Old Mar 05, 2012, 02:38 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
OPTIC 6 SPORT 2.4 - Firmware update V1.02(0)
HPP-22 V1.12(0)
. HTS-VOICE Firmware update and Set up can be upgraded by HPP-22.
. Firmware update for HTS-VOICE (Ver.1.03(0))!!
- Real time RX battery voltage announcing (w/o sensor station)
- Can be upgraded by HPP-22
. Firmware update for OPTIC 6 SPORT 2.4 (Ver.1.02(0))!!
- Refine Trainer function"
Instructions with pictures on how to remove old and install new HPP-22 program at
HPP-22 program file V1.12(0) now available.
26 September 2012: New Ugrades
HPP-22 Upgrade to V1.13(0)
includes:
Optic 6 Sport 2.4 V1.03(0) Upgrade
- Improved Latency
Update Optic 6 Sport Transmitter as pictured:
Hitec Optic 6 & Optic 6 Sport - Manuals, Tutorial, Comparison Charts, Updates & FAQ
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Apr 11, 2012, 05:35 PM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Hi Alan
Been trying to find out this info. I needed a cheap buddy box for my A9. I have trained many who had the Optic6 not the sport. So I purchased an FM optic 6 version. Also purchased the spectra module. Did the swap out but cannot bind to either of my spare optima 7 RX's. On the TX module I get a flashing blue led. On the RX the red solid. Do a reset after binding and get very intermittent servo response. Extremely jittery and hardly responsive. Do I need to change a setting in the optic 6 PPM or whatever? I had purchase a combine module with two Rx's as a kit. FW version on the box is 2.02. I have never had issue binding my A9 etc. What am I doing wrong. I cannot find any info or documentation on doing an upgrade from FM to 2.4 on the optic 6. Thanks much
acesimmer is offline Find More Posts by acesimmer
Old Apr 11, 2012, 06:23 PM
A.T. is offline
Joined Aug 2002
Originally Posted by acesimmer View Post
Hi Alan
Just answered same question on other thread before seeing this..
The Optic 6 does not "bind" to the Spectra Module.
Spectra module simply plugs into socket on reverse of Tx in lieu of the standard HPM-M or synthesised version.
Ensure Optic 6, via system menu (- hold down top left two buttons whilst switching on) is on PPM not QPCM and
although not essential with Spectra Module, preferably to keep standards, "N" shift.
The Spectra is a self contained Rf module has or update firmware version:
Spectra V2.00 for all transceivers V1.01 V1.04(0)
Spectra V3.01 for all Transceivers with V2.02 firmware & essential for Minima receivers (Optimum performance)
For further information, refer to:
. Hitec Optic 6 & Optic 6 Sport - Manuals, Tutorial, Comparison Charts, Updates & FAQ
As Slave Tx, the slave does not need to be bound to the Tx nor even have a module installed.
As Master Tx, simply swap the module from the A9 to Optic 6, saves resetting transceiever/receiver
when changing between the two Tx.
The module contains the Rf link
. Aurora 9 - Trainer / Buddy system Master & Slave function Set-up. - & Data Transfer A9<>A9 etc.
- Also covers Eclipse 7 Pro & other Hitec transmitters.
Alan T.
Old Apr 11, 2012, 07:00 PM
acesimmer's Avatar
Joined Oct 2011
Alan... Did all you suggested but it will not bind with any of my receivers neither 6,7 or 9 channels. I would have thought the procedure would be the same as my A9?
Old Apr 11, 2012, 07:24 PM
acesimmer's Avatar
Joined Oct 2011
Okay I just found out the problem. Got hold of the latest binding doc. Turns out I have to hit the link button on the tx for another 2 seconds to get the correct blink sequence. So finally have it communicating correctly. Slightly different than my A9. Thanks all for the help.
Help! Hitec Optic 6 2.4 Sport Problem fly Frontier Hitec/Multiplex USA 4 Oct 03, 2014 10:37 AM
Sold Hitec Optic 6 Sport 2.4 radio $80 JoeR Aircraft - General - Radio Equipment (FS/W) 16 Jan 12, 2012 08:25 PM
Help! Hitec Optic 6 2.4 Sport Problem. HELP fly Frontier Radios 1 Dec 30, 2011 06:47 PM
Discussion Optic 6 Sport 2.4 and Optima 6 carthagenj Hitec/Multiplex USA 6 Nov 23, 2011 02:34 PM
Help! hitec optic 6 2.4 vs optic 6 sport 2.4 shanet1975 Radios 13 Nov 29, 2010 03:06 AM
