Old Mar 05, 2012, 03:31 AM
JeremyBB is offline
Find More Posts by JeremyBB
Farnham Common, UK
Joined Oct 2009
Build Log
Hovercraft SR.N6
Build logs of scale hovercraft appear to be few and far between. So I've decided to start one here of my 1/16th scale SR.N6 built to a plan designed by Mark Porter. Any comments, help advice etc that I can get along the way would be much appreciated .
I plan to model the Hovertravel version shown in the photo below. I have started construction of the basic shell using 0.8mm birch ply and 6mm square balsa strips. So far, so good...
JeremyBB is offline Find More Posts by JeremyBB
Old Mar 05, 2012, 04:10 PM
ChrisCurry is offline
Find More Posts by ChrisCurry
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
Looking good! Nice ribs. I cheated with the ribs and just cut a hole in each one.
Made the ducting by wrapping balsa around a jam jar. Managed to sand the inlet so it looks even.
I painted the fan and ducting as it's probably easier to do during the build and touch up at the end. What are you using for the lift?
ChrisCurry is offline Find More Posts by ChrisCurry
Old Mar 05, 2012, 05:05 PM
JeremyBB is offline
Farnham Common, UK
Joined Oct 2009
Mark Porter's original design used a standard 540 brushed motor for lift with a 3 bladed 6"x3" prop.. I will use a brushless motor for more power and less weight but will stick to the same prop. The hole in the base is 6" in diameter so I may have to trim a prop a little bit. I haven't chosen the motor yet nor have I decided how to mount it to the body. When I get a bit further on with the build, I will have to work it out.
From your photo it looks like you are using an impeller for lift. How do you see that working as compared to a propellor? It's reduced diameter certainly gives you a more prototypical appearance.
I look forward to following your build.
Old Mar 06, 2012, 03:33 PM
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
I am using an impeller as it gives a more scale appearance and apparently has more of a compressor effect than a propellor. Also I just wanted to see if I could make one
I think the brushless and a prop will be a lot more efficient than the old rs540. Looking forward to more pics. I'll post some more of mine if I may as I've got quite a bit further.
Old Mar 08, 2012, 01:09 AM
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
A big advantage of the impeller/centrifugal fan. I've finished the skirt and attached it using tape so i can test it. It hovers on about 10% power! I'm using about a 100w motor so that's pretty efficient. It does weigh in at about 1kg so pretty light so far.
Old Mar 10, 2012, 04:16 PM
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
Moving on quicker now. The thrust motor had its shaft removed and I found a piece of 3.2mm piano wire which fitted it just fine. A few support bearings later, I wrapped the lot in .6mm ply.
Old Mar 14, 2012, 11:23 AM
owlsabie is online now
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Hey Chris - looking great there, so glad your impeller works Looking forward to seeing this one in person again
Al
owlsabie is online now Find More Posts by owlsabie
Old Mar 17, 2012, 06:18 AM
JeremyBB is offline
Farnham Common, UK
Joined Oct 2009
Hi Chris
You are making great progress. How were you able to test the lift of your model before sheeting in the deck?
My removable cabin structure now complete. Next step will be to install the peripheral support for the side frames. I will use 1/4 inch square spruce for this - heavier than balsa but it will provide better protection against the inevitable bumps.
Jeremy
Old Mar 19, 2012, 02:10 AM
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
I didn't test the lift but merely spun up the fan in the housing that I made for it. It blew everything off of the table so I knew it would work OK. In practice it works brilliantly. It hovers on less than half power and consumes less than 50 watts!
Your build is looking a lot nicer than mine. Your windows look really good.
Old Mar 26, 2012, 03:15 PM
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
Moved on. Have hovered and it does hover well at low powers.
Old Mar 27, 2012, 09:48 AM
owlsabie's Avatar
South Africa
Joined Feb 2009
Hey Chris ! She's a beaut!! Any news Jeremy?
Owl
Old Mar 27, 2012, 12:22 PM
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
Thanks, owl. I've just taken another picture now that the prop been replaced and the back end rebuilt. You can see that the panier lid back left is missing. That's the one that opened mid "flight" and broke the prop and did the damage.
Old Mar 27, 2012, 12:31 PM
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
Here is the kit I'm building for my daughter. The fan has come out far better than mine. I might steal it you can see bottom middle my special tools - the blade angle thing on the left, the blade length cutting jig in the middle and the window cutter on the right. Two hovercraft at the same time works quite well.
Old Mar 28, 2012, 02:11 AM
JeremyBB is offline
Farnham Common, UK
Joined Oct 2009
Hi Chris.
Beautiful model and you seem to work at the speed of light - from basic structure to close on completion in only three weeks! Will you be adding the ribs to the deck? Nothing to report on my build, Owl, as we've been away on holiday. I'll get back to it this weekend.
Jeremy
Old Mar 30, 2012, 02:07 AM
Barefeet
ChrisCurry's Avatar
Johannesburg
Joined Jul 2006
I will be adding ribs and puff ports to the deck. Hopefully get them to work as well. Busy closing up the area around the thrust motor. Bit of a pain...
New Product EAGLE N6 Multicopter Controller bdpowers Multirotor Talk 282 Jan 05, 2014 07:19 PM
Discussion Eagle N6 Controller board ferrocium Multirotor Talk 4 Jan 15, 2012 06:41 PM
Sold Airfield N6 - 6ch Tx and Rx - 2.4Ghz - $40 shipped conus h2oman Aircraft - General - Radio Equipment (FS/W) 9 Apr 20, 2011 07:57 PM
Sold Airfield N6 - 6ch Tx and Rx - $40 shipped conus h2oman Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 12:08 AM
Help! airfield n6 transmitter information? devinvagt Radios 4 Jan 08, 2011 02:08 PM
