, 04:51 PM
HoverTim is offline
HoverTim's Avatar
Joined Mar 2007
props
whats the fit like on the prop adapter if its a bit loose then you can wrap some masking tape cut down to about 10 mm wide this allows the prop to sit tight on the shaft and not wobble i would check everything on your lift motor setup as the prop should not sheer off
Old Sep 08, 2012, 12:56 PM
JeremyBB is offline
Farnham Common, UK
Joined Oct 2009
3mm prop adapter on 3mm motor shaft. Seems to tighten up OK. I don't think there's any room for masking tape. Tried with a new prop today which shattered after a few minutes. I don't understand where the nicks came from as I only tried the craft on water. However, as you will see, it shattered which is probably what happened to the first one . Cheap Chinese rubbish from Hobby King?? - most of their stuff is excellent and good value so I have no complaints so far as rthey are concerned. Maybe their props are an exception. I will try with a genuine APC prop next, hopefully with better results.
Old Sep 09, 2012, 02:21 AM
jpcwebb is offline
Find More Posts by jpcwebb
MHA webmaster
United Kingdom, England, Reading
Joined Mar 2011
Definitely recommend APC - especially the 'E' variety specially designed for fast electric motors. Another thing might be to put mesh inside the intake opening to stop dirt getting in.
jpcwebb is offline Find More Posts by jpcwebb
Old Nov 21, 2012, 06:58 AM
sashaNar is offline
Find More Posts by sashaNar
Skilled crasher
Ukraine, Kyiv city, Kiev
Joined Oct 2010
I am making SR.N5 one using Porter's plans and lots of fotos. Here it is. Materials are 3mm plywood - boxes for fruits:-) and balsa. Scale is 1:16, it should weight around 1kg.
The main problem for me so far is finding 3mm shaft for thrust prop. I heard one can be found in old cd/dvd drives but idk where to get one.
sashaNar is offline Find More Posts by sashaNar
Old Nov 29, 2012, 05:19 AM
ChrisCurry is offline
Find More Posts by ChrisCurry
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
I used 3mm piano wire, cut it to length then put it in a drill and sanded it till it fit small ball race bearings I had from a helicopter project. Seems pretty straight and works fine.
ChrisCurry is offline Find More Posts by ChrisCurry
Old May 31, 2013, 12:29 PM
sashaNar is offline
Skilled crasher
Joined Oct 2010
Made some progress in the last month. Found 3mm shaft in local gobby shop - just as good as stock one, but long. I am using Trex 450 tail rotor for thrust - it will allow me to reverse. I like running on ground more than on water, so reverse is essential.
How to attach skirt's outer edge so that it will be easily removable? I thought about zipper, but dunno. It is so wide, even the smallest one.
Old Oct 15, 2013, 11:35 AM
JeremyBB is offline
Farnham Common, UK
Joined Oct 2009
Progress?
It's many months since I last looked at this thread. sashaNar or Pitpup, any progress on your models? I had my SRN6 out on the lake a couple of weeks ago. Goes OK but still pretty noisy - however, much less vibration after strenthening the lift motor mount. Video of run at
SRN6 at Black Park 060913 (1 min 28 sec)
Jeremy
New Product EAGLE N6 Multicopter Controller bdpowers Multirotor Talk 282 Jan 05, 2014 07:19 PM
Discussion Eagle N6 Controller board ferrocium Multirotor Talk 4 Jan 15, 2012 06:41 PM
Sold Airfield N6 - 6ch Tx and Rx - 2.4Ghz - $40 shipped conus h2oman Aircraft - General - Radio Equipment (FS/W) 9 Apr 20, 2011 07:57 PM
Sold Airfield N6 - 6ch Tx and Rx - $40 shipped conus h2oman Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 12:08 AM
Help! airfield n6 transmitter information? devinvagt Radios 4 Jan 08, 2011 02:08 PM
